MODEL ROD TYPE1 OUTPUT POWER2 DIODE BIAS VOLTAGE3 DRIVE CURRENT3
RBAG20-0.66C2 2 mm, YAG 20 W 12 VDC 0-38A (25A NOMINAL)
RBAG20-1C2 2 mm, YAG 35 W 18 VDC 0-38A (25A NOMINAL)
RBAG30-1C2 3mm, YAG 50 W 18 VDC 0-38A (25A NOMINAL)
1 Rod length is 63 mm with flat/flat faces and 0.6% Nd doping
2 Minimum 1064 nm multimode output in a short cavity (165 ± 5 mm, 0.75mCC HR/flat 80%R OC) CW oscillator, at a maximum 25A drive current, arrangement at delivery.
3 Required voltage at the pump head stated w/o consideration for inefficiencies in the electrical system. Your DC power supply should be oversized by 30% to allow for these inefficiencies.
其中的0.75mCC HR/flat 80%R OC cc和oc各是代表什么意思啊,是英文缩写吗?
谢谢! |
