<P>急求購數碼相機鏡頭VGA 0.35M 4M鏡頭</P>
<P>規格:</P>
<P>SONY ICX098BQ</P>
<P>Diagonal 4.5mm (Type 1/4) Progressive Scan CCD Image Sensor with Square Pixel for Color Cameras</P>
<P>Device Structure
? Interline CCD image sensor
? Image size: Diagonal 4.5mm (Type 1/4)
? Number of effective pixels: 659 (H) × 494 (V) approx. 330K pixels
? Total number of pixels: 692 (H) × 504 (V) approx. 350K pixels
<FONT color=#e61a42>? Chip size: 4.60mm (H) × 3.97mm (V)</FONT>
? Unit cell size: 5.6µm (H) × 5.6µm (V)
? Optical black: Horizontal (H) direction: Front 2 pixels, rear 31 pixels
Vertical (V) direction: Front 8 pixels, rear 2 pixels
? Number of dummy bits: Horizontal 16
Vertical 5
? Substrate material: Silicon
– 1 –
ICX098BQ
E00343B37
Sony reserves the right to change products and specifications without prior notice. This information does not convey any license by
any implication or otherwise under any patents or other right. Application circuits shown, if any, are typical examples illustrating the
operation of the devices. Sony cannot assume responsibility for any problems arising out of the use of these circuits.
</P>
<P>SONY ICX406BQF</P>
<P>Device Structure
? Total number of pixels: 2384 (H) × 1734 (V) approx. 4.13M pixels
? Number of effective pixels: 2312 (H) × 1720 (V) approx. 3.98M pixels
? Number of active pixels: 2308 (H) × 1712 (V) approx. 3.95M pixels diagonal 8.980mm
? Number of recommended recording pixels:
2272 (H) × 1740 (V) approx. 3.87M pixels diagonal 8.875mm aspect ratio 4:3
<FONT color=#f70938>? Chip size: 8.08mm (H) × 6.62mm (V)</FONT>
? Unit cell size: 3.125µm (H) × 3.125µm (V)
? Optical black: Horizontal (H) direction:Front 16 pixels, rear 56 pixels
Vertical (V) direction: Front 12 pixels, rear 2 pixels
? Number of dummy bits: Horizontal 28
Vertical 1 (even fields only)
? Substrate material: Silicon</P>
<P>如要規格請與我聯繫</P>
<P>e-mail:<a href="mailtliuhk9603@126.com" target="_blank" >liuhk9603@126.com</A></P>
<P>急需需要鏡頭,請送樣2-3樣本測試</P>
