光学玻璃用高纯度硝酸钾中微量钠的火焰原子吸收光谱法测试
Determination of Trace Amount of Sodium in Refined Potassium Nitrate by Flame Atomic Absorption Spectrometry
下载全文
光学玻璃用高纯度硝酸钾中微量钠的火焰原子吸收光谱法测试.pdf
(226.5 KB, 下载次数: 1)
作 者:梁波[1] 王利强[1] 李敏[1] 江林[2] 罗明标[1]
LIANG Bo,WANG Li-qiang,LI Min,JIANG Lin,LUO Ming-biao( 1.Nuclear Resources and Environmental Engineering Center,East China Institute of Technology,Nanchang 330013,China; 2.Nanchang O-Film Tech Co.,Ltd, Nanchang 332000,China)
机构地区:[1]东华理工大学核资源与环境工程技术中心,江西南昌330013 [2]南昌欧菲光科技有限公司,江西南昌332000
出 处:《玻璃与搪瓷》 2014年第42卷第6期 19-22页,40页,共5页
Glass & Enamel
摘 要:介绍了火焰原子吸收法测试智能手机触摸屏用高纯度硝酸钾中微量钠的方法,优化了仪器的灯电流、狭缝宽度、乙炔与空气流量,研究了标准曲线选择、最大称样量及消电离剂用量等条件.该方法用于智能手机触摸屏用高纯度硝酸钾中微量钠的测试,检出限为0.002%,相对标准偏差为2.88%,回收率在95.00% ~ 101.25%。
By using flame atomic absorption spectrometry a method for accurate determination of trace amount of sodium in refined potassium nitrate,which is used as a raw material for touch screen,was described.The measuring parameters,such as lamp current,slit width,flow rate of acetylene and air,etc.were optimized.In addition,the selection of the standard curve,the maximum sampling weight and the amount of the ionization buffer in determining process were also discussed.The detection limit was 0.002%,the recovery rate was between 95.00% and 101.25%,and the relative standard deviation was less than 2.88%.
关键词:火焰原子吸收法 触摸屏 高纯度硝酸钾 微量钠
Flame Atomic Absorption Spectrometry (FAAS) ; touch screen ; refined potassium nitrate ; trace amount of sodium ; |
