Applications: ·Metropolitan area network ·Laboratory research ·System monitoring ·Dynamic configuration points inserted multiplexing
Features: Low insertion loss Wide wavelength range Low cross talk High stability, reliability Exclusive patent technology Optical path without glue Latching or non-latching Parameters
| D2×2B
| Wavelength range nm
| 670~980
| 1260~1650
| Testing wavelength nm
| 670/785/850/980
| 1310/1490/1550/1625/1650
| Insertion loss dB
| Typ:0.8 Max:1.2
| Return loss dB
| SM≥50 MM≥30
| Cross talk dB
| SM≥55 MM≥35
| Polarization dependant loss dB
| ≤0.05
| Wavelength dependant loss dB
| ≤0.25
| Temperature dependant loss dB
| ≤0.25
| Repeatability dB
| ≤±0.05
| Working voltage V
| 3.0 or 5.0
| Lifetime times
| ≥107
| Switching time ms
| ≤8
| Transmission power mW
| ≤300
| Operating temperature ℃
| -20~+70
| Storage temperature ℃
| -40~+85
| Dimension mm
| 16
| Wavelength range nm
| (L)27.0×(W)12.6×(H)8.0(公差±0.2)
