Pulsed ns 532 Laser
Our 532-Q laser heads are just a few cm longer than the well known 1064-Q lasers. The frequency doubling is done with state of the art walk off compensation which leads to a conversion efficiency of more than 50% by just single pass through a non linear crystal. These 532-Q Lasers are well suited for LIDAR (light detection and ranging) as well as LIBS (Laser Induced Breakdown Spectroscopy) applications. We reached output powers up to 500 mW, but here you will receive a much stronger pulse to pulse timing jitter. More details can be found in the corresponding datasheets below. For different specifications, please contact us directly. We also develop customer specified laser systems.
Average Power [mW]
50
Pulse Energy [µJ]
>4
Peak Power [kW]
>2
Pulsewidth [ns]
~2
Reptition Rate [kHz]
0 - 20
Spectral longitudinal mode
Single mode
Spatial mode
TEM00
Pulse to puls jitter [% rms] at 10 kHz
<3
Beam diameter [µm]
~110
Divergency [mrad], full angle
~6
