高分辨率视频摄远物镜光学系统设计及成像实验
Optical System Design of High Definition Video Telephoto Objective and Its Imaging Experiment
下载全文
高分辨率视频摄远物镜光学系统设计及成像实验.pdf
(946.19 KB, 下载次数: 10)
作 者:高兴宇[1,2,3] 郁道银[1] 龙跃[2] 萧泽新[3]
Gao Xingyu Yu Daoyin Long Yue Xiao Zexin( 1School of Precision Instrument and Opto-Electronics Engineering, Tianjin University, Tianjin 300072, China 2Liuzhou OVM Mechatronics Incorporated Corporation, Liuzhou, Guangxi 545005, China 3School of Mechatronics Engineering, Guigin University of Electronics Technology, Guilin, Guangxi 541004, China)
机构地区:[1]天津大学精密仪器及光电子工程学院,天津300072 [2]柳州欧维姆机械股份有限公司,广西柳州545005 [3]桂林电子科技大学机电工程学院,广西桂林541004
出 处:《激光与光电子学进展》 CSCD 2014年第51卷第10期 77-82页,共6页
Laser & Optoelectronics Progress
摘 要:为了满足斜拉桥拉索表面缺陷的远程检测要求,基于摄远型物镜结构原理设计加工了高分辨率视频摄远物镜光学及机械系统。根据物方300 m外分辨4 mm线宽的分辨率要求,按照焦距f′=320 mm计算,确定摄远物镜像方分辨率为234 cycle/mm。选择适当初始结构,用光学设计软件OSLO进行焦距缩放、替换玻璃、减少镜片等多步骤优化,最后得到相对孔径为1/5.7、视场角为2ω=1.379°、分辨率达到250 cycle/mm的摄远物镜光学结构。合理设计光机结构,加工装调实验样机。分辨率测试实验证明其实际物方分辨率可以达到300 m远分辨4 mm线宽。在斜拉桥工程现场成像实验表明该系统符合实际工程结构表面缺陷远程检测的要求。
In order to satisfy the remote detection requirements for the surface defects on the cables of cable stayed bridges, an opto-mechanical system of a high definition video telephoto objective is designed and manufactured. According to the objective definition requirement of 4 mm at the distance of 300 m, the imaging definition of 234 cycle/mm with a focal length of 320 mm is determined. A proper initial configuration is chosen, and then some optimization procedures are carried out with the optics design program OSLO, including the focus zooming, glass exchanging, lens reduction, etc. Finally an optical configuration of the telephoto objective is obtained with the relative aperture of 1/5.7, the field angle of 2 ω =1.379°, and the definition of 250 cycle/mm. The opto-mechanical structures are designed rationally and the experimental objective is manufactured. The definition testifies that its actual objective definition reaches 4 mm at the distance of 300 m. The site imaging experiment results at the location of a cable stayed bridge show that this system satisfies the remote detection requirements for the surface defects on the real engineering structures.
关键词:光学设计 高分辨率摄远物镜 光学像差优化 远程表面缺陷检测
optical design ; high definition telephoto objective ; optical aberration optimization ; remotedetection of surface defects ; |
