组装、冲压、喷漆等专业词汇
Assembly line组装线
Layout布置图
Conveyer流水线物料板
Rivet table拉钉机
Rivet gun拉钉枪
Screw driver起子
Electric screw driver电动起子
Pneumatic screw driver气动起子
worktable 工作桌
OOBA开箱检查
fit together组装在一起
fasten锁紧(螺丝)
fixture 夹具(治具)
pallet栈板
barcode条码
barcode scanner条码扫描器
fuse together熔合
fuse machine热熔机
repair修理
operator作业员
QC品管
supervisor 课长
ME制造工程师
MT制造生技
cosmetic inspect外观检查
inner parts inspect内部检查
thumb screw大头螺丝
lbs. inch镑、英寸
EMI gasket导电条
front plate前板
rear plate后板
chassis 基座
bezel panel面板
power button电源按键
reset button重置键
Hi-pot test of SPS高源高压测试
Voltage switch of SPS
电源电压接拉键
sheet metal parts 冲件
plastic parts塑胶件
SOP制造作业程序
material check list物料检查表
work cell工作间
trolley台车
carton纸箱
sub-line支线
left fork叉车
production department生产部门
planning department企划部
QC Section品管科
stamping factory冲压厂
painting factory烤漆厂
molding factory成型厂
common equipment常用设备
uncoiler and straightener整平机
punching machine 冲床
robot机械手
hydraulic machine油压机
lathe车床
planer 'plein?刨床
miller铣床
grinder磨床
driller铣床
linear cutting线切割
electrical sparkle电火花
welder电焊机
staker=reviting machine铆合机
position职务
president董事长
general manager总经理
special assistant manager特助
factory director厂长
department director部长
deputy manager =vice manager副理
section supervisor课长
deputy section supervisor =vice section superisor副课长
group leader/supervisor组长
line supervisor线长
assistant manager助理
to move, to carry, to handle搬运
be put in storage入库
pack packing包装
to apply oil擦油
to file burr 锉毛刺
final inspection终检
to connect material接料
to reverse material 翻料
wet station沾湿台
Tiana天那水
cleaning cloth抹布
to load material上料
to unload material卸料
to return material/stock to退料
scraped 'skr?pid报废
scrape ..v.刮;削
deficient purchase来料不良
manufacture procedure制程
deficient manufacturing procedure制程不良
oxidation ' ksi'dei?n氧化
scratch刮伤
dents压痕
defective upsiding down抽芽不良
defective to staking铆合不良
embedded lump镶块
feeding is not in place送料不到位
stamping-missing漏冲
production capacity生产力
education and training教育与训练
proposal improvement提案改善
spare parts=buffer备件
forklift叉车
trailer=long vehicle拖板车
compound die合模
die locker锁模器
pressure plate=plate pinch压板
bolt螺栓
name of a department部门名称
administration/general affairs dept总务部
automatic screwdriver电动启子
thickness gauge厚薄规
gauge(or jig)治具
power wire电源线
buzzle蜂鸣器
defective product label不良标签
identifying sheet list标示单
screwdriver holder起子插座
pedal踩踏板
stopper阻挡器
flow board流水板
hydraulic handjack油压板车
forklift叉车
pallet栈板
glove(s)手套
glove(s) with exposed fingers割手套
thumb大拇指
forefinger食指
midfinger中指
ring finger无名指
little finger小指
band-aid创可贴
iudustrial alcohol工业酒精
alcohol container沾湿台
head of screwdriver起子头
sweeper扫把
mop拖把
vaccum cleaner吸尘器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
chain链条
jack升降机
production line流水线
chain链条槽
magnetizer加磁器
lamp holder灯架
to mop the floor拖地
to clean the floor扫地
to clean a table擦桌子
air pipe 气管
packaging tool打包机
packaging打包
missing part漏件
wrong part错件
excessive defects过多的缺陷
critical defect极严重缺陷
major defect主要缺陷
minor defect次要缺陷
not up to standard不合规格
dimension/size is a little bigger尺寸偏大(小)
cosmetic defect外观不良
slipped screwhead/slippery screw head螺丝滑头
slipped screwhead/shippery screw thread滑手
speckle斑点
mildewed=moldy=mouldy发霉
rust生锈
deformation变形
burr(金属)flash(塑件)毛边
poor staking铆合不良
excesssive gap间隙过大
grease/oil stains油污
inclusion杂质
painting peel off脏污
shrinking/shrinkage缩水
mixed color杂色
scratch划伤
poor processing 制程不良
poor incoming part事件不良
fold of pakaging belt打包带折皱
painting make-up补漆
discoloration羿色
water spots水渍
polishing/surface processing表面处理
exposed metal/bare metal金属裸露
lack of painting烤漆不到位
safety安全
quality品质
delivery deadline交货期
cost成本
engineering工程
die repair模修
enterprise plan = enterprise expansion projects企划
QC品管
die worker模工
production, to produce生产
equipment设备
to start a press开机
stop/switch off a press关机
classification整理
regulation整顿
cleanness清扫
conservation清洁
culture教养
qualified products, up-to-grade products良品
defective products, not up-to-grade products不良品
waste废料
board看板
feeder送料机
sliding rack滑料架
defective product box不良品箱
die change 换模
to fix a die装模
to take apart a die拆模
to repair a die修模
packing material包材
basket蝴蝶竺
plastic basket胶筐
isolating plate baffle plate; barricade隔板
carton box纸箱
to pull and stretch拉深
to put material in place, to cut material, to input落料
to impose lines压线
to compress, compressing压缩
character die字模
to feed, feeding送料
transportation运输
(be)qualfied, up to grade合格
not up to grade, not qualified不合格
material change, stock change材料变更
feature change 特性变更
evaluation评估
prepare for, make preparations for 准备
parameters参数
rotating speed, revolution转速
manufacture management制造管理
abnormal handling异常处理
production unit生产单位
lots of production生产批量
steel plate钢板
roll material卷料
operation procedure作业流程
to revise, modify修订
to switch over to, switch---to throw--over switching over切换
engineering, project difficulty
工程瓶颈
stage die工程模
automation自动化
to stake, staking, reviting铆合
add lubricating oil加润滑油
shut die架模
shut height of a die架模高度
analog-mode device类模器
die lifter举模器
argon welding氩焊
vocabulary for stamping
冲压常词汇
stamping, press冲压
punch press, dieing out press冲床
uncoiler & strainghtener整平机
feeder送料机
rack, shelf, stack料架
cylinder油缸
robot机械手
taker取料机
conveyer belt输送带
transmission rack输送架
top stop上死点
bottom stop下死点
one stroke一行程
inch寸动
to continue, cont.连动
to grip(material)吸料
location lump, locating piece, block stop 定位块
reset复位
smoothly顺利
dent压痕
scratch刮伤
deformation变形
filings铁削
to draw holes抽孔
inquiry, search for查寻
to stock, storage, in stock库存
receive领取
approval examine and verify审核
processing, to process加工
delivery, to deliver 交货
to return delivenry to.
to send delinery back
to retrn of goods退货
registration登记
registration card登记卡
to control管制
to put forward and hand in提报
safe stock安全库存
acceptance = receive验收
to notice通知
application form for purchase请购单
consume, consumption消耗
to fill in填写
abrasion磨损
reverse angle = chamfer倒角
character die字模
to collect, to gather收集
failure, trouble故障
statistics统计
demand and supply需求
career card履历卡
to take apart a die卸下模具
to load a die装上模具
to tight a bolt拧紧螺栓
to looser a bolt拧松螺栓
to move away a die plate移走模板
easily damaged parts易损件
standard parts标准件
breaking.(be)broken,(be)cracked 断裂
to lubricate润滑
common vocabulary for die engineering
模具工程常用词汇
die 模具
figure file, chart file图档
cutting die, blanking die冲裁模
progressive die, follow (-on)die
连续模
compound die复合模
punched hole冲孔
panel board镶块
to cutedges=side cut=side scrap切边
to bending折弯
to pull, to stretch拉伸
Line streching, line pulling线拉伸
engraving, to engrave刻印
upsiding down edges翻边
to stake铆合
designing, to design设计
design modification设计变化
die block模块
folded block折弯块
sliding block滑块
location pin定位销
lifting pin顶料销
die plate, front board模板
padding block垫块
stepping bar垫条
upper die base上模座
lower die base下模座
upper supporting blank上承板
upper padding plate blank上垫板
spare dies模具备品
spring 弹簧
bolt螺栓
document folder文件夹
file folder资料夹
to put file in order整理资料
spare tools location手工备品仓
first count初盘人
first check初盘复棹人
second count 复盘人
second check复盘复核人
equipment设备
waste materials废料
work in progress product在制品
casing = containerazation装箱
quantity of physical invetory second count 复盘点数量
quantity of customs count
会计师盘,点数量
the first page第一联
filed by accounting department for reference会计部存查
end-user/using unit(department)使用单位
summary of year-end physical inventory bills
年终盘点截止单据汇总表
bill name单据名称
This sheet and physical inventory list will be sent to accounting
department together (Those of NHK will be sent to financial
department)
本表请与盘点清册一起送会计部-(NHK厂区送财会部)
Application status records of year-end physical inventory List and
physical inventory card 年终盘点卡与清册使用-状况明细表
blank and waste sheet NO.
