只是一个cmos芯片的资料啊。
这样的资料我还有其他的,比如sony,kodak,micron等。
需要的朋友可以联系我
huangfy@daheng-image.com
qq 7686974898
General Description
The PAS202B is a highly integrated CMOS active-pixel image sensor that has a VGA resolution of 644H x 484V.
To have an excellent image quality, the PAS202B outputs 10-bit RGB raw data through a parallel data bus. It is
available in color or monochrome and in 28-pin LCC.
The PAS202B can be programmed to set the exposure time for different luminance condition via I2CTM serial
control bus. By programming the internal register sets, it performs on-chip frame rate adjustment, offset correction
DAC, programmable gain control, 10-bits ADC and 8-bits output formatting. |
