主要特性与技术指标- Dramatically simplified transceiver measurements that provide just the essential tests via the one page graphical user interface (running on an external Windows® XP PC via a USB 2.0 interface)
- Standard measurements at fixed rates between 125 Mb/s and 3.125 Gb/s
- Generation of Pseudo Random Bit Sequence (PRBS) polynomials and a K28.5 pattern at Low Voltage Differential Signal (LVDS) or Emitter Coupled Logic (ECL) levels
- Optical and electrical error injection (once or at selectable Bit-Error-Ratio)
- Analysis of gated Bit-Error-Ratio with display of the absolute number of errors and selectability of gate time
- Flexible connections to the device under test via 3.5 mm differential electrical coax connectors and/or standard optical SFP module plug-ins
- Full programmability of all graphical user interface features from another software program, making automation in manufacturing an easy task
描述Keysight N5980A 3.125 Gb/s生产用串行BERT(比特误码率测试仪)可对制造收发模块的过程进行测试,其价格只是当前N4906B BERT的三分之一。它还具有独立的电接口和光接口(SFP插件),提供双倍的最大吞吐率。除了具有价格优势以外,它还把测试成本降低了6倍。
另外,N5980A的体积缩小了6倍,节省了宝贵的空间,进一步降低了测试成本。因此,尤其针对低成本、高吞吐率的测试应用而言(比如千兆位收发模块制造),它已经成为最具有吸引力的测试解决方案。
- 速率范围155 Mb/s到3.125 Gb/s之间的标准测量。
- 在低压差分信号 (LVDS) 或发射极耦合电路(ECL)电平上生成伪随机二进制序列(PRBS)多项式和K28.5码型。
- 通过3.5 mm差分同轴电连接器和/或标准光SFP模块插件,灵活地连接到被测器件上。
- 光电接口差错产生(单次产生或者按照可选的比特误码率)。
- 分析门选通比特误码率,可以显示误码的绝对数量和选择门选通时间。
- 大幅简化收发模块测量,通过USB 2.0接口连接到外置Windows® XP电脑上的单页图形用户界面,从而进行基本测试。
- 全面的图形化可编程,配合相关软件程序,使生产自动化测试成为一项轻松的任务。
- Data rate The same data rate applies for pattern generator electrical out and optical out, and for error detector electrical in and optical in. Data rates Fast Ethernet 125 Mb/s OC-3 155.52 Mb/s OC-12 622.08 Mb/s OC-48 2.48832 Gb/s OC-48 with FEC 2.66606 Gb/s 1 x FC 1.0625 Gb/s 2 x FC 2.125 Gb/s 1 x Gigabit Ethernet 1.25 Gb/s XAUI 3.125 Gb/s Accuracy ± 50 ppm Operating system The software supplied runs on Windows 2000, XP or 7 with .NET v2.0, by a USB 2.0 interface. Pattern Generator Pattern The following patterns are supported: PRBS: 27-1, 215-1, 223-1, 231-1. Data pattern: K28.5. Clock pattern: data rate divide by n, n=2,4,8,10,16,20 The pattern can be individually adjusted for pattern generator electrical out and optical out. Error injection Fixed electrical and optical error inject: Fixed error ratios of 1 error in 10n bits, n=3,4,5,6,7,8,9. Single error injection. Separate error ratios can be adjusted for pattern generator electrical out and optical out. Pattern generator electrical out A differential electrical output is provided on the front-panel. Out/Out Output type differential, AC-coupled, external 100 Ω differential termination Amplitude, selectable ECL 850 mVpp typ., single-ended 1700 mVpp typ., differential LVDS 400 mVpp typ., single-ended 800 mVpp typ., differential Jitter peak-peak 0.05 UI typ. @ OC-12 0.08 UI typ. @ GbE 0.15 UI typ. @ OC-48 Connector SMA, front panel Pattern generator optical out A standard SFP housing is provided. Minimum number of insertion/deinsertion cycles: 200. Trigger output A single-ended, electrical output is provided on the front-panel. Trigger out Output type single-ended Impedance 50 Ω nominal, AC-coupled Amplitude 850 mV typ. Clock rate, selectable data rate divided