谁整过输出脉宽1ns的DPL
回复|共 33 个
jeank Lv.4 发表于 2008-7-24 12:53:46|浙江 | 查看全部
用两个自饱和吸收体,弛豫时间不一样的,再加上短腔设计,合适的参数,就可以产生1ns输出
robinhand413 楼主Lv.8 发表于 2008-7-24 14:15:47|四川 | 查看全部
可否留个email详谈!!!
再也不能这样 Lv.10 发表于 2008-7-24 14:16:36|新加坡 | 查看全部
原帖由 jeank 于 2008-7-24 12:53 发表
赞你无私的信息!
频率呢?平均功率呢?
jeank Lv.4 发表于 2008-7-24 15:53:41|浙江 | 查看全部
email地址已站内短信,请查收一下
kaka Lv.14 发表于 2008-7-24 16:31:14|北京 | 查看全部
CR4:YAG可以,我有现成的
kaka Lv.14 发表于 2008-7-24 16:32:15|北京 | 查看全部
压到几个ns没问题
何必有我 Lv.8 发表于 2008-7-25 09:32:35|湖北 | 查看全部
微腔+腔倒空,例子 brightsolution的wedge激光器
再也不能这样 Lv.10 发表于 2008-7-25 10:58:43|新加坡 | 查看全部
http://www.brightsolutions.it/index.php?pageId=15
Wedge DPSSL
High Peak Power Diode Pumped Solid State Laser
All solid state design
Patented Polarization-Switching Technology
Less than 1.5 ns pulse duration
Up to 1 MW peak power
Low heat waste,air cooling
WEDGE emits pulses of 1.5 mJ energy at 1064 nm, duration shorter than 1.5 ns and peak powers exceeding 1 MW.
Based on a proprietary electrooptic Q-switching technology,this monolithic laser source features a very high peak power with excellent wall plug efficiency.
The sealed miniaturized laser head is insensitive to vibrations and harsh environments. High output peak power with relatively low Q-switch energy allows efficient nonlinear harmonic or parametric generation as well as interaction with a wide range of materials.
Harmonic options available:
Second harmonic @ 532 nm
Third harmonic @ 355 nm
Two mechanical configurations available:
Single Unit.
Dual Unit. A Resonator Unit is linked to a Pumping Unit via a fiber optic cable and a Q-switch cable.
Both the versions have built-in finned heat exchangers for air cooling.
Applications
Nonlinear spectroscopy
2nd and 3rd harmonic generation
Visible to IR OPO pumping
Material processing
Surface and intra-volume glass marking
何必有我 Lv.8 发表于 2008-7-25 15:30:11|湖北 | 查看全部
如果为了达到1ns的脉宽,却使得频率不能连续调节就没有什么意义了
robinhand413 楼主Lv.8 发表于 2008-7-28 14:13:11|四川 | 查看全部
但有的用户就是需要窄脉宽,其他的不要求。
另外还有需要激光脉宽1~30ns连续可调的,不知各位有何高见?