空白与作废单号
plate电镀
mold成型
material for engineering mold testing工程试模材料
not included in physical inventory不列入盘点
sample样品
incoming material to be inspected进货待验
description品名
steel/rolled steel钢材
material statistics sheet
物料统计明细表
meeting minutes会议记录
meeting type 会别
distribution department分发单位
location地点
chairman主席
present members出席人员
subject主题
conclusion结论
decision items决议事项
responsible department负责单位
pre-fixed finishing date预定完成日
approved by / checked by / prepared by核准/审核/承办
PCE assembly production schedule sheet
PCE组装厂生产排配表
model机锺
work order工令
revision版次
remark备注
production control confirmation生产确认
checked by初审
approved by核准
department部门
stock age analysis sheet
库存货龄分析表
on-hand inventory现有库存
available material良品可使用
obsolete material良品已呆滞
to be inspected or reworked
待验或重工
total合计
cause description原因说明
part number/ P/N 料号
type形态
item/group/class类别
quality品质
prepared by制表
notes说明
year-end physical inventory difference analysis sheet
年终盘点差异分析表
physical inventory盘点数量
physical count quantity帐面数量
difference quantity差异量
cause analysis原因分析
raw materials原料
materials物料
finished product成品
semi-finished product半成品
packing materials包材
good product/accepted goods/ accepted parts/good parts良品
defective product/non-good parts不良品
disposed goods处理品
warehouse/hub仓库
on way location在途仓
oversea location海外仓
spare parts physical inventory list备品盘点清单
spare molds location模具备品仓
skid/pallet栈板
tox machine自铆机
wire EDM线割
EDM放电机
coil stock卷料
sheet stock片料
tolerance工差
score=groove压线
cam block滑块
pilot导正筒
trim剪外边
pierce剪内边
drag form压锻差
pocket for the punch head挂钩槽
slug hole废料孔
feature die公母模
expansion dwg展开图
radius半径
shim(wedge)楔子
torch-flame cut火焰切割
set screw止付螺丝
form block折刀
stop pin定位销
round pierce punch=die button圆冲子
shape punch=die insert异形子
stock locater block定位块
under cut=scrap chopper清角
active plate活动板
baffle plate挡块
cover plate盖板
male die公模
female die母模
groove punch压线冲子
air-cushion eject-rod气垫顶杆
spring-box eject-plate弹簧箱顶板
bushing block衬套
insert 入块
club car高尔夫球车
capability能力
parameter参数
factor系数
phosphate皮膜化成
viscosity涂料粘度
alkalidipping脱脂
main manifold主集流脉
bezel斜视规
blanking穿落模
dejecting顶固模
demagnetization去磁;消磁
high-speed transmission高速传递
heat dissipation热传
rack上料
degrease脱脂
rinse水洗
alkaline etch龄咬
desmut剥黑膜
D.I. rinse纯水次
Chromate铬酸处理
Anodize阳性处理
seal封孔
revision版次
part number/P/N料号
good products良品
scraped products报放心品
defective products不良品
finished products成品
disposed products处理品
barcode条码
flow chart流程表单
assembly组装
stamping冲压
molding成型
spare parts=buffer备品
coordinate座标
dismantle the die折模
auxiliary fuction辅助功能
poly-line多义线
heater band 加热片
thermocouple热电偶
sand blasting喷沙
grit 砂砾
derusting machine除锈机
degate打浇口
dryer烘干机
induction感应
induction light感应光
response=reaction=interaction感应
ram连杆
edge finder巡边器
concave凸
convex凹
short射料不足
nick缺口
speck瑕??
shine亮班
splay 银纹
gas mark焦痕
delamination起鳞
cold slug冷块
blush 导色
gouge沟槽;凿槽
satin texture段面咬花
witness line证示线
patent专利
grit沙砾
granule=peuet=grain细粒
grit maker抽粒机
cushion缓冲
magnalium镁铝合金
magnesium镁金
metal plate钣金
lathe车
mill锉
plane刨
grind磨
drill铝
boring镗
blinster气泡
fillet镶;嵌边
through-hole form通孔形式
voller pin formality滚针形式
cam driver铡楔
shank摸柄
crank shaft曲柄轴
augular offset角度偏差
velocity速度
production tempo生产进度现状
torque扭矩
spline=the multiple keys花键
quenching淬火
tempering回火
annealing退火
carbonization碳化
alloy合金
tungsten high speed steel钨高速的
moly high speed steel钼高速的
organic solvent有机溶剂
bracket小磁导
liaison联络单
volatile挥发性
resistance电阻
ion离子
titrator滴定仪
beacon警示灯
coolant冷却液
crusher破碎机
模具工程类
plain die简易模
pierce die冲孔模
forming die成型模
progressive die连续模
gang dies复合模
shearing die剪边模
riveting die铆合模
pierce冲孔
forming成型(抽凸,冲凸)
draw hole抽孔
bending折弯
trim切边
emboss凸点
dome凸圆
semi-shearing半剪
stamp mark冲记号
deburr or coin压毛边
punch riveting冲压铆合
side stretch侧冲压平
reel stretch卷圆压平
groove压线
blanking下料
stamp letter冲字(料号)
shearing剪断
tick-mark nearside正面压印
tick-mark farside反面压印
冲压名称类
extension dwg展开图
procedure dwg工程图
die structure dwg模具结构图
material材质
material thickness料片厚度
factor系数
upward向上
downward向下
press specification冲床规格
die height range适用模高
die height闭模高度
burr毛边
gap间隙
weight重量
total wt.总重量
punch wt.上模重量
五金零件类
inner guiding post内导柱
inner hexagon screw内六角螺钉
dowel pin固定销
coil spring弹簧
lifter pin顶料销
eq-height sleeves=spool等高套筒
pin销
lifter guide pin浮升导料销
guide pin导正销
wire spring圆线弹簧
outer guiding post外导柱
stop screw止付螺丝
located pin定位销
outer bush外导套
模板类
top plate上托板(顶板)
top block上垫脚
punch set上模座
punch pad上垫板
punch holder上夹板
stripper pad脱料背板
up stripper上脱料板
male die公模(凸模)
feature die公母模
female die母模(凹模)
upper plate上模板
lower plate下模板
die pad下垫板
die holder下夹板
die set下模座
bottom block下垫脚
bottom plate下托板(底板)
stripping plate内外打(脱料板)
outer stripper外脱料板
inner stripper内脱料板
lower stripper下脱料板
零件类
punch冲头
insert入块(嵌入件)
deburring punch压毛边冲子
groove punch压线冲子
stamped punch字模冲子
round punch圆冲子
special shape punch异形冲子
bending block折刀
roller滚轴
baffle plate挡块
located block定位块
supporting block for location
定位支承块
air cushion plate气垫板
trimming punch切边冲子
stiffening rib punch = stinger 加强筋冲子
ribbon punch压筋冲子
reel-stretch punch卷圆压平冲子
guide plate定位板
sliding block滑块
sliding dowel block滑块固定块
active plate活动板
lower sliding plate下滑块板
upper holder block上压块
upper mid plate上中间板
spring box弹簧箱
spring-box eject-rod弹簧箱顶杆
bushing bolck衬套
cover plate盖板
guide pad导料块
塑件&模具相关英文
compre sion molding压缩成型
flash mold溢流式模具
plsitive mold挤压式模具
split mold分割式模具
cavity型控 母模
core模心 公模
taper锥拔
leather cloak仿皮革
shiver饰纹
flow mark流痕
welding mark溶合痕
post screw insert螺纹套筒埋值
self tapping screw自攻螺丝
striper plate脱料板
piston活塞
cylinder汽缸套
chip细碎物
handle mold手持式模具
移转成型用模具
encapsulation molding低压封装成型
射出成型用模具
two plate两极式(模具)
well type蓄料井
insulated runner绝缘浇道方式
hot runner热浇道
runner plat浇道模块
valve gate阀门浇口
band heater环带状的电热器
spindle阀针
spear head刨尖头
slag well冷料井
cold slag冷料渣
air vent排气道
h=0.02~0.05mm
w=3.2mm
L=3~5mm
welding line熔合痕
eject pin顶出针
