LED天花舞台灯 QQ:949401782 阿里巴巴ID:szlidajd
型号:W666
材质:优质塑料+光纤
外观表面处理:喷油+电镀
尺寸:Φ90*85mm
包装:90*90*85mm
电源:AC85-260V 50/60H,DC 9V/12V/24V(需要定制)
功率:3W. (RGB七色)
启动时间:≤1秒
工作寿命: 8000H
模式:自走+声控
适合范围:装入到天花灯中应用于舞台,酒吧,KTV,家庭装饰,店铺,夜店等
LED ceiling stage light
specification:
Model NO.:W666
Light source: 3w (RGB color)
Working Voltage: AC 85-260V or DC9V/12V/24V(custom-made)
Line Frequency: 50~60Hz
Packing:90*90*85mm
Lifespan:8000H
Working Temperature: -30 °C to +50 °C
Control mode:Auto and sound-activated
Application: into the ceiling lamp,apply to Stage,Bar, KTV, home decoration, dance hall, indoor using and so on
Notice:
1.please shut power off when Installation or replacement light
2.this unit is intended for indoor use only and should be prevented from water,moisture and shake.
3.To keep the body of this unit clean to avoid any unneccessary troubles.
4.please operate this LED light according to above the manual strictly.
