! Macro TOLMTF
! Other global variables which may be filled in to override
! defaults are: ! ^format The format of the output. The total width of
! the field should be 12 characters. The default
! is "8d.3d". ! ^description A description of the image quality value for
! labeling purposes. The default is a blank. ! ^degradation A value of +1 or -1 depending on whether
! an increase or decrease of the image quality
! value degrades the image. For example, for
! RMS wavefront error it is +1 while for
! MTF it is -1. The default is +1. ! ^error An error code. It is initialized to 0 in
! TOLFDIF. If the image quality value cannot
! be calculated, this macro should set it to 1. ! ^z_limit The limit on the zoom loop. It is initialized
! to (NUM Z) in TOLFDIF. ! ^f_limit The limit on the field loop. It is initialized
! to (NUM F) in TOLFDIF. ! ^z_label The label for the zoom loop. It is initialized
! to "Zoom" in TOLFDIF. It can be up to 10 characters. ! ^f_label The label for the field loop. It is initialized
! to "Field" in TOLFDIF. It can be up to 10 characters. ! ^z_name(50) The names of the zoom values. It is initialized
! to 1, 2, 3, etc., in TOLFDIF. Each can be up to 10 characters. ! ^f_name(50) The names of the field values. It is initialized
rfd "TAN" 20
lcl num ^z ^f
lcl str ^t
!lcl num mtfs(200)
!lcl num mtft(200)
! Define format, description and degradation for use by TOLFDIF
^format == "5d.6d"
^description == concat(substr(rfstr(1),1,3)," MTF at ")
^description == concat(^description,num_to_str(#2))
^description == concat(^description," cyc/mm ")
^degradation == -1
^t==rfstr(1)
^t==substr(upcase(^t),1,1) vux f1 (vux f1)+.001
BUF DEL B0 ! clear B0 buffer
BUF YES ! turn on output buffer to collect output
mtf
mfr #2
ifr #2/2
plo fre n
go
BUF NO ! turn off output buffer ! Loop through field, using BUF FND to locate data of interest
! "DIFFRACTION LIMIT" is reference point for start of MTF data
! sagittal is 6 lines below, 4 columns over
! tangent. is 6 lines below, 5 columns over BUF MOV B0 I1 J1
BUF FND B0 "DIFFRACTION LIMIT" ! find first occurrence
for ^z 1 (num z)
for ^F 1 (num f)
!^diffs(^i) == (buf.num ic+6 jc+2) ! ic updated by each BUF FND
!^difft(^i) == (buf.num ic+6 jc+3)
!^mtfs(^j,^i) == (buf.num ic+6 jc+4)
IF ^t = 'T'
^imagqual(^z,^f) == (buf.num ic+6 jc+5)
ELSE
^imagqual(^z,^f) == (buf.num ic+6 jc+4)
END IF
!^mtft(^j,^i) == (buf.num ic+6 jc+5)
BUF FND ! find next occurrence
end for
end for buf del b0 以上是一个用于MONTE CALRO 的宏的示例. 其实很简单,但是将你想要进行的公差分析内容入进一个全局变量中,供TOLMONTE CALRO调用就可以了. |