knock pin顶出销
return pin回位销反顶针
sleave套筒
stripper plate脱料板
insert core放置入子
runner stripper plate浇道脱料板
guide pin导销
eject rod (bar)(成型机)顶业捧
subzero深冷处理
three plate三极式模具
runner system浇道系统
stress crack应力电裂
orientation定向
sprue gate射料浇口,直浇口
nozzle射嘴
sprue lock pin料头钩销(拉料杆)
slag well冷料井
side gate侧浇口
edge gate侧缘浇口
tab gate搭接浇口
film gate薄膜浇口
flash gate闸门浇口
slit gate缝隙浇口
fan gate扇形浇口
dish gate因盘形浇口
H=F=1/2t~1/5t
T=2.5~3.5mm
diaphragm gate隔膜浇口
ring gate环形浇口
subarine gate潜入式浇口
tunnel gate隧道式浇口
pin gate针点浇口
Φ0.8~1.0mm
Runner less无浇道
(sprue less)无射料管方式
long nozzle延长喷嘴方式
sprue浇口;溶渣
品质人员名称类
QC quality control 品质管理人员
FQC final quality control 终点品质管制人员
IPQC in process quality control 制程中的品质管制人员
OQC output quality control 最终出货品质管制人员
IQC incoming quality control 进料品质管制人员
TQC total quality control 全面质量管理
POC passage quality control 段检人员
QA quality assurance 质量保证人员
OQA output quality assurance 出货质量保证人员
QE quality engineering 品质工程人员
品质保证类
FAI first article inspection 新品首件检查
FAA first article assurance 首件确认
TVR tool verification report 模具确认报告
3B 3B 模具正式投产前确认
CP capability index 能力指数
CPK capability index of process 模具制程能力参数
SSQA standardized supplier quality 合格供应商品质评估
OOBA out of box audit 开箱检查
QFD quality function deployment 品质机能展开
FMEA failure model effectiveness analysis 失效模式分析
8 disciplines 8项回复内容
FA final audit 最後一次稽核
CAR corrective action request 改正行动要求
corrective action report 改正行动报告
FQC运作类
AQL Acceptable Quality Level 运作类允收品质水准
S/S Sample size 抽样检验样本大小
ACC Accept 允收
REE Reject 拒收
CR Critical 极严重的
MAJ Major 主要的
MIN Minor 轻微的
AOQ Average Output Quality 平均出厂品质
AOQL Average Output Quality Level 平均出厂品质
Q/R/S Quality/Reliability/Service 品质/可靠度服务
MIL-STD Military-Standard 军用标准
S I-S IV Special I-Special IV 特殊抽样水准等级
P/N Part Number 料号
L/N Lot Number 特采
AOD Accept On Deviation 特采
UAI Use As It 首件检查报告
FPIR First Piece Inspection Report 百万分之一
PPM Percent Per Million 批号
制程统计品管专类
SPC Statistical Process Control 统计制程管制
SQC Statistical Quality Control 统计品质管制
R Range 全距
AR Averary Range 全距平均值
UCL Upper Central Limit 管制上限
LCL Lower Central Limit 管制下限
MAX Maximum 最大值
MIN Minimum 最小值
GRR Gauge Reproducibility&Repeatability 量具之再制性及重测性判断量可靠与否
DIM Dimension 尺寸
DIA Diameter 直径
FREQ Frequency 频率
N Number 样品数
其它品质术语类
QCC Quality Control Circle 品质圈
QIT Quality Improvement Team 品质改善小组
PDCA Plan Do Check Action 计划 执行 检查 总结
ZD Zero Defect 零缺点
QI Quality Improvement 品质改善
QP Quality Policy 目标方针
TQM Total Quality Management 全面品质管理
MRB Material Reject Bill 退货单
LQL Limiting Quality Level 最低品质水准
RMA Return Material Audit 退料认可
QAN Quality Amelionrate Notice 品质改善活动
ADM Absolute Dimension Measuremat 全尺寸测量
QT Quality Target 品质目标
7QCTools 7 Quality Controll Tools 品管七大手法
通用之件类
ECN Engineering Change Notes 工程变更通知(供应商)
ECO Engineering Change Order 工程改动要求(客户)
PCN Process Change Notice 工序改动通知
PMP Product Management Plan 生产管制计划
SIP Specification In Process 制程检验规格
SOP Standard Operation Procedure 制造作业规范
IS Inspection Specification 成品检验规范
BOM Bill Of Material 物料清单
PS Package Specification 包装规范
SPEC Specification 规格
DWG Drawing 图面
系统文件类
QC Quality System 品质系统
ES Engineering Standarization 工程标准
CGOO China General PCE龙华厂文件
H Huston (美国)休斯敦
C Compaq (美国)康伯公司
C China 中国大陆
A Assembly 组装(厂)
S Stamping 冲压(厂)
P Painting 烤漆(厂)
I Intel 英特尔公司
T TAIWAN 台湾
IWS International Workman Standard 工艺标准
ISO International Standard Organization 国际标准化组织
GS General Specification 一般规格
CMCS C-China M-Manufact C-Compaq S-Stamping Compaq产品在龙华冲压厂制造作业规范
CQCA Q-Quality A-Assembly Compaq产品在龙华组装厂品管作业规范
CQCP P-Painting Compaq产品在龙华烤漆厂品管作业规范
部类
PMC Production & Material Control 生产和物料控制
PPC Production Plan Control 生产计划控制
MC Material Control 物料控制
ME Manafacture Engineering 制造工程部
PE Project Engineering 产品工程部
A/C Accountant Dept 会计部
P/A Personal & Administration 人事行政部
DC Document Center 资料中心
QE Quality Engineering 品质工程(部)
QA Quality Assurance 品质保证(处)
QC Quality Control 品质管制(课)
PD Product Department 生产部
LAB Labratry 实验室
IE Industrial Engineering 工业工程
R&D Research & Design 设计开发部
P Painting 烤漆(厂)
A Asssembly 组装(厂)
S Stamping 冲压(厂)
生产类
PCS Pieces 个(根,块等)
PRS Pairs 双(对等)
CTN Carton 卡通箱
PAL Pallet/skid 栈板
PO Purchasing Order 采购订单
MO Manufacture Order 生产单
D/C Date Code 生产日期码
ID/C Identification Code (供应商)识别码
SWR Special Work Request 特殊工作需求
L/N Lot Number 批号
P/N Part Number 料号
其它
OEM Original Equipment Manufacture 原设备制造
PCE Personal Computer Enclosure 个人电脑外设
PC Personal Computer 个人电脑
CPU Central Processing Unit 中央处理器
SECC SECC` 电解片
SGCC SGCC 热浸镀锌材料
NHK North of Hongkong 中国大陆
PRC People's Republic of China 中国大陆
U.S.A the United States of America 美国
A.S.A.P As Soon As Possible 尽可能快的
E-MAIL Electrical-Mail 电子邮件
N/A Not Applicable 不适用
QTY Quantity 数量
VS 以及
REV Revision 版本
JIT Just In Time 零库存
I/O Input/Output 输入/输出
OK Ok 好
NG Not Good 不行,不合格
C=0 Critical=0 极严重不允许
ESD Electry-static Discharge 静电排放
5S 希腊语 整理,整顿,清扫,清洁,教养
ATIN Attention 知会
CC Carbon Copy 副本复印相关人员
APP Approve 核准,认可,承认
CHK Check 确认
AM Ante Meridian 上午
PM Post Meridian 下午
CD Compact Disk 光碟
CD-ROM Compact Disk Read-Only Memory 只读光碟
FDD Floppy Disk Drive 软碟机
HDD Hard Disk Drive 碟碟机
REF Reference 仅供参考
CONN Connector 连接器
CAV Cavity 模穴
CAD Computer Aid Design 计算机辅助设计
ASS'Y Assembly 装配,组装
MAT'S Material 材料
IC Integrated Circuit 集成电路
T/P True Position 真位度
TYP Type 类型
WDR Weekly Delivery Requitement 周出货需求
C?T Cycle Time 制程周期
L/T Lead Time 前置时间(生产前准备时间)
S/T Standard Time 标准时间
P/M Product Market 产品市场
3C Computer,Commumcation,Consumer electronic's 消费性电子
5WIH When,Where,Who,What,Why,How to
5M Man,Machine,Material,Method,Measurement
4MIH Man,Materia,Money,Method,Time 人力,物力,财务,技术,时间(资源)
SQA Strategy Quality Assurance 策略品质保证
DQA Desigh Quality Assurance 设计品质保证
MQA Manufacture Quality Assurance 制造品质保证
SSQA Sales and service Quality Assurance 销售及服务品质保证
LRR Lot Rejeet Rate 批退率
BS Brain storming 脑力激荡
