在zemax 中有个程序,叫Seq2ZMX,可以将Code V文件转换成zemax文件,您试试这个看。但也有些限制的:以下是它的说明: SEQ2ZMX v 1.3 Utility to convert Code V(TM) sequence files to ZEMAX files Syntax: SEQ2ZMX INPUTFILENAME OUTPUTFILENAME LOGFILENAME Where
INPUTFILENAME is the input sequence file name, i.e. LENS.SEQ
OUTPUTFILENAME is the output ZEMAX file name, i.e. LENS.ZMX
LOGFILENAME is the optional log file name. Default = seq2zmx.LOG
File names may include the drive and path. Supported Commands: Aspheric surface type
Conic surface type
Cylindrical surface type
Grating surface type
Spherical surface type
Default dimensions
Numerical aperture, F/#
PIM solve
Radius or curvature, thickness, glass
Wavelengths, reference wavelength, and weights
Field angles, object height, and paraxial image height
Title
X,Y,Z tilts, decenters, BEN and DAR commands
Zooms on thickness Disclaimer:
This utility is provided as is without warranty either expressed or implied.
The utility is intended to convert simple Code V ver. 8.1 sequence files to
ZEMAX lens files. Not all Code V commands are supported. Complex systems
may require additional editing within ZEMAX. Unconverted commands
are stored in the log file. E-mail conversion suggestions to
support@zemax.com . |
