Beam quality TEM00 (M2 1,1)
Beam roundness [%] 1,1
Thermal tuning coefficient [GHz/K] -6
Thermal tuning range [GHz] 60
Thermal response bandwidth [Hz] 1
PZT tuning coefficient [MHz/V] 2
PZT tuning range [MHz] ± 200
PZT response bandwidth [kHz] 1
Emission spectrum single-frequency
Spectral linewidth [kHz/100 ms] 1
Coherence length [km] 1
Frequency drift [MHz/min] 2
Relative Intensity Noise, RIN [dB/Hz] -90
Noise eater option, RIN [dB/Hz] -1401)
Intensity noise, 10 Hz to 2 MHz [% rms] 0,1
Waist location (outside laser head) [mm] 120
Laser head size, w · h · d [cm] 27,0 · 16,8 · 52,0
Laser head weight [kg] 30
Laser electronics size, w · h · d [cm] 35 · 14 · 34
Laser electronics weight [kg] 10
Frequency doubling electronics size, w · h · d [cm] 35 · 9 · 34
Frequency doubling electronics weight [kg] 8
Laser apertures 10 mm
520
INNOLIGHT
DIABOLO PRODUCT LINE
这是目前商用激光器中频宽最窄的产品之一,线宽只有1KHZ
联系方式:jack-yao@teo.com.cn
[此贴子已经被作者于2004-9-4 8:25:12编辑过]
