崩解时限测定仪
LB-812A型崩解时限测定仪,适用与固体制剂的片剂糖衣片,薄膜衣片,肠溶衣片,浸膏片和胶囊等药物进行崩解时限实验,仪器采用了先进的电路设计,温控数字显示,控温精度高,直观性能好,是国内领先水平的药物崩解时限测定仪器,所有的技术参数符合《中国药典2005版》的规定。
控温精度:37±0.3±℃
控温范围:0℃-45℃
吊篮上下往复距离:55±1mm
吊篮上升篮网至液面下:15mm
吊篮上下往复次数:30-32次/分
吊篮下降篮网至杯底:25mm
过热保护:60±5℃
LB-812A disintegration time limit tester
LB-812A applicable to disintegration time limit test of solid dosage forms of tablet,sugar coated pill, film pill, intestine resolved pill, paste immersed pill, capsule, etc. the tester used by advanced electrocircuit design. Temperature figures showed with hig-precision control, and smart visual performance, It is a leading drug disintegration time limit tester in domestic market. All the technical parameters in line with the “ Chinese pharmacopoeia 2005 edition”
The main technical parameters:
Precision in Constant Temperature 37±0.3℃
The Range of temperature control 0℃-45℃
Distance Hanging Basket Covers Vertically 55±1mm
Distance from Rising Basket Net to Liquid Level 15mm
Times of Hanging Basket Up and Down 30-32 times/min
Distance from Falling Basket Net to Bottom of Cup 25mm
Temperature of Overheating Protective Device 60±5℃
LB-2D 型智能崩解时限测定仪
LB-2D 型智能崩解时限测定仪,适用于固体制剂的片剂、糖衣片、薄膜衣片、肠溶衣片 、浸膏片和胶囊等药物进行崩解时限试验。仪器采用了国际高性能的单片机控制,实时对温度,时间自动监控监测报警,定时停机功能,恒温精度高,直观性好,是具有国内领先水平的药物崩解时限测定的仪器,本仪器各项技术指标均符合《中国药典2005版》规定的标准.
主要技术参数:
恒温精度:37±0.3℃
温控显示:自动数显
时钟定时范围:99.99小时、自动停机、报警
吊篮上下移动距离:55±1mm
吊篮上升篮网至液面下面:15mm
吊篮上下往复次数:30-32次/分
吊篮下降篮网至杯底:25mm
过热保护温度:60±5℃
LB-2D disintegration time limit tester
LB-2D applicable to disintegration time limit test of solid dosage forms of tablet,sugar coated pill, film pill, intestine resolved pill, paste immersed pill, capsule, etc. the tester used by the international high-performance single-chip control, automatic monitoring and alarming to temperature and time with real-time. As well as shutdown functions from time to time, constant temperature with high precision and smart intuitive. It is a leading drug disintegration time limit tester in domestic market.
The tester technical indicators are in line with the “ China pharmacopoeia 2005 version of ” the required standards.
Timing Range of Clock 0 – 999 minutes automatic stopping& alarming