EMI Electronic Magnetion Inspect 高磁测试
FMI Frequency Modulatim Inspect 高频测试
B/M Boar/Molding(flat cable)
C/P Connector of PC
A/P Assembly
SPS Switching power supply 电源箱
DT Desk Top 卧式(机箱)
MT Mini-Tower 立式(机箱)
DVD Digital Vedio Disk
VCD Vdeio Compact Disk
LCD Liquid Crystal Display
CAD Computer AID Design
CAM Computer AID Manufacturing
CAE Computer AID Engineering
ABIOS Achanced Basic in put/output system 先进的基本输入/输出系统
CMOS Complemeruary Metoll Oxide Semiconductor 互补金属氧化物半导体
PDA Personal Digital Assistant 个人数字助理
ISA Industry Standard Architecture 工业标准体制结构
MCA Micro Channel Architecture 微通道结构
EISA Extended Industry Standard Architecture 扩充的工业标准结构
SIMM Single in-line memory module 单项导通汇流组件
DIMM Dual in-line Memory Module 双项导通汇流组件
LED Light-Emitting Diode 发光二级管
FMEA Failure Mode Effectivenes 失效模式分析
W/H Wire Harness 金属线绪束集组件
F/C Flat Calle 排线
PCB Printed Circuit Board 印刷电路板
CAR Correction Action Report 改善报告
NG Not Good 不良
WPR Weekly Delivery Requirement 周出货要求
PPM Parts Per Million 百万分之一
TPM Total Production Maintenance 全面生产保养
MRP Material Requiremcnt Planning 物料需计划
OC Operation System 作业系统
TBA To Be Design 待定,定缺
D/C Drawing Change
P/P Plans & Procedune
EMI Electrical-Music Industry 电子音乐工业
RFI Read Frequency Input 读频输入
MMC Maximum Material Condition
MMS Maximum Material Size
LMC Least Material Condition
LMS Least Material Size
模具技术用语
各种模具常用成形方式
accurate die casting 精密压铸
powder forming 粉末成形
calendaring molding 压延成形
powder metal forging 粉末锻造
cold chamber die casting 冷式压铸
precision forging 精密锻造
cold forging 冷锻
press forging 冲锻
compacting molding 粉末压出成形
rocking die forging 摇动锻造
compound molding 复合成形
rotary forging 回转锻造
compression molding 压缩成形
rotational molding 离心成形
dip mold 浸渍成形
rubber molding 橡胶成形
encapsulation molding 注入成形
sand mold casting 砂模铸造
extrusion molding 挤出成形
shell casting 壳模铸造
foam forming ?泡成形
sinter forging 烧结锻造
forging roll 轧锻
six sides forging 六面锻造
gravity casting 重力铸造
slush molding 凝塑成形
hollow(blow) molding 中空(吹出)成形
squeeze casting 高压铸造
hot chamber die casting 热室压铸
swaging 挤锻
hot forging 热锻
transfer molding 转送成形
injection molding 射出成形
warm forging 温锻
investment casting 精密铸造
matched die method 对模成形法
laminating method 被覆淋膜成形
low pressure casting 低压铸造
lost wax casting 脱蜡铸造
matched mould thermal forming 对模热成形模
各式模具分类用语
bismuth mold 铋铸模
landed plunger mold 有肩柱塞式模具
burnishing die 挤光模
landed positive mold 有肩全压式模具
button die 镶入式圆形凹模
loading shoe mold 料套式模具
center-gated mold 中心浇口式模具
loose detail mold 活零件模具
chill mold 冷硬用铸模
loose mold 活动式模具
clod hobbing 冷挤压制模
ouvering die 百叶窗冲切模
composite dies 复合模具
manifold die 分歧管模具
counter punch 反凸模
modular mold 组合式模具
double stack mold 双层模具
multi-cavity mold 多模穴模具
electroformed mold 电铸成形模
multi-gate mold 复式浇口模具
expander die 扩径模
offswt bending die 双折冷弯模具
extrusion die 挤出模
palletizing die 叠层模
family mold 反套制品模具
plaster mold 石膏模
blank through dies 漏件式落料模
porous mold 通气性模具
duplicated cavity plate 复板模
positive mold 全压式模具
fantail die 扇尾形模具
pressure die 压紧模
fishtail die 鱼尾形模具
profile die 轮廓模
flash mold 溢料式模具
progressive die 顺序模
gypsum mold 石膏铸模
protable mold 手提式模具
hot-runner mold 热流道模具
prototype mold 雏形试验模具
ingot mold 钢锭模
punching die 落料模
lancing die 切口模
raising(embossing) 压花起伏成形
re-entrant mold 倒角式模具
sectional die 拼合模
runless injection mold 无流道冷料模具
sectional die 对合模具
segment mold 组合模
semi-positive mold 半全压式模具
shaper 定型模套
single cavity mold 单腔模具
solid forging die 整体锻模
split forging die 拼合锻模
split mold 双并式模具
sprueless mold 无注道残料模具
squeezing die 挤压模
stretch form die 拉伸成形模
sweeping mold 平刮铸模
swing die 振动模具
three plates mold 三片式模具
trimming die 切边模
unit mold 单元式模具
universal mold 通用模具
unscrewing mold 退扣式模具
yoke type die 轭型模
模具厂常用之标准零配件
air vent vale 通气阀 anchor pin 锚梢
angular pin 角梢 baffle 调节阻板
angular pin 倾斜梢 baffle plate 折流档板
ball button 球塞套 ball plunger 定位球塞
ball slider 球塞滑块 binder plate 压板
blank holder 防皱压板 blanking die 落料冲头
bolster 上下模板 bottom board 浇注底板
bolster 垫板 bottom plate 下固定板
bracket 托架 bumper block 缓冲块
buster 堵口 casting ladle 浇注包
casting lug 铸耳 cavity 模穴(模仁)
cavity retainer plate 模穴托板 center pin 中心梢
clamping block 锁定块 coil spring 螺旋弹簧
cold punched nut 冷冲螺母 cooling spiral 螺旋冷却栓
core 心型 core pin 心型梢
cotter 开口梢 cross 十字接头
cushion pin 缓冲梢 diaphragm gate 盘形浇口
die approach 模头料道 die bed 型底
die block 块形模体 die body 铸模座
die bush 合模衬套 die button 冲模母模
die clamper 夹模器 die fastener 模具固定用零件
die holder 母模固定板 die lip 模唇
die plate 冲模板 die set 冲压模座
direct gate 直接浇口 dog chuck 爪牙夹头
dowel 定位梢 dowel hole 导套孔
dowel pin 合模梢 dozzle 辅助浇口
dowel pin 定位梢 draft 拔模锥度
draw bead 张力调整杆 drive bearing 传动轴承
ejection pad 顶出衬垫 ejector 脱模器
ejector guide pin 顶出导梢 ejector leader busher 顶出导梢衬套
ejector pad 顶出垫 ejector pin 顶出梢
ejector plate 顶出板 ejector rod 顶出杆
ejector sleeve 顶出衬套 ejector valve 顶出阀
eye bolt 环首螺栓 filling core 椿入蕊
film gate 薄膜形浇口 finger pin 指形梢
finish machined plate 角形模板 finish machined round plate 圆形模板
fixed bolster plate 固定侧模板 flanged pin 带凸缘?
flash gate 毛边形浇口 flask 上箱
floating punch 浮动冲头 gate 浇口
gate land 浇口面 gib 凹形拉紧?
goose neck 鹅颈管 guide bushing 引导衬套
guide pin 导梢 guide post 引导柱
guide plate 导板 guide rail 导轨
head punch 顶?冲头 headless punch 直柄冲头
heavily tapered solid 整体模蕊盒 hose nippler 管接头
impact damper 缓冲器 injection ram 压射柱塞
inlay busher 嵌入衬套 inner plunger 内柱塞
inner punch 内冲头 insert 嵌件
insert pin 嵌件梢 king pin 转向梢
king pin bush 主梢衬套 knockout bar 脱模杵
land 合模平坦面 land area 合模面
leader busher 导梢衬套 lifting pin 起模顶?
lining 内衬 locating center punch 定位中心冲头
locating pilot pin 定位导梢 locating ring 定位环
lock block 压块 locking block 定位块
locking plate 定位板 loose bush 活动衬套
making die 打印冲子 manifold block 歧管档块
master plate 靠模样板 match plate 分型板
mold base 塑胶模座 mold clamp 铸模紧固夹
mold platen 模用板 moving bolster 换模保持装置
moving bolster plate 可动侧模板 one piece casting 整体铸件
parallel block 平行垫块 paring line 分模线
parting lock set 合模定位器 pass guide 穴型导板
peened head punch 镶入式冲头 pilot pin 导?
