爱普生晶体晶振在无线通讯领域的应用33 秒前 上传
下载附件 (29.67 KB)
EPSON晶振FC-135
| Block
Function
| Epson Products
| Function
| Category
| Model
| Description 1
| Description 2
| A
| Transceiver
| Ref. Clock
| Crystal Unit
| FA-20H
FA-128
FA-118T
| 16.0MHz, 20MHz, 26.0MHz, 37.4MHz, 38.4MHz, 40.0MHz, 48.0MHz
| Crystal unit for WiFi, BT
| A
| Transceiver
| Ref. Clock
| Crystal Unit
| FA-20HS
FA-128S
| 19.2MHz, 26.0MHz, 38.4MHz, 52.0MHz
| Crystal with Thermistor for GPS and Cellular
| A
| Transceiver
| Ref. Clock
| VC-TCXO
| TG-5006CJ
| For Cellular RF
| A
| Transceiver
| Ref. Clock
| TCXO
| TG-5006CJ
| 16.368MHz, 26.0MHz, 37.4MHz, 38.4MHz, 40.0MHz
| For GPS and WiFi
| B
| Base Band
| PMIC (RTC)
| Crystal Unit
| FC-135
FC-12M
FC1610AN
| 32.768kHz
| C
| Base Band
| MCU
| Crystal Unit
| FA-20H
FA-128
FA-118T
| 24MHz, 24.576MHz
| 爱普生晶体振荡器、谐振器、时钟芯片在示波器中的应用33 秒前 上传
下载附件 (24 KB)
MC-146
| Block
Function
| Epson Products
| Function
| Category
| Model
| Description 1
| Description 2
| A
| CLK Generator
| Clock
| SPXO
| SG-210STF
| 12.288MHz, 15.36MHz, 19.44MHz, 25MHz
| B
| CLK Distribution
| Jitter clean
| VCXO
| VG-4501CA
| 122.88MHz
| APR:+/-20ppm Min.
| C
| MCU
| Clock
| OSC
| SG-8003CG
SG-8003CE
SG-8003LB
SG-8003CA
SG-8003JF
| 20MHz, 27MHz, 30MHz etc.
| D
| MCU
| RTC
| Crystal unit
| MC-146
FC-135
| 32.768kHz
| D
| MCU
| RTC
| Built in
Crystal Unit
| RX6110SA
RX8010SJ
| I2C, SPI
| E
| Ethernet(LAN)
| Clock
| SPXO
| SG-210STF
| 25MHz, 50MHz
| E
| Ethernet(LAN)
| Clock
| Crystal unit
| FA-238
| 25MHz, 50MHz
| F
| USB
| Clock
| SPXO
| SG-210STF
| 12MHz, 24MHz, 48MHz
| F
| USB
| Clock
| Crystal unit
| FA-238
FA-238
| 12MHz, 24MHz, 48MHz
| G
| Reference CLK
| Ref Clock
| OCXO
| (contact us)
| 10MHz
| 爱普生频率元器件在Smart Meter(智能电表)领域的应用34 秒前 上传
下载附件 (24.77 KB)
FA-20H
| Block
Function
| Epson Products
| Function
| Category
| Model
| Description 1
| Description 2
| A
| MCU
| Clock
| Crystal unit
| MA-406
FA-238
| 4MHz, 8MHz, 12MHz
| B
| MCU
| RTC
| Built in
Crystal unit
| RX6110SA
| I2C & SPI
| Low Power
| B
| MCU
| RTC
| Built in
Crystal unit
| RX-8803SA
RX-8803LC
| I2C
| Hight stability
| B
| MCU
| RTC
| Built in
Crystal unit
| RX-4803SA
RX-4803LC
| SPI
| Hight stability
| C
| Communication unit
| W-PAN
| Crystal unit
| TSX-3225
FA-20H
FA-128
| 26MHz, 30MHz, 32MHz
| C
| Communication unit
| W-PAN
| TCXO
| TG-5021CG
TG-5021CE
TG-5006CJ
TG-5006CG
TG-5006CE
| 26MHz, 30MHz, 32MHz
| C
| Communication unit
| W-LAN
| Crystal unit
| TSX-3225
FA-20H
FA-128
| 26MHz, 30MHz, 32MHz
| D
| Ethernet
| Clock
| SPXO
| SG-210STF
| 25MHz, 50MHz
| D
| Ethernet
| Clock
| Crystal unit
| FA-238
| 25MHz, 50MHz
以上资料经专业的晶振供应商-上海唐辉电子整理,公司作为EPSON的代理商,可提供各种常用标准频率值,各种片式规格尺寸的常用型号晶振,并提供专业的晶振选型指导,为客户提供100%的原装正品。
