金刚石研磨液抛光高硬度不锈钢工艺研究
CMP of stainless steel 1 1Cr17 with diamond slurry
下载全文
金刚石研磨液抛光高硬度不锈钢工艺研究.pdf
(582.64 KB, 下载次数: 0)
作 者:王志强[1] 豁国燕[1] 方伟[1] 王沛[2] 刘弟鑫[1]
WANG Zhi-qiang, HUO Guo-yan, FANG Wei, WANG Pei, LIU Di-xin (1. Zhengzhou Research Institute for Abrasives & Grinding Co. Ltd. , Zhengzhou 450001, China) (2. Henan University of Technology, Zhengzhou 450001, China)
机构地区:[1]郑州磨料磨具磨削研究所有限公司,郑州450001 [2]河南工业大学,郑州450001
出 处:《金刚石与磨料磨具工程》 2014年第6期 76-79页,83页,共5页
Diamond & Abrasives Engineering
摘 要:研究了11Cr17不锈钢的抛光工艺。通过考察抛光液理化指标参数以及抛光工艺条件对不锈钢去除速率、反射率、表面粗糙度值 Ra的影响,确定了合适的抛光工艺:抛光时间60 min、系统压力150 N、磨盘转速50 r/min。经此条件抛光后的不锈钢表面平整光亮,去除速率0.0477 mm/min,反射率为47%,表面粗糙度值 Ra为21 nm。
The polishing process of 1 1Cr17 stainless steel was studied. The effects of slurry characteristics and polishing conditions on removal rate,reflectivity and roughness(Ra)of the stainless steel were examined.Optimized polishing process conditions were as follows:polishing time 60 min, system pressure 150 N,and disc rotation speed 50 r/min.The stainless steel surface was smooth and bright after polishing on these conditions.The removal rate was 0.047 7 mm/min and the reflectivity 47%,as well as the surface roughness Ra 21 nm.
关键词:不锈钢 抛光 反射率 表面粗糙度
stainless steel ;polishing ;reflectivity ;surface roughness ;
