[讨论]关于激光标记的问题
About SCANLAB Products Solutions Contact News Job Opportunities Downloads Sitemap
S10 an SSV30
SCANgine?/SUP
The SCANgine?/SUP series - the choice for a wide range of applications - comprises compact beam deflection units for two axes using the industry-proven galvanometer scanners from SCANLAB.
The modularity of the SCANgine?/SUP series makes it easy to meet special customer requirements.
Closed loop position control
Active temperature control
Maximum scan frequencies up to 700 Hz
For inertias up to 20 g-cm?/TD
Apertures up to 30 mm
Scan angles up to 50?optical
Moving iron technology
High precision capacitive position detector
Available with various input modes
Low weight
Typical applications:
Laser materials processing
Marking, Welding, Cutting, Scribing
Rapid manufacturing
Stereolithography
Micro-machining
Inspection Identification
Medical systems
Ophthalmology, Dermatology
Science Research
The High Performance Galvanometer Scanner S10 is a moving iron galvanometer scanner. Together with the Amplifier Board SSV30, the S10 forms a high precision unit for the deflection and positioning of laser beams.
This unit meets the highest demands for precision and speed over a wide range of applications.
The S10 and the SSV30 are manufactured to the highest quality standards, thus ensuring error-free operation for long term and continuous use.
S10
The precise capacitive position detector exhibits a highly linear behaviour over the full range of deflection and allows integration in a closed position control loop.
Temperature-regulated scanner heating and a feed back line for automatic gain control optimize the drift behaviour and ensure the highest precision and stability.
Axially preloaded precision ball bearings guarantee that the rotor bearing is free of backlash and that friction and hysteresis remain low. The optimal layout of the magnetic circuit leads to very good torque linearity over the full range of deflection.
The rotationally symmetrical mounting flange allows the S10 to be easily integrated into customer-specific single- or multiple-axis deflection units.
SSV30
The SSV30 amplifier board transforms an analog input signal into a proportional angular excursion of the scanner.
The board also provides additional vital functions such as temperature stabilization, automatic gain control and generation of status signals. The board is available with different current and voltage input modes.
The SSV30 board, which forms a closed control loop together with the scanner S10, can be optimally tuned to the specific scanner-mirror configuration.
Overall solutions from SCANLAB
SCANLAB designs and manufactures complete subsystems.
SCANLAB provides matching mirror substrates with coatings for all common laser wavelengths and power densities. Mirrors and mirror mounts are inertia-optimized.
SCANLAB also offers scanner mounts developed for XY scan systems with various apertures.
Impressum Home
(c)2002 SCANLAB AG - This page is best viewed with Microsoft Internet Explorer 5 or higher.
Company Overview
Focusing on
Management
Impressum
The Company
The Employees
The Market
Innovations
Milestones
Overview
Application Matrix
Scan Heads
Hand-held Scan Unit palmSCAN
Variable Focal Length Optical Systems
3D Beam Positioning Systems
Scanners and Amplifier Boards
Electronics and Control
Customized XY-Scan-Modules and Systems
Scan Head Series SCANgine?/sup
Scan Head Series hurrySCAN?/sup
Scan Head Series SCANjet?/sup
Compact Scan Head HS7
SK1020
powerSCAN
hurrySCAN?/sup 10, 14
hurrySCAN?/sup II 10
hurrySCAN?/sup 25
SCANjet?/sup
SCANjet?/sup II
powerSCAN 33
powerSCAN 70
varioSCAN 20
varioSCAN 40 / varioSCAN 80
XY Scan Head varioSCAN
powerSCAN 33 varioSCAN 40
powerSCAN 70 varioSCAN 80
S10 an SSV30
PC Interface Board RTC3
PC Interface Board RTC2
Interface Board PC1000
Interface Board SDIREC
Amplifier board SSV30
Automatic Self-Calibration
How to contact us
E-Mail
Information Request
How to find us (in Puchheim)
The latest from SCANLAB
Press Releases
Events
SCANLAB America, Inc.
Compact Scan Head with 25 mm Aperture for High-Power Lasers
New Reference Standard for Scan Heads
A New Dimension in Laser Beam Steering
High Power Laser Beam Steering in 3D
The Future is Now!
Schwei?Scanner f黵 hohe Leistungen
Freude am Laser
Schwei遝n per Scanner
Im Gespr鋍h
Auf den Verschluss gebracht
SCANLAB AG
Zukunft Lasertechnik
Technischer Vertrieb
你好,那位前辈能意译 |
