在TRACEPRO中定义导光板的材料定义材料包括2大项,1、物质材料。2 、表面材料。 其中:定义物质材料为过程的第三步,比较简单。表面材料为第四步,另外创造反射镜部分也很麻烦,希望共同探讨:Adding Surface Properties to the LCD PanelTo add a mirror surface to the bottom of the panel you need to select surfaces 1,2,3 and 5 by first opening Object 1 by left mouse clicking on the + sign before the objectNow left mouse click on surface in this will highlight the surface in blue on the object tree and in black on the viewing area Right mouse click on the viewing area to bring up the Cut, Copy, etc dialog box. Select the Properties Option.Now go to the Surface tab in the Apply Properties menu Using the pull down menu find the Perfect Mirror coating and using the Apply this coating to surfaces 1,2,3 and 5.Make sure your object tree looks like the one to the left. |
