78X-6A片剂四用测定仪
78X-6A型片剂四用测定仪是我公司在原78X-2型片剂四用测定仪基础上创新设计的产品,该产品技术指标均符合《中国药典2005年》版规定。是比较理想的药检测试仪器。
二、 主要技术规格
崩解部分:
吊篮上下移动距离 55±2mm
吊篮上下往复次数 30~32次/分
平底烧杯容积 1000ml
平底烧杯数量: 2只
杯内水温 37± 0.3 ℃
吊篮上升篮网至液面距离 25mm
吊篮下降篮网至杯底距离 25mm
2. 溶出部分:
转速 25~200r.p.m
转速精度 ±1%转
篮旋转摆动幅度 ≤±1mm
浆叶旋转摆动幅度 ≤±1mm
球底烧杯容积 1000ml
球底烧杯数量 6只
3.脆碎部分:
轮鼓直径: Ø286±0.20mm
轮鼓深: 39±0.30mm
轮鼓数量: 2只
转速: 25转/分、100转停机
4. 硬度部分
被测药片最大直径 25mm
最大测试压力 200N
测试精度 5N
78X-6A four functions tablet tester is a new innovate designed production which is based on former model 78X-2 four functions tablet tester. All the tester technical indicators are in line with the "Chinese Pharmacopoeia 2005" version of the provision. It is an ideal drug testing equipment.
78X Series tablet tester is the best testing equipment for research units, universities, drug checking department and pharmaceutical company.
78X-2B片剂四用测定仪
78X-2B型片剂四用测定仪,是我公司开发的新产品,该仪器集药物片剂的硬度,脆碎度,溶出度和崩解度四种功能于一体.整机结构设计合理,性能稳定,操作方便,测试数据精确可靠,主要技术指标符合《中国药典2005版》的规定,广泛用于医药行业的科研,教学,药检所及各制药行业的质量管理部门和实验室.
二、 主要技术规格
崩解部分:
吊篮上下移动距离 55±2mm
吊篮上下往复次数 30~32次/分
平底烧杯容积 1000ml
平底烧杯数量: 2只
杯内水温 37± 0.3 ℃
吊篮上升篮网至液面距离 25mm
吊篮下降篮网至杯底距离 25mm
溶出部分:
转速 50、100、150、200r.p.m
转速精度 ±1%
转篮旋转摆动幅度 ≤±1mm
浆叶旋转摆动幅度 ≤±1mm
球底烧杯容积 1000ml
脆碎部分:
轮鼓直径: Ø286±0.20mm
轮鼓深: 39±0.30mm
轮鼓数量: 2只
转速: 25转/分、100转停机
环境温度: 1~35℃
环境相对湿度: ﹤85%
硬度部分
被测药片最大直径 25mm
最大测试压力 200N
测试精度 5N
78X-2B four functions tablet tester is a new innovate designed production which have four functions including test tablet’s hardness, friability, dissolution and disintegration. The tester structure designed with reason, performance with stability, easy to operate, test data with reliable and accurate. All the tester technical indicators are in line with the "Chinese Pharmacopoeia 2005" version of the provision. the tester is widely used by the pharmaceutical industry from research units, teaching, drug checking institution and quality control department as well as laboratory. The main technical specification the part of disintegrationDistance Hanging Basket Covers Vertically 55±2mm Times of Hanging Basket Up and Down 30-32 times/min the volume of flat-bottomed beaker 1000ml the number of flat-bottomed beaker 2 pieces the part of dissolutionThe speed of rotation 50,100,150,200 rpm The accuracy of rotary speed ±1% The volume of spherical support beaker 1000 ml the part of friabilityThe diameter of brake drum Ø286mm±0.20mm The depth of brake drum 39mm±0.30mm The number of brake drum The rotary speed 25r/min. 100r/min will be stopped the part of hardnessthe max. Diameter of testing drug 25mm the max. testing pressure 200N
the testing accuracy 5N
78X-2片剂四用测定仪
78X-2型片剂四用测定仪曾获上海市技术革新奖,它将药片的多种性能的测试综合在一台仪器上完成,可分别用于药片的硬度、脆碎度、崩解度和溶出度测试,适用与各制药厂车间的初级检测和医学院校的教学实验等。
技术参数:
被测药片最大直径 16mm
最大测试压力 200N
测试精度 10N
恒温精度 37±0.5℃
