793/2000nm Singlemode Wavelength Division Multiplexer
The 793/2000 nm Singlemode Wavelength Division Multiplexer combines light at 793 nm and 2000 nm windows.They offer very low insertion loss and excellent environmental stability.
Specifications
Parameter Value
793nm Channel 793 ± 20nm
Max. Insertion Loss 0.7dB
Min. Isolation @2000 ± 20nm 10dB
2000nm Channel 2000 ± 20nm
Max. Insertion Loss 0.9dB
Min. Isolation @793 ± 20nm 10dB
Max. Polarization Dependent Loss 0.2dB
Thermal Stability ≤0.004dB/℃ over -5 °C to +70 °C
Min. Return Loss 55dB
Min. Directivity 55dB
Max. Optical Power (Continuous Wave) 500mW
Operating Temperature -5 to +70℃
Storage Temperature -40 to +85℃
*Above specifications are for device without connector.
*For devices with connectors, IL is 0.3dB higher, RL is 5dB lower.
具体订购详情跟公司销售人员联系。
珠海飞宇光电深圳业务中心
地址:深圳市宝安区龙华鹊山太阳能硅谷大厦A座14楼
电话:0755-28113498-2806
传真:0755-29048624
Http://www.opticres.com
Email: bgzeng@opticres.com QQ:1350027351 |
