Deqing HuaRui-optics Components Co., Ltd
HR-OPTICS devotes itself to development of all kinds new optical single crystals, optic wafers and optic passive components. For passing 10 years over we enjoyed our abundance experience at growing and mass production of optical grade Lithium Niobate / Lithium Tanatalate single crystal and it's wafers. We are equipped with advanced facilities at crystal growing, wafer lapping and polishing, all finished products are passed at Testing and QC inspection. Our R D is active at developing and researching from new materials to finished products at all kinds of optical electronic components.
Optical Materials
HROPTICS is capable of fabricating a wide variety of optical components with various optical materials. The most important material properties to consider for an optical element are transmission versus wavelength, index of refraction, thermal characteristics, mechanical and chemical characteristics and cost.
There are two instances in which you might need to know more about optical materials. First, you may need to determine the performance of a catalog component in a particular application. Second, you may need specific information when selecting the material for a custom component. The data in the following is intended to assist in these situations.
To select the right materials seems overwhelming. The simplest way is to let a HROPTICS engineer know your application, and we can select them for you.
SOME OF THE MATERIALS THAT HROPTICS USES INCLUDE
General optical glass: CDGM glass ,Schott glass, Ohara glass
Special glass: Fused silica, (JGS1、JGS2、JGS3), Float glass, etc...
Optical crystal: LiNbO3,, LitaO3,Quartz, Silicon, Ge, . Sapphire, CaF2,
CDGM glass(BK7) ,Schott glass, Ohara glass |