pin gate 针尖浇口 plate 衬板
pre extrusion punch 顶挤冲头 punch 冲头
puncher 推杆 pusher pin 衬套梢
rack 机架 rapping rod 起模杆
re-entrant mold 凹入模 retainer pin 嵌件梢
retainer plate 托料板 return pin 回位梢
riding stripper 浮动脱模器 ring gate 环型浇口
roller 滚筒 runner 流道
runner ejector set 流道顶出器 runner lock pin 流道拉梢
screw plug 头塞 set screw 固定螺丝
shedder 脱模装置 shim 分隔片
shoe 模座之上下模板 shoot 流道
shoulder bolt 肩部螺丝 skeleton 骨架
slag riser 冒渣口 slide(slide core) 滑块
slip joint 滑配接头 spacer block 间隔块
spacer ring 间隔环 spider 模蕊支架
spindle 主轴 sprue 注道
sprue bushing 注道衬套 sprue bushing guide 注道导套
sprue lock bushing 注道定位衬套 sprue puller 注道拉料?
spue line 合模线 square key 方键
square nut 方螺帽 square thread 方螺纹
stop collar 限位套 stop pin 止动梢
stop ring 止动环 stopper 定位停止梢
straight pin 圆柱? stripper bolt 脱料螺栓
stripper bushing 脱模衬套 stripper plate 剥料板
stroke end block 行程止梢 submarine gate 潜入式浇口
support pillar 支撑支柱/顶出支柱 support pin 支撑梢
supporting plate 托板 sweep templete 造模刮板
tab gate 辅助浇口 taper key 推拔键
taper pin 拔锥梢/锥形梢 teeming 浇注
three start screw 三条螺纹 thrust pin 推力销
tie bar 拉杵 tunnel gate 隧道形浇口
vent 通气孔 wortle plate 拉丝模板
模具常用之工作机械
3D coordinate measurement 三次元量床 boring machine 搪孔机
cnc milling machine CNC铣床 contouring machine 轮廓锯床
copy grinding machine 仿形磨床 copy lathe 仿形车床
copy milling machine 仿形铣床 copy shaping machine 仿形刨床
cylindrical grinding machine 外圆磨床 die spotting machine 合模机
drilling machine ?孔机 engraving machine 雕刻机
engraving E.D.M. 雕模放置加工机 form grinding machine 成形磨床
graphite machine 石墨加工机 horizontal boring machine 卧式搪孔机
horizontal machine center 卧式加工制造中心 internal cylindrical machine 内圆磨床
jig boring machine 冶具搪孔机 jig grinding machine 冶具磨床
lap machine 研磨机 machine center 加工制造中心
multi model miller 靠磨铣床 NC drilling machine NC钻床
NC grinding machine NC磨床 NC lathe NC车床
NC programming system NC程式制作系统 planer 龙门刨床
profile grinding machine 投影磨床 projection grinder 投影磨床
radial drilling machine 旋臂?床 shaper 牛头刨床
surface grinder 平面磨床 try machine 试模机
turret lathe 转塔车床 universal tool grinding machine 万能工具磨床
vertical machine center 立式加工制造中心 wire E.D.M. 线割放电加工机
检验量测工具用语
autocollimator 自动准直机 bench comparator 比长仪
block gauge 块规 bore check 精密小测定器
calibration 校准 caliper gauge 卡规
check gauge 校对规 clearance gauge 间隙规
clinoretee 测斜仪 comparator 比测仪
cylinder square 圆筒直尺 depth gauge 测深规
dial indicator 针盘指示表 dial snap gauge 卡规
digital micrometer 数位式测微计 feeler gauge 测隙规
gauge plate 量规定位板 height gauge 测高规
inside calipers 内卡钳 inside micrometer 内分??卡
interferometer 干涉仪 leveling block 平台
limit gauge 限规 micrometer 测微计
mil 千分之一寸 monometer 压力计
morse taper gauge 莫氏锥度量规 nonius 游标卡尺
optical flat 光学平晶 optical parallel 光学平行
passimeter 内径仪 position scale 位置刻度
profile projector 轮廓光学投影仪 protractor 分角器
radius 半径 ring gauge 环规
sine bar 正弦量规 snap gauge 卡模
square master 直角尺 stylus 触针
telescopic gauge 伸缩性量规 working gauge 工作量规
模具钢材
alloy tool steel 合金工具钢 aluminium alloy 铝合金钢
bearing alloy 轴承合金 blister steel 浸碳钢
bonderized steel sheet 邦德防蚀钢板 carbon tool steel 碳素工具钢
clad sheet 被覆板 clod work die steel 冷锻模用钢
emery 金钢砂 ferrostatic pressure 钢铁水静压力
forging die steel 锻造模用钢 galvanized steel sheet 镀锌铁板
hard alloy steel 超硬合金钢 high speed tool steel 高速度工具钢
hot work die steel 热锻模用钢 low alloy tool steel 特殊工具钢
low manganese casting steel 低锰铸钢 marging steel 马式体高强度热处理钢
martrix alloy 马特里斯合金 meehanite cast iron 米汉纳铸钢
meehanite metal 米汉纳铁 merchant iron 市售钢材
molybdenum high speed steel 钼系高速钢 molybdenum steel 钼钢
nickel chromium steel 镍铬钢 prehardened steel 顶硬钢
silicon steel sheet 矽钢板 stainless steel 不锈钢
tin plated steel sheet 镀锡铁板 tough pitch copper 韧铜
troostite 吐粒散铁 tungsten steel ?钢
vinyl tapped steel sheet 塑胶覆面钢板
表面处理关连用语
age hardening 时效硬化 ageing 老化处理
air hardening 气体硬化 air patenting 空气韧化
annealing 退火 anode effect 阳极效应
anodizing 阳极氧化处理 atomloy treatment 阿托木洛伊表面
austempering 奥氏体等温淬火 austenite 奥斯田体/奥氏体
bainite 贝氏体 banded structure 条纹状组织
barrel plating 滚镀 barrel tumbling 滚筒打光
blackening 染黑法 blue shortness 青熟脆性
bonderizing 磷酸盐皮膜处理 box annealing 箱型退火
box carburizing 封箱渗碳 bright electroplating 辉面电镀
bright heat treatment 光辉热处理 bypass heat treatment 旁路热处理
carbide 炭化物 carburized case depth 浸碳硬化深层
carburizing 渗碳 cementite 炭化铁
chemical plating 化学电镀 chemical vapor deposition 化学蒸镀
coarsening 结晶粒粗大化 coating 涂布被覆
cold shortness 低温脆性 comemtite 渗碳体
controlled atmosphere 大气热处理 corner effect 锐角效应
creeping discharge 蠕缓放电 decarburization 脱碳处理
decarburizing 脱碳退火 depth of hardening 硬化深层
diffusion 扩散 diffusion annealing 扩散退火
electrolytic hardening 电解淬火 embossing 压花
etching 表面蚀刻 ferrite 肥粒铁
first stage annealing 第一段退火 flame hardening 火焰硬化
flame treatment 火焰处理 full annealing 完全退火
gaseous cyaniding 气体氧化法 globular cementite 球状炭化铁
grain size 结晶粒度 granolite treatment 磷酸溶液热处理
graphitizing 石墨退火 hardenability 硬化性
hardenability curve 硬化性曲线 hardening 硬化
heat treatment 热处理 hot bath quenching 热浴淬火
hot dipping 热浸镀 induction hardening 高周波硬化
ion carbonitriding 离子渗碳氮化 ion carburizing 离子渗碳处理
ion plating 离子电镀 isothermal annealing 等温退火
liquid honing 液体喷砂法 low temperature annealing 低温退火
malleablizing 可锻化退火 martempering 麻回火处理
martensite 马氏体/硬化铁炭 metallikon 金属喷镀法
metallizing 真空涂膜 nitriding 氮化处理
nitrocarburizing 软氮化 normalizing 正常化
oil quenching 油淬化 overageing 过老化
overheating 过热 pearlite 针尖组织
phosphating 磷酸盐皮膜处理 physical vapor deposition 物理蒸镀
plasma nitriding 离子氮化 pre-annealing 预备退火
precipitation 析出 precipitation hardening 析出硬化
press quenching 加压硬化 process annealing 制程退火
quench ageing 淬火老化 quench hardening 淬火
quenching crack 淬火裂痕 quenching distortion 淬火变形
quenching stress 淬火应力 reconditioning 再调质
recrystallization 再结晶 red shortness 红热脆性
