<P>This is a complicated model. IMHO, you could model a imaging system with extended source and a cylindrical reflecting surface.The extended source is your body, the imaging plane will be placed at the location of the source. Then you could get a distorted imaging. The issue is the imaging your eyes viewed. This make the system a complicated one. I think you could insert human eyes optical model into your system just in front of your iris and at the location of the extended source. You will find that the system is a tilted system with the limitation of the eyes FOV. This could be starting point.</P>
<P>-mdfremont</P>
