大家好, 我们是美国一家光电公司,现有一台日本昭和光学真空镀膜机和一台日本optorun 光学真空镀膜机,有意者,请与我联系13937381870 。我姓安 以下是机器的简要介绍。 Showa SGC-26SA-RF Model.(日本昭和) 1. Vintage: 2003 2. Chamber size: 1100 mm 3. Low vacuum system: ULVAC VS2401 Rotary Pump+ULVAC PRC-012AS High vacuum system: SHOWA SHINKU SFD-26C oil Diffusion Pump. Poly Cold R2000 series 4. Two E-Beam Gun 5. JEOL JST-10F EB-Source Power Supply 6. Kyosan 3KW RF GENERATOR for Assisted Deposition 7. Inficon IC/5 Deposition Controller 8.Optical monitoring system, from 300 nm to 2500nm 9. Substrate holding fixture: Dome. 另外我公司还有一批激光器。 Lambda Physik Lithography lasers for semiconductor SERIAL DESCRIPTION MODEL WAVELENGTH
6795 Factory crate A2020 193 6794 Factory crate A2020B 193 (kinematics mounts) 6469 Factory crate A2020 193
7181 USED A4020 193 (kinematics mounts)
6947 USED K2020B 248 (kinematics mounts) 6767 USED K2020B 248 (kinematics mounts)
4181 USED KrF 1Khz "lambda litho" 谢谢