residual stress 残留应力 retained austenite 残留奥
rust prevention 防蚀 salt bath quenching 盐浴淬火
sand blast 喷砂处理 seasoning 时效处理
second stage annealing 第二段退火 secular distortion 经年变形
segregation 偏析 selective hardening 部分淬火
shot blast 喷丸处理 shot peening 珠击法
single stage nitriding 等温渗氮 sintering 烧结处理
soaking 均热处理 softening 软化退火
solution treatment 固溶化热处理 spheroidizing 球状化退火
stabilizing treatment 安定化处理 straightening annealing 矫直退火
strain ageing 应变老化 stress relieving annealing 应力消除退火
subzero treatment 生冷处理 supercooling 过冷
surface hardening 表面硬化处理 temper brittleness 回火脆性
temper colour 回火颜色 tempering 回火
tempering crack 回火裂痕 texture 咬花
thermal refining 调质处理 thermoechanical treatment 加工热处理
time quenching 时间淬火 transformation 变态
tufftride process 软氮化处理 under annealing 不完全退火
vacuum carbonitriding 真空渗碳氮化 vacuum carburizing 真空渗碳处理
vacuum hardening 真空淬火 vacuum heat treatment 真空热处理
vacuum nitriding 真空氮化 water quenching 水淬火
wetout 浸润处理
焊接用语
acetylene 乙炔 ampere 电流安培
angle welding 角焊 arc 电弧
argon arc welding 氩弧焊接 bare electrode 光熔接条
butt welding 对接焊接 camber 电弧弯曲
cascade 阶叠熔接法 clad weld 被覆熔接
crator 焊疤 excess metal 多余金属
filler rod 焊条 fillet weld 填角焊接
gas shield 气体遮蔽 groove welding 起槽熔接
hand face shield 手握面罩 hard facing 硬表面堆焊
jig welding 工模焊接 laser beam welding 雷射光焊接
metal electrode insert gas welding MIG熔接 nugget 点焊熔核
overlaying 堆焊 peening of welding 珠击熔接法
plug welding 塞孔熔接 positioned welding 正向熔接
pressure welding 压焊 propane gas cutting 丙烷气切割
pure nickel electrode 纯镍熔接条 reinforcement of weld 加强焊接
resist 抗蚀护膜 root running 背面熔接
seam 焊缝 seaming 接合
seam welding 流缝熔接 series seam welding 串联缝熔接
skip welding process 跳焊法 spark 火花
spot welding 点焊接 stitch welding 针角焊接
stud arc welding 电弧焊接 under laying 下部焊层
void 焊接空隙 weld flow mark 焊接流痕
weld flush 焊缝凸起 weld line 焊接纹
weld mark 焊接痕 weld penetration 熔接透入
weld zone 焊接区 welding 焊接
welding bead 焊接泡 welding direction 焊接方向
welding distortion 焊接变形 welding flux 焊剂
welding ground 电熔接地 welding interval 焊接周期
welding stress 熔接应变 welding torch 熔接气炬
射出成形关联用语
activator 活化剂 bag moulding 气胎施压成形
bonding strength 黏合强度 breathing 排气
caulking compound 填隙料 cell 气孔
cold slug 半凝式射出 colorant 著色剂
color matching 调色 color masterbatch 色母料
compound 混合料 copolymer 共聚合体
cull 残料废品 cure 凝固化
cryptometer 不透明度仪 daylight 开隙
dry cycle time 空料试车周期时间 ductility 延性
elastomer 弹性体 extruded bead sealing 压出粒涂层法
feed 供料 filler 充填剂
film blowing 薄膜吹制法 floating platen 活动模板
foaming agent 发泡剂 gloss 光泽
granule 颗粒料 gunk 料斗
hot mark 热斑 hot stamping 烫印
injection nozzle 射出喷嘴 injection plunger 射出柱塞
injection ram 射出冲柱 isomer 同分异构物
kneader 混合机 leveling agent 匀涂剂
lubricant 润滑剂 matched die method 配合成形法
mould clamping force 锁模力 mould release agent 脱模剂
nozzle 喷嘴 oriented film 取向薄膜
parison 吹气成形坏料 pellet 粒料
plasticizer 可塑剂 plunger 压料柱塞
porosity 孔隙率 post cure 後固化
premix 预混料 purging 清除
reciprocating screw 往复螺杆 resilience 回弹性
resin injection 树脂射出法 rheology 流变学
sheet 塑胶片 shot 注射
shot cycle 射出循环 slip agent 光滑剂
take out device 取料装置 tie bar 拉杆
toggle type mould clamping system 肘杆式锁模装置
torpedo spreader 形分流板 transparency 透明性
void content 空洞率
塑胶原料
acrylic 压克力 casein 酪素
cellulose acetate 醋酸纤维素CA cellulose acetate butyrate 醋酸丁酸纤维素CAB
composite material 复合材料 cresol resin 甲酚树脂CF
dially phthalate 苯二甲酸二烯丙酯 disperse reinforcement 分散性强化复合材料
engineering plastics 工程塑胶 epoxy resin 环氧树脂EP
ethyl cellulose 乙基纤维素 ethylene vinylacetate copolymer 乙烯-醋酸乙烯EVA
ethylene-vinlacetate copolyme 醋酸乙烯共聚物EVA expanded polystyrene
?泡聚苯乙烯EPS
fiber reinforcement 纤维强化热固性/纤维强化复合材料
high density polyethylene 高密度聚乙烯HDPE
high impact polystyrene 高冲击聚苯乙烯HIPS
high impact polystyrene rigidity 高冲击性聚苯乙烯
low density polyethylene 低密度聚乙烯LDPE melamine resin 三聚氰胺酚醛树脂MF
nitrocellulose 硝酸纤维素 phenolic resin 酚醛树脂
plastic 塑胶 polyacrylic acid 聚丙烯酸PAP
polyamide 耐龙PA polybutyleneterephthalate 聚对苯二甲酸丁酯PBT
polycarbonate 聚碳酸酯PC polyethyleneglycol 聚乙二醇PFG
polyethyleneoxide 聚氧化乙烯PEO polyethyleneterephthalate 聚乙醇对苯PETP
polymetylmethacrylate 聚甲基丙烯酸甲酯PMMA polyoxymethylene 聚缩醛POM
polyphenylene oxide 聚硫化亚苯 polyphenyleneoxide 聚苯醚PPO
polypropylene 聚丙烯PP polystyrene 聚苯乙烯PS
polytetrafluoroethylene 聚四氟乙烯PTFE polytetrafluoroethylene 聚四氟乙烯
polythene 聚乙烯PE polyurethane 聚氨基甲酸酯PU
polyvinylacetate 聚醋酸乙烯PVAC polyvinylalcohol 聚乙烯醇PVA
polyvinylbutyral 聚乙烯醇缩丁醛PVB polyvinylchloride 聚氯乙烯PVC
polyvinylfuoride 聚氟乙烯PVF polyvinylidenechloride 聚偏二氯乙烯PVDC
prepolymer 预聚物 silicone resin 矽树脂
thermoplastic 热塑性 thermosetting 热固性
thermosetting plastic 塑胶 unsaturated polyester 不饱和聚酯树脂
成形不良用语
aberration 色差 atomization ?化
bank mark ?料纹 bite 咬入
blacking hole 涂料孔(铸疵) blacking scab 涂料疤
blister 起泡 blooming 起霜
blow hole 破孔 blushing 泛白
body wrinkle 侧壁皱纹 breaking-in 冒口带肉
bubble 膜泡 burn mark 糊斑
burr 毛边 camber 翘曲
cell 气泡 center buckle 表面中部波皱
check 细裂痕 checking 龟裂
chipping 修整表面缺陷 clamp-off 铸件凹痕
collapse 塌陷 color mottle 色斑
corrosion 腐蚀 crack 裂痕
crazing 碎裂 crazing 龟裂
deformation 变形 edge 切边碎片
edge crack 裂边 fading 退色
filler speak 填充料斑 fissure 裂纹
flange wrinkle 凸缘起皱 flaw 刮伤
flow mark 流痕 galling 毛边
glazing 光滑 gloss 光泽
grease pits 污斑 grinding defect 磨痕
haircrack 发裂 haze 雾度
incrustation 水锈 indentation 压痕
internal porosity 内部气孔 mismatch 偏模
mottle 斑点 necking 缩颈
nick 割痕 orange peel 橘皮状表面缺陷
overflow 溢流 peeling 剥离
pit 坑 pitting corrosion 点状腐蚀
plate mark 模板印痕 pock 麻点
pock mark 痘斑 resin streak 树脂流纹
resin wear 树脂脱落 riding 凹陷
sagging 松垂 saponification 皂化
scar 疤痕 scrap 废料
scrap jam 废料阻塞 scratch 刮伤/划痕
scuffing 深冲表面划伤 seam 裂痕
shock line 模口挤痕 short shot 充填不足
shrinkage pool 凹孔 sink mark 凹痕
skin inclusion 表皮摺叠 straightening 矫直
streak 条状痕 surface check 表面裂痕
surface roughening 橘皮状表皮皱摺 surging 波动
