Fujitsu 10Gb/s 1550nm EA-Modulated Integrated DFB Laser
Modulator Integrated DFB Laser Diode Module
CW operation of DFB laser section
Modulation voltage applied only to modulator section
High speed butterfly package with GPO connection
Built-in optical isolator, monitor photodiode, thermistor, and thermo-electric cooler
APPLICATION
This MI laser is intended for intermediate reach applications (<=24km) at 10Gb/s.
DESCRIPTION
The Modulator Integrated DFB Laser (MI DFB Laser) has an electro-absorption modulator monolithically integrated with a conventional Distributed Feed-Back (DFB) laser. The modulation voltage is applied to the modulator section while the laser section operates CW allowing extremely low wavelength chirping. Extinction ratios of more than 8.2 dB can be achieved with 2.6 Vp-p modulation. The MI laser is installed in a butterfly type package. The module incorporates a highly stable optical coupling system. The module includes an optical isolator, monitor photodiode,thermistor and a thermoelectric cooler.
EMAIL:OECR_CWDM@hotmail.com |