by n, n=2,4,8,10,16,20 Connector SMA, front Panel Error Detector A differential electrical input is provided on the frontpanel. Data rate is the same as pattern generator. Pattern The following patterns are supported: PRBS: 27-1, 215-1, 223-1, 231-1. In/In Input type differential, AC-coupled Max. input amplitude 1 Vpp, single-ended 2 Vpp, differential Impedance 100 Ω nominal Sensitivity < 50 mV Clocking mode internal CDR Synchronization automatically on level, polarity, phase, bit and pattern Connector SMA, front panel
- Agilent 83497A 光电时钟恢复模块
Agilent 8157A 光衰减仪
Agilent 81637B 快速功率计
Agilent 34570A 数字万用表
Agilent 44476A 微波复用器模块
Agilent 70004A 光谱分析仪
Agilent 81000FI 光纤连接器
Agilent 81002FF 积分球
Agilent 81521B 光功率计探头
Agilent 81524A 光功率探头
Agilent 81525A 大功率光学探头
Agilent 81533A 接口模块
Agilent 81533B 接口模块
Agilent 81536A 光功率计传感插件
Agilent 81560A 可变光衰减器
Agilent 81567A 可变光衰减器模块
Agilent 8156A 光衰减器
Agilent 81578A可变光衰减器模块
Agilent 81610A回损测试模块
Agilent 81619A 光功率模块
Agilent 81624A 光学探头
Agilent 81625A 光功率探头
Agilent 81633A 分布式反馈(DFB)激光器
Agilent 81635A 双光功率传感器
Agilent 8163A光功率计主机
Agilent 8163B 光波万用表
Agilent 8164A 光波测量系统主机
Agilent 81650A 单法布里-珀罗激光源
Agilent 81651A 光源模块
Agilent 81654A 法布里-珀罗激光源
Agilent 81662A 分布式反馈(DFB)激光器
Agilent 8168E 可调谐激光源
Agilent 83440D 光波转换器
Agilent 83480A 数字通信分析仪
Agilent 83483A 双通道电模块
Agilent 83486A 光电模块
Agilent 83487A 光电模块
Agilent 83492A 多模时钟模块
Agilent 83493A 单模时钟恢复模块
Agilent 83494A 单模时钟恢复模块
Agilent 83495A 时钟恢复模块
Agilent 83496A 光电时钟恢复模块
Agilent 86100A 光示波器
Agilent 86100C 宽带示波器主机
Agilent 86103A 光电模块
Agilent 86103B 光电模块
Agilent 86105A 光电模块
Agilent 86105B 光电模块
Agilent 86106B 光电模块
Agilent 86107A 精密时基参考模块
Agilent 86120B 多波长计
Agilent 86120C 多波长计
Agilent 86142B 高性能光谱分析仪
Agilent 86146B 光谱分析仪
Agilent N7740 多端口光功率计
Ando AQ2140 光功率计
Ando AQ2730 光功率计模块
Ando AQ2742 光功率传感器
Ando AQ2743 光功率传感器
Ando AQ4211 LD组件
Ando AQ4215 光功率计
Andu AQ-4137 光源
Andu AQ-4142 光源
Anritsu 69347B 信号源
Anritsu MN9610B 光衰减器
Anritsu ms9710c 光谱分析仪
Anritsu MS9740A 台式光谱分析仪
CVI Melles Griot 05-LHP-211-1 激光器
Ericsson FSU-975 光纤熔接机
Exfo IQS-3150 可变衰减器
EXFO WA-1650 光波长计
HP 8153A 光功率计
HP 8153B 光波万用表
HP 81551MM 点光源模块
HP 83540A 插件信号源
HP 8595E 频谱分析仪
IFR GPS-101 全球定位系统模拟器
Jdsu HA9 光衰减器
JDSU OLP-55 光功率计
Keithley 7001半导体开关系统
Keithley 2001A 数字多用表
Keithley 2400 数字源表
Keithley 2400-C 数字源表
Keithley 2500 数字源表
Keithley 2502 数字源表
KEITHLEY 6221 电流源表
Keysight 11708A 衰减器垫
Keysight 3458A 数字多用表
Keysight 34903A GP开关模块
Keysight 81570A 可变光衰减器模块
Keysight 81618A 接口模块
Keysight 81623B 锗光功率探头
Keysight 81630B 大功率光传感器
Keysight 81634B 低偏振相关光功率传感器
Keysight 81636B 光功率传感器
Keysight 8164B 光波测量系统主机
Keysight 82357B GPIB 卡
Keysight 86100D 宽带宽示波器主机
Keysight 86105C 光电采样模块
Keysight 86105D 光电模块
Keysight E3631A 三路输出电源
Keysight J7231B 抖动通信性能分析仪
Keysight N5181A 射频模拟信号发生器
Keysight N5980A 比特误码率测试仪
Keysight N7744A 多端口光功率计
Keysight N7748A 高性能光功率计
Newport 818-IG 高性能光电二极管传感器
Newport 918-IG 高性能光电二极管传感器
Newport 918-ir 高性能光电二极管传感器
NI PCI GPIB 小卡
NI PXI-1031 板卡
Photom EP-712 光功率计
Picometrix PT-12B 光电转换芯片
R&S FSP3 频谱分析仪
R&S NRPZ51 射频功率计
R&S NRPZ55 射频功率计
R&S NRP-Z55 射频功率计
Tektronix DPP125B 误码仪
Tektronix 80C02 光采样模块
Tektronix 80E04 双通道时域反射计
Tektronix DSA8200 采样示波器
Tektronix DSA8300 数字采样示波器
USHIO UXM-Q256BY点光源
YOKOGAWA AQ2200-421 单槽型光开关
YOKOGAWA AQ2201 帧控制器主机