sweat out 冒汗 torsion 扭曲
warpage 翘曲 waviness 波痕
webbing 熔塌 weld mark 焊痕
whitening 白化 wrinkle 皱纹
模具常用刀具与工作法用语
adjustable spanner 活动扳手 angle cutter 角铣刀
anvil 铁? arbour 心轴
backing 衬垫 belt sander 带式打磨机
buffing 抛光 chamfering machine 倒角机
chamfering tool 去角刀具 chisel 扁錾
chuck 夹具 compass 两角规
concave cutter 凹面铣刀 convex cutter 凸形铣刀
cross joint 十字接头 cutting edge clearance 刃口余隙角
drill stand 钻台 edge file 刃用锉刀
file 锉刀 flange joint 凸缘接头
grinder 砂轮机 hammer 铁锤
hand brace 手摇钻 hatching 剖面线
hexagon headed bolt 六角头螺栓 hexagon nut 六角螺帽
index head 分度头 jack 千斤顶
jig 治具 kit 工具箱
lapping 研磨 metal saw 金工锯
nose angle 刀角 pinchers 钳子
pliers 铗钳 plug 柱塞头
polisher 磨光器 protable driller 手提钻孔机
punch 冲头 sand paper 砂纸
scraper 刮刀 screw driver 螺丝起子
scribing 划线 second out file 中纹锉
spanner 扳手 spline broach 方栓槽拉刀
square 直角尺 square sleeker 方形镘刀
square trowel 直角度 stripping 剥离工具
T-slot T形槽 tool for lathe 车刀
tool point angle 刀刃角 tool post 刀架
tosecan 划线盘 trimming 去毛边
waffle die flattening 压纹效平 wiper 脱模钳
wrench 螺旋扳手
电脑关联用语
3D modeling 三次元模拟 access 通路
animation 卡通影片 application 应用
board 基板 bug 故障
bus 汇流排 CAD 电脑辅助设计
CAE 电脑辅助工程分析 CAM 电脑辅助制造
cassette 卡座 color display 彩色显示器
command 指令 communication 通信
compact 精简小型 computer 电脑
copy 复制 cursor 游标
curve modeling 曲面模拟 database 资料库
design 设计 digitizing 数位化
disk 磁碟 dot 点
eyelet 眼孔 floppy 磁碟片
format 格式化 graphic 圆解
hardware 硬体 honeycomb 蜂巢
interface 界面 know how 秘诀
laser printer 雷射印表机 lay out 布置
memory 记忆 memory swap 交换记忆
microprocessor 微处理器 modeling 造型
module 模组 monitor 萤幕
mouse 滑鼠 need 需求
network 网路 new version 新版
on line 上线中 option 选择
PC 个人电脑 plotter 绘图机
program 程式 scanning 扫描
simulation 模拟 software 软体
solid model 实体模型 system 系统
tape 磁带 terminal 终端机
texture 构造 trim 修边
venter 排气风扇 word processor 文书处理器
各种冲模加工关连用语
barreling 滚光加工 belling 压凸加工
bending 弯曲加工 blanking 下料加工
bulging 撑压加工 burring 冲缘加工
cam die bending 凸轮弯曲加工 caulking ?合加工
coining 压印加工 compressing 压缩加工
compression bending 押弯曲加工 crowning 凸面加工
curl bending 卷边弯曲加工 curling 卷曲加工
cutting 切削加工 dinking 切断蕊骨
double shearing 叠板裁断 drawing 引伸加工
drawing with ironing 抽引光滑加工 embossing 浮花压制加工
extrusion 挤制加工 filing 锉削加工
fine blanking 精密下料加工 finish blanking 光制下料加工
finishing 精整加工 flanging 凸缘加工
folding 折边弯曲加工 folding 摺叠加工
forming 成形加工 impact extrusion 冲击挤压加工
indenting 压痕加工 ironing 引缩加工
knurling 滚花 lock seaming 固定接合
louvering 百叶窗板加工 marking 刻印加工
necking 颈缩加工 notching 冲口加工
parting 分断加工 piercing 冲孔加工
progressive bending 连续弯曲加工 progressive blanking 连续下料加工
progressive drawing 连续引伸加工 progressive forming 连续成形加工
reaming 铰孔加工 restriking 二次精冲加工
riveting ?接加工 roll bending 滚筒弯曲加工
roll finishing 滚压加工 rolling 压延加工
roughing 粗加工 scrapless machining 无废料加工
seaming 折弯重叠加工 shaving 缺口修整加工
shearing 切断加工 sizing 精压加工/矫正加工
slitting 割缝加工 spinning 卷边?接
staking ?固 stamping 锻压加工
swaging 挤锻压加工 trimming 整缘加工
upsetting 锻粗加工 wiring 抽线加工
冲压机械及周边关连用语
back shaft 支撑轴 blank determination 胚料展开
bottom slide press 下传动式压力机 board drop hammer 板落锤
brake 煞车 buckle 剥砂面
camlachie cramp 铸包 casting on flat ?合
chamotte sand 烧磨砂 charging hopper 加料漏斗
clearance 间隙 closed-die forging 合模锻造
clump 夹紧 clutch 离合器
clutch brake 离合器制动器 clutch boss 离合器轮壳
clutch lining 离合器覆盖 coil car 带卷升降运输机
coil cradle 卷材进料装置 coil reel stand 钢材卷料架
column 圆柱 connection screw 连杆调节螺钉
core compound 砂心黏结剂 counter blow hammer 对击锻锤
cradle 送料架 crank 曲柄轴
crankless 无曲柄式 cross crank 横向曲轴
cushion 缓冲 depression 外缩凹孔
dial feed 分度送料 die approach 模口角度
die assembly 合模 die cushion 模具缓冲垫
die height 冲压闭合高度 die life 模具寿命
die opening 母模逃孔 die spotting press 调整冲模用压力机
double crank press 双曲柄轴冲床 draght angle 逃料倾斜角
edging 边锻伸 embedded core 加装砂心
feed length 送料长度 feed level 送料高度
filling core 埋入砂心 filling in 填砂
film play 液面花纹 fine blanking press 精密下料冲床
forging roll 辊锻机 finishing slag 炼後熔渣
fly wheel 飞轮 fly wheel brake 飞轮制动器
foot press 脚踏冲床 formboard 进模口板
frame 床身机架 friction 摩擦
friction brake 摩擦煞车 gap shear 凹口剪床
gear 齿轮 gib 滑块引导部
gripper 夹具 gripper feed 夹持进料
gripper feeder 夹紧传送装置 hammer 槌机
hand press 手动冲床 hand rack pinion press 手动齿轮齿条式冲床
hand screw press 手动螺旋式冲床 hopper feed 料斗送料
idle stage 空站 inching 微调尺寸
isothermal forging 恒温锻造 key clutch 键槽离合器
knockout 脱模装置 knuckle mechanic 转向机构
land 模具直线刀面部 level 水平
loader 供料器 unloader 卸料机
loop controller 闭回路控制器 lower die 下模
micro inching device 微寸动装置 microinching equipment 微动装置
motor 马达 moving bolster 活动工作台
notching press 冲缺口压力机 opening 排料逃孔
overload protection device 防超载装置 pinch roll 导正滚轮
pinion 小齿轮 pitch 节距
pressfit 压入 progressive 连续送料
pusher feed 推杆式送料 pusher feeder 料片押片装置
quick die change system 快速换模系统 regrinding 再次研磨
releasing 松释动作 reversed blanking 反转下料
robot 机器人 roll forming machine 辊轧成形
roll forming machine 辊轧成形机 roll release 脱辊
roller feed 辊式送料 roller leveler 辊式矫直机
rotary bender 卷弯成形机 safety guard 安全保护装置
scrap cutter 废料切刀 scrap press 废料冲床
seamless forging 无缝锻造 separate 分离
shave 崩砂 shear angle 剪角
sheet loader 薄板装料机 shot 单行程工作
shrinkage fit 收缩配合 shut height 闭合高度
sieve mesh 筛孔 sintering of sand 铸砂烧贴
slide balancer 滑动平衡器 slug hole 逃料孔
spin forming machine 旋压成形机 spotting 合模
stack feeder 堆叠拨送料机 stickness 黏模性
straight side frame 冲床侧板 stretcher leveler 拉伸矫直机
strip feeder 料材送料装置 stripping pressure 弹出压力
stroke 冲程 take out device 取料装置
toggle press 肘杆式压力机 transfer 传送
transfer feed 连续自动送料装置 turrent punch press 转塔冲床
two speed clutch 双速离合器 uncoiler 闭卷送料机
unloader 卸载机 vibration feeder 振动送料机
wiring press 嵌线卷边机
线切割放电加工关连用语
abnormal glow 不规则辉光放电 arc discharge 电弧放电
belt 皮带 centreless 无心
chrome bronze 铭铜 clearance angle 後角
corner shear drop 直角压陷 deflection 桡曲度
discharge energy 放电能量 dressing 修整
dwell 保压 flange 凸缘
