标题: 光纤插头端面加工中材料去除的分析 [打印本页]
作者: 风轻扬    时间: 2015-7-12 18:46
光纤插头端面加工中材料去除的分析
Material Removal Analysis on Face Machining of Optical Fiber Plug
下载全文
光纤插头端面加工中材料去除的分析.pdf (1.08 MB, 下载次数: 0)
作  者:高绮 杨浩 董刚
GAO Qi, YANG Hao, DONG Gang (Mechanical Engineering Training Center, Tianjin Vocational Institute, Tianjin 300410, China)
机构地区:天津职业大学机械实训中心,天津300410
出  处:《机电工程技术》 2014年第9期 77-80页,137页,共5页
Mechanical & Electrical Engineering Technology
基  金:天津市自然科学基金面上项目(编号:13JCYBJC18100);天津职业大学培育项目(编号:20101101)
摘  要:为了研究光纤端面的现行加工工艺,提出了一种光纤端面材料去除的分析方法。对被加工光纤端面和研抛工具先进行研磨压力的有限元分析,再模拟计算光纤研磨速度,最后分析去除率的材料。结果表明:光纤端面材料去除率的变化周期主要受研磨速度影响;成形初期的研磨去除率分布主要受研磨压力的影响;与平动式光纤研磨机相比,用行星回转式光纤研磨机加工一批单芯光纤和MPO多芯光纤插头时,由研磨速度的差异引起的各纤芯间材料去除率变化的最大值分别为3%和0.32%。本模拟分析方法建模简单,直观,模拟分析结果与生产现状相一致。
In order to investigate the existing process of optical fiber end-face, a simple material removal analysis on optical fiber end-face is established .Analyzing the fiber and lapping/polishing film posted on the rubber pad as follow,first the FEM static analysis of lapping pressure, secandly, simulating lapping/polishing velocity, at last analyze the material removal rate on basis of 1&2. Analysis results indicate that the material removal rate varied periodically with time, as like the lapping/polishing velocities, the distributions of material removal rate at beginning of the forming processing mainly affected by the lapping pressure;Using planetary rotary fiber lapper, not translational one,the Max. R/t among of single fiber end-faces is 3%,because of different lapping velocity and this value will up to 3%for the MPO end-face. This analysis is easy to model,and simulation results are corresponding to the processing.
关键词:材料去除 光纤端面 研磨/抛光
material removal ;optical fiber end-face ;lapping/polishing ;
