硬脆材料的化学机械抛光机理研究
The Chemical Mechanical Polishing Technique Research of the Hard and Brittle Materials
下载全文
硬脆材料的化学机械抛光机理研究.pdf
(833.36 KB, 下载次数: 6)
作 者:武昌壕 郭冰 姚光 赵清亮
WU Chang-hao, GUO Bing, YAO Guang, ZHAO Qing-liang (College of Mechanical and Electrical Engineering, Harbin Institute of Technology, Heilongjiang Harbin 150001, China)
机构地区:哈尔滨工业大学机电工程学院,黑龙江哈尔滨,150001
出 处:《机械设计与制造》 2014年第2期 37-39页,共3页
Machinery Design & Manufacture
基 金:国家自然科学基金(51075093)
摘 要:化学机械抛光(Chemical Mechanical Polishing,简称CMP)技术是目前唯一可提供全局平面化的超精密表面加工技术,加工后无表面和亚表面损伤.该技术广泛应用于光学元件、微机电系统、集成电路芯片等表面的处理,可达到纳米级的表面粗糙度和微米级的面形精度.目前的研究主要集中在化学机械抛光工艺上,抛光机理尚未形成统一的学说.针对硬脆材料(Si、SiC)的CMP技术进行综述,介绍了CMP技术的发展现状,并对加工过程中存在的材料去除机理做了可能性解释,最后对CMP技术的发展和研究重点做了预测和建议.
Chemical mechanical polishing, which is short, for CMP, is the only. global plat,rizuian technalogy .fir ultra precision surface processing, and there is no sure and sub-surface danage after processed. Bectuse of its ad,antages in achieving nanoscale surface roughtwss and micron surface accuracy, CMP is widely used itz the surface tretament of optical elements, micro-electromechattical systems, integraled circuit chips, etc. The research has mainly focused on the chemical mechanical polishing process, and the polihing mechtmism has not yet formed a unified theory until nu,. The progress of CMP for bard cmd brittle mttterial, like Si trod SiC is reviewed here; meanwhile, the probable removal mechanism /CMP are presented. At last, the fiture trends atd key problems of CMP are discussed.
关键词:化学机械抛光 去除机理 影响因素 表面质量
Chemical Mechanical Polishing ; Removal Mechanism ; Factors ; Surface Quality ; |