gap 间隙 graphite 石墨
graphite contraction allowance 电极缩小余量 graphite holder 电极夹座
hair crack 发裂 horn 电极臂
jump 跳刀 magnetic base 磁性座
master graphite 标准电极 pipe graphite 管状电极
pulse 脉冲 rib working 肋部加工
roller electrode 滚轮式电极 rotary surface 旋转面
shank 柄部 sharp edge 锐角部
tough bronze 韧铜 traverse 摇臂
tungsten bronze ?青铜 waviness 波形起伏
work 工件 working allowance 加工余量
working dischard 加工废料
锻铸造关连用语
accretion 炉瘤 acid converter 酸性转炉
acid lining cupola 酸性熔铁炉 acid open-hearth furnace 酸性平炉
aerator 松砂机 air set mold 常温自硬铸模
airless blasting cleaning 离心喷光 all core molding 集合式铸模
all round die holder 通用模座 assembly mark 铸造合模记号
back pouring 补浇注 backing sand 背砂
base bullion 粗金属锭 base permeability 原砂透气度
belling 压凸 billet 坏料
bleed 漏铸 blocker 预锻模膛
blocking 粗胚锻件 blow hole 铸件气孔
board drop hammer 板落锤 bottom pour mold 底浇
bottom pouring 底注 boxless mold 脱箱砂模
break-off core 缩颈砂心 brick molding 砌箱造模法
buckle 剥砂面 camber 错箱
camlachie cramp 铸包 cast blade 铸造叶片
casting flange 铸造凸缘 casting on flat 水平铸造
cleaning of casting 铸件清理 closed-die forging 合模锻造
core compound 砂心黏结剂 core template 砂心模板
core vent 砂蕊排气孔 corner gate 压边浇口
counter blow hammer 对击锻造 counter lock 止口镶嵌方式
depression 外缩凹孔 die approach 模口角度
draw out 锻造拔长 draw plate 起模板
draw spike 起模长针 dummying 预锻
embedded core 加装砂心 erosion 冲砂
fettling 铸件清理 filling core 埋入砂心
filling in 填砂 film play 液面花纹
finishing slag 炼後熔渣 flash gutter 锻模飞边槽
flask molding 砂箱造模 forging roll 辊锻机
formboard 进模口板 gutter 锻模飞边槽
hammer man 锻工 heading machine 顶镦机
impacter 卧式锻造机 inblock cast 整体铸造
ingot 铸锭 ingot blank 铸坯
inlay casting 镶铸法 investment casting 失模铸造
isothermal forging 恒温锻造 loose piece 木模活块
molding pit 铸模地坑 pouring process 浇注法
recasting 重铸 roll forging 轧锻
rolled surface 轧制表面 rough sand 粗砂
roughing forge 粗锻 sand crushing 塌箱
shave 崩砂 shrinkage fit 收缩配合
shut height 闭合高度 sieve mesh 筛孔
sintering of sand 铸砂烧贴 slag 熔渣
slag inclusion 夹渣 stickness 黏模性
strip layout 带状胚料排样法 tap casting 顶注
top gate 顶注浇口 unworked casting 不加工铸件
upender 翻转装置 upending 顶锻
uphill casting 底铸 white cast iron 白口铸件
模具加工方法
barrel 滚筒(加工) bending 波纹加工
broaching 拉刀切削 centering 定中心
cutting 切削 cylindrical lathe cutting 外圆车削
electric discharge machine 放电加工 electrolytic grinding 电解研磨
embossing 压花加工 facing 面车削
filing 锉刀修润 hand finishing 手工修润
hemming 卷边加工 hobbing 滚齿加工
joggling 摇动加工 lapping 抛光/研磨修润
laser beam machining 雷射加工 lathe cutting 车床车削
planning 刨削加工 polishing 抛亮光
reaming 铰孔修润 rough machining 粗切削
rounding 圆形加工 sawing 锯削
scaling 清除钢碇缺陷 shaping 成形加工
skiving 表面研磨 slotting 切缝切削
taper turning 锥度车削 thread cutting 螺纹切削
ultrasonic machining 超音波加工 up cut milling 逆铣加工
学理实验与试验用语
air permeability test 透气性试验 austenitic steel 沃斯田铁钢
brinell hardness 布耐内尔硬度 brinell hardness test 布氏硬度试验
charpy impact test 夏比冲击试验 conical cup test 圆锥杯突试验
cup flow test 杯模式流动度试验 dart drop impact test 落锤冲击试验
Elmendorf test 埃罗门多撕裂强度试验 environmental stress cracking test
环境应力龟裂试验
ericessen test 埃留伸薄板拉伸试验 falling ball impact test 落球冲击试验
fatigue test 疲劳试验 ferrite 纯铁体
gantt chart 甘特图 heat cycle test 热循环试验
histogram 柱状图 hot bend test 热弯试验
izod impact test 埃左德冲击试验 loop tenacity 环结强度
martens heat distortion temperature test 马顿斯耐热试验
martensite 马氏体 mullen bursting strength tester 密廉式破裂强度试验机
nol ring test 诺尔环试验 normal distribution 常态分配
ozone resistance test 抗臭氧试验 pareto diagram 柏拉图
peeling test 剥离试验 pinhole test 针孔试验机
rattler test 磨耗试验 rockweel hardness test 洛氏硬度试验
rockweel hardness 洛氏威尔硬度 rolinx process 罗林克斯射出压缩成形法
rossi-peakes flow test 罗西皮克斯流动试验 sampling inspection 抽样检查
scratch hardness 抗刮硬度 shore hardness 萧氏硬度
spiral flow test 螺旋流动试验 surface abrasion test 表面磨耗试验
taber abraser 泰伯磨耗试验机 tensile impact test 拉伸冲击试验
tensile strength 抗拉强度 tension test 张力试验
thermal shock test 冷热剧变试验 torsion test 扭曲试验
ubbelohde viscometer 乌别洛德黏度计 vicat indentation test 维卡针压陷试验
Vickers hardness test 维氏硬度试验 warpage test 翘曲试验
weatherometer 人工老化试验机 weissenberg effect 威森伯格回转效应
砂轮用语
abrasive 砂轮 Al2O3 氧化铝
balance 平衡 bond 结合
borazon 氧化硼立方晶 buffing wheel 抛光布轮
diamond 钻石 dresser 砂轮整修机
dressing 修整 endless grinding belt 循环式研磨带
finishing allowance 加工余量 grain 磨粒
grinding disc 研磨盘 jamp up 孔眼堵塞
mesh 网筛目 parameter 参数
resinoid grinding wheel 半树脂型砂轮 slitting 切缝量
vitrified 陶瓷的 wheel 旋转
机械设计及周边其他用语
assembly drawing 装配图 auto tool change cycle 自动换刀时间周期
beam 横梁 bending moment 弯矩
bending stress 弯曲应力 bottoming 底靠
buckling 纵弯曲 chamfering 去角斜切
channel 凹槽 chattering 颤动
check point 查核点 chip 切屑
chip conveyor 排屑输送机 coefficient of friction 摩擦系数
compact 小型的 cooling pipe 冷却管
coupon 试样胚 deflection 挠曲量
distortion 扭曲变形 draft taper 拔模锥度
draw out 拉拔 fit tolerance 配合公差
flexible rigidity 弯曲刚性 gas vent 气孔
hatching 剖面线 heater cooler 加热器冷却装置
hook cavity 钩穴 inching 寸动
lug 凸缘 maintenance 维修保固
metallurgy 冶金学 notch effect 切口效果
out of roughness 真圆度 performance 动作性能
pit 坑 plane strain 倒角应力
plug mill 蕊棒轧管机
repeated load 重覆载荷
riveted joint ?钉接合
sand paper 砂纸
shift 偏移
shrink fit 热压配合
shrinkage hole 缩孔
sinking 凹陷
sketch 草图
spalling 剥落
straightness 直度
submarine 深陷式
surface roughness 表面粗度
tapping 攻螺丝
thermocouple 热电耦
torsion load 扭转载荷
toughness 韧性
tracing 描图
under cut 凹割
3D modeling 三次元模拟
aberration 色差
abrasive 砂轮
access 通路
account 帐户
accretion 炉瘤
acid converter 酸性转炉
acid open-hearth furnance 酸性平炉
activator 活化剂
acetylene 乙炔
aerator 松砂机
after service 售後服务
age hardening 时效硬化
ageing 老化处理
air hardening 气体硬化
airless plasting cleaning 离心喷光
air patenting 空气韧化
air set mold 常温自硬铸模
air vent valve 通气阀
allround die holder 通用模型
amendment 修正
ampere 电流安培
anchor pin 锚梢
angle cutter 角铣刀
angle welding 角焊
angular pin 角梢
angular pin 倾斜梢
animation 卡通影片
anode effect 阳极效应
annealing 退火
