Butterfly APD Receiver ZGBxA1-701x-00 Description
The product integrates a high linearity InGaAs APD with TEC and thermistor, Low dark current, High linearity, High responsivity
Features:
Long wavelength operation
Package: 8pin & 14pin butterfly package
Built-in thermistor, and TEC
Low dark current
Excellent reliability compliance to GR-468-CORE
Compliance to RoHS standard
Applications
Optical fiber sensor system
Optical fiber communications system
Absolute Maximum Ratings
Parameter | | | | | | Operating Case Temperature | | | | | | | | | | | | | | | | | | Thermoelectric cooler voltage
| | | 2.6 | | | Forward current | | | | | | Reverse current | | | | | | Lead solder Temperature | | | 260 | | | | | | 10 | | |
Optical/Electrical Characteristics (T=25℃,unless otherwise stated)
| Parameter | Symbol | Min | Typ | Max | Unit | Test Conditions | | | | | | | | Breakdown Voltage
| | | | | | | Dark Current
| | | | 50 | | | Responsivity
| | | | | | λ = 1550nm;M=1;25°C Tc=25℃~-20℃ | TEC Current
| | | | | | | Cutoff frequency
| | | | | | | Capacitance
| | | 0.38 | | | | Thermistor Resistance
| | | | | | | Thermistor B-Value
Dimensions and Pin Description Dimensions are in millimeters. All dimensions are ±0.1mm unless otherwise specified.
8pin butterfly package
