成像光谱仪大孔径前置物镜设计研究
Research and Design of Prefixing Objective with Large Aperture in Imaging Spectrometer
下载全文
成像光谱仪大孔径前置物镜设计研究.pdf
(361.81 KB, 下载次数: 2)
作 者:于建冬[1,2] 梁中翥[1] 梁静秋[1] 吕金光[1] 秦余欣[1] 田超[1,2] 王维彪[1]
Yu Jiandong,Liang Zhongzhu,Liang Jingqiu,Lv Jinguang,Qin Yuxin,Tian Chao,Wang Weibiao(1.State Key Laboratory of Applied Optics, Changchun Institute of Optics, Fine Mechanics and Physics, Chinese Academy of Sciences, Changehun, Jilin 130033, China; 2.University of Chinese Academy of Sciences, Beijing 100049, China)
机构地区:[1]中国科学院长春光学精密机械与物理研究所应用光学国家重点实验室,吉林长春130033 [2]中国科学院大学,北京100049
出 处:《光学学报》 EI CSCD 2015年第2期 268-275页,共8页
Acta Optica Sinica
基 金:国家自然科学基金(60977062,61027010,61376122)、国家863计划(2009AA042315)、吉林省科技发展计划项目(201205025,20130206010GX)、长春市科技发展计划项目(2011131,2013261)
摘 要:含有阶梯微反射镜和片状分束器的时空联合调制型傅里叶变换成像光谱仪的前置成像系统不仅要满足与阶梯微反射镜参数相匹配,还需具有实入瞳和像方远心的特性。为此,研究了将普通红外物镜转变为具有实入瞳的像方远心结构的方法。同时,研究了片状分束器和补偿板所带来的离轴像差,并提出了采用柱面和泽尼克面相结合的矫正方法以提高成像质量。设计出满足光谱范围3~5μm、F数为4、有效焦距为400 mm、视场为4.58°的整个波段全视场范围内无渐晕的红外光学系统。仿真结果表明:前置成像系统的成像质量接近衍射极限,最大全视场均方根光斑直径为5.9μm。这种设计方法可以用于大孔径时空联合调制型傅里叶变换成像光谱仪前置成像系统设计。
Containing stepped micro-mirror and flaky beam splitter, prefixing objective of spatio-temporally modulated Fourier transform imaging spectrometer is not only to match with parameters of ladder micro- mirror, but also to have telecentric characteristic with a real entrance pupil. To this end, this paper studies a method to transform the ordinary infrared lens into a telecentric construction with a real entrance pupil. Meanwhile, the study of off axis aberrations caused by the sheet beam splitter and compensation plate proposes a correction method applying a combination of cylindrical and Zernike surface to improve image quality. Based on the method, with the specific requirements of 3-5 pm spectral range, F number of 4, 400 mm effective focal length, no vignetting within full field of view of 4.58~, an infrared optical system is designed. Simulation results show that: the image quality of front objective is closed to the diffraction limit with the maximum root mean square (RMS) spot diameter 5.9 μm in full field, and the distortion less than 0.3%. So this method can be used for the design of the front lens with large aperture in spatio-temporally modulated Fourier transform imaging spectrometer.
关键词:光学设计 傅里叶变换成像光谱仪 红外系统 片状分束器
optical design ; Fourier transform imaging spectrometer ; infrared system ; flat splitter ; |
