Ce,Sm:YAG单晶用于白光LED器件的封装研究
Study on package of white led device for ce,sm:yag single crystal
下载全文
Ce,Sm:YAG单晶用于白光LED器件的封装研究.pdf
(579.74 KB, 下载次数: 3)
作 者:郝继彦[1] 陈兆平[2] 张成龙[3] 向卫东[3] 刘海涛[3]
机构地区:[1]呼伦贝尔市红利玻璃制瓶有限公司,内蒙古自治区呼伦贝尔021000 [2]上海应用技术学院材料科学与工程学院,上海200235 [3]温州大学化学与材料工程学院,浙江温州325035
出 处:《中国建材科技》 2015年第1期 47-51页,共5页
China Building Materials Science & Technology
基 金:国家自然科学基金(51172165)
摘 要:采用提拉法生长了白光LED用Ce,Sm:YAG单晶,用XRD对物相进行分析,探讨了不同因素对LED器件光电参数的影响,采用LED老化仪对不同封装形式的LED器件进行了光衰测试,结果表明:采用不同支架封装对LED器件光电参数影响很小;提高晶片厚度可以增加光效,但光谱中黄绿光成分随之增加,色度坐标偏离白光区域;随着测试电流的降低,器件光效显著增加,AB胶的引入可以增加器件的光效。而在1000小时光衰测试中并未出现发光衰减。
Ce,Sm:YAG single crystal for white light emitting diode (LED) was grown by Czochralski method. The crystal phase structure of YAG was analysised by XRD.The photoelectric properties of white LED fabricated by Ce,Sm:YAG single crystal Were also measured by several factors.The light decay of LED device was tested by the LED aging instrument.LED packages of different stents optical parameters of the device have little effect.Thickness of the wafer can be increased to improve light efficiency, but increases the spectral components in yellow-green,white chromaticity coordinates deviate from the region.With lower test current,there is significant increasing in device efficiency.The introducing of AB glue can increase the optical efficiency of the device.There was no luminescence decay during the test of 1000 h.
关键词:LED YAG 单晶 封装 光效
LED ; YAG ; single crystal ; package ; light efficiency ; |
