目录
简 介..........................................................................................................................................................................................................3
光纤加速度计..............................................................................................................................................................................................4
光纤加速度计.............................................................................................................................................................................4
超轻型光纤加速度计FOA1550.................................................................................................................................................4
标准型光纤加速度计.................................................................................................................................................................4
超宽温度范围光纤加速度计.....................................................................................................................................................4
用于狭窄环境光纤加速度计.....................................................................................................................................................5
双轴标准型光纤加速度计.........................................................................................................................................................5
超宽温度范围光纤加速度计.....................................................................................................................................................5
6通道光纤加速度计..................................................................................................................................................................5
光纤地震计.................................................................................................................................................................................6
光纤声音传感器..........................................................................................................................................................................................7
光纤声音传感器.........................................................................................................................................................................7
光纤监听器.................................................................................................................................................................................7
(光纤微振动传感器).............................................................................................................................................................7
低噪声全方位光纤声音传感器.................................................................................................................................................7
防水密封型光纤声音传感器FOM4120.....................................................................................................................................8
接触式光纤声音传感器.............................................................................................................................................................8
3维声强探测器..........................................................................................................................................................................8
8字型双向光纤声音传感器......................................................................................................................................................8
心型单向光纤声音传感器.........................................................................................................................................................9
8字型光纤声音传感器..............................................................................................................................................................9
高方向性光纤声音传感器系统.................................................................................................................................................9
抗震型光纤声音传感器.............................................................................................................................................................9
带SPL抗震型光纤声音传感器................................................................................................................................................10
超宽频率抗震型光纤声音传感器...........................................................................................................................................10
超宽温度范围抗震型光纤声音传感器....................................................................................................................................10
次声抗震型光纤声音传感器...................................................................................................................................................10
小尺寸光纤声音传感器...........................................................................................................................................................11
高SPL光纤声音传感器............................................................................................................................................................11
超宽频率光纤声音传感器.......................................................................................................................................................11
超宽温度光纤声音传感器.......................................................................................................................................................11
声学及振动分析仪....................................................................................................................................................................................12
手机:13902430737
Q Q:13902430737
我们提供以下各种解决方案和所需器件:
高功率脉冲光纤激光器解决方案
高功率光纤放大器(保偏和单模)解决方案
高功率光纤激光相干合成解决方案
DTS光纤R-OTDR测温传感系统解决方案
光纤B-OTDR和B-OTDA温度/应变传感系统解决方案
FBG光纤光栅温度/应变传感系统解决方案
光纤水听器系统解决方案
光纤电流/电压传感器解决方案
光纤冲击波、声音、振动、速度、位移传感系统解决方案
近/远距离激光多普勒测风雷达解决方案
激光成像雷达系统解决方案
FSO自由空间光通讯系统解决方案
转台/离心机光纤滑环高速信号传输系统解决方案
光纤射频/视频/数据传输系统解决方案
