CJY-300C片剂脆碎度检测仪
CJY-300C型片剂脆碎度检测仪,是控制药片稳定性的测试仪器,适用于片剂生产厂,药检所,及医院和医学院校等单位对药物片剂的稳定性抗腐蚀性,滚扎碰撞性及其它物理强度。是药物检测中不可缺少的仪器。它为片剂包糖衣提供了可靠的依据,符合中国药典2005版药物片剂脆碎度检测标准。
轮毂内径:286mm
轮毂深度:39mm
转速精度:±0.5转
CJY-300C tablet friability tester which can control the stability of drug uncoating tablet. It is apply to the tablet production plants, hospitals and other units of Institute for control and detection of drug tablets’ mechanical stability, abrasion resistance, rolling resistance of the collision, as well as other physical strength (such as crushing strength, etc.), the tester also is an indispensable and necessary equipment. According to the demand of user, Computer program can set arbitrary in the motor rotary speed, brake drum circle round and other aspects.
The main technical parameters:
The inner diameter of drum inner diameter 286mm ±0.20mm
The depth of drum depth 39mm ±0.30mm
The range of rotary speed 25 r/min
The accuracy of rotary speed ±0.2 r %
CJY-300B型片剂脆碎度测定仪
CJY-300B型片剂脆碎度测定仪是控制药片稳定性的测试仪器。适用于片剂生产厂、药检所及医院等检测药物片剂的机械稳定性、抗磨性、耐滚轧碰撞性,以及其它物理强度(如压缩强度等),是药物检测中不可缺少的必备仪器。它为片剂包糖衣也提供了可靠的数据。符合《中国药典》2005版脆碎试检测标准本仪器有两个透明有机玻璃轮鼓,在每分钟25转恒速转动下,至100转自动停机报警。整机结构设计合理、外观大方、操作简便,装药鼓轮开启方便、透明度高,便于观察测试情况。
主要技术参数:
轮鼓内径:286mm±0.2mm
轮鼓深:39mm±0.3mm
转速:25r.p.m、100转自动报警停机
CJY-300B tablet friability tester which can control the stability of the tablet and apply to the tablet production plants, units of Institute for control, hospitals and medical colleges and other units of the drug tablet for detection of drug tablets’ mechanical stability, anti-corrosion stability, rolling resistance of the collision, as well as other physical strength. the tester also is an indispensable and necessary equipment. It is also provide a reliable basis for sugar-coating tablet and in line with the Chinese Pharmacopoeia 2005 version of the tablet drug testing standard of tablet friability degrees.
The tester have an unique liquid crystal display and microcomputer control system, with accurate test data, under in every 25 minutes constant speed rotation, the speed of two wheels Perspex transparent can up to 100 rotation with automatically alarm.
The inner diameter of boss 286mm
The depth of boss 39mm
The accuracy of rotation speed ±0.5 r |
