<P>原文:Measurement of electrical quantities and component</P>
<P>Electrical parameters<BR><BR>Most measurements made on electronic equipment are the parameters of voltage, current, and power. These measurements are usually made during the final product testing phase or incoming testing before the equipment is placed in day-to-day use and Of course during system diagnostic and maintenance stages. Verification of proper operating voltages, current, and power indicate that at least the system has an operational power supply and that power regulation circuits are operating correctly. Oftentimes the main problem with many electronic systems is a poor or defective power supply and by monitoring the power supply electrical parameters, a power supply failure and system outage can be avoided.<BR><BR>Voltage<BR><BR>One of the easiest measurements to make on a system is voltage. Voltage can be measured using a variety of methods. Instruments used in today’s electronic industry consist of various types of voltmeters with accuracies form 5 percent of full scale to nearly 0.002 percent of reading. Many multimeters used today still use the magnetoelectric meter movement as an indicating device. Many people still feel that a meter showing small flickering changes is easier to read than a digital meter on which you try to read flashing digits. The digital voltmeter has to be powered with a power supply or batteries, while the magnetoelectric type meter only needs a battery in the ohms mode.<BR></P>
<P>译文:电量和电子元件的测量</P>
<P>电参数<BR><BR>对大多数电子设备而言需要测量的是电压,电流,和功率。这些测量通常在产品测试阶段进行,或者在产品即将被日夜使用之前来进行,当然也在系统作诊断和维修期间进行。如果证实操作电压,电流,功率是正常的,那么表明系统至少有一个可供系统运行的能量供应,也表明能量的调节电路是正常运行的。就常规来说,有许多电子的系统的主要的问题是有着不良的或者是有缺陷的能量供但是通过监控能量供应的电子参数,供电失误和系统 停止的情况是可以避免的。<BR><BR>电压<BR><BR>在一个系统中,以上最容易测量的就是电压。电压测量可以使用许多方法。当今在电子业使用的测量仪器包括各种各样的电压表,精度从满刻度盘的5%到接近读数的0.002%。今天使用的许多万用表仍在利用电磁表头的运动来作为指示刻度之用。许多人仍然感到在显示出微小摇曳变化的仪表读数比在数字表上竭力去读闪烁的数字更容易。数字式伏特计必须供以能量或者以电池组为动力,而磁电式仪表仅仅在欧姆表里需要一节电池。<BR></P>
<P>更多英中对照请点击:<a href="http://www.greatleo.com/show.aspx?id=122cid=11" target="_blank" >http://www.greatleo.com/show.aspx?id=122cid=11</A></P>
