Features
● High Isolation
● Low Insertion Loss
● High Return Loss
● Low Polarization Sensitivity
Applications
● Optical Fiber Amplifiers
● CATV Fiberoptic Links
● Fiberoptic Systems Testing
● Fiberoptic LAN Systems
● Telecommunications
Performance Specifications
Parameter Specification
Center Wavelength (nm) 1310,1480 or 1550
Min. Bandwidth(nm) ±15
Typical Insertion Loss (dB) 0.4
Max. Insertion Loss (dB) 0.6
Faraday Rotation Angle (Single Pass) 45°
Rotation Angle Tolerance over Wavelength and Temperature 0.5°
Max. PDL (dB) 0.05
Max. PMD (dB) 0.05
Max. Optical Power (mW) 300
Max. Tensile Load (N) 5
Operation Temperature (℃) -5 ~ +70
Storage Temperature (℃) -40 ~ +85
Dimensions (mm) Φ4.5x25 or Φ 5.5x30
Specifications may change without notice
Ordering Information
FRDMR XX X X X
Center wavelength Pigtail Style Fiber Length Connector
13=1310nm
14=1480nm
15=1550nm 1=Bare Fiber
2=900um jacket 1=1m
S=Specify 0=none
1=FC/APC
2=FC/PC
3=SC/APC
4=SC/PC
5=ST
6=LC
