本公司是韩国光电子的代理,主要销售红外发射管,接收管,接收头,硅光二极管,硅光电池,可见光接收管,光电开关,光电耦合器(光耦),光电编码器,光电位置检测器,激光管等.主要品牌有KODENSHI,HONEYWELL,EVERLIGHT,OSRAM,VISHAY等. | kodenshi | SP-1KL | | SP-1ML | | SP-45ML | | HPI-1KL5 | | HP-202G | | HPI210 | | HPI5FCR2 | | HPI6FER2 | | HPI6FER4 | | HPI6FGR4 | | HPI6FFR4 | | ST-1CL3H | | ST-1KB | | ST-1KLA·ST-1KLB | | ST-1KL3A·ST-1KL3B | | ST-1MLBR2 | | ST-23G | | PT-23G | | SD-402 | | EL-23G | | EL-1CL3 | | EL-1ML2 | | EL-1K3 | | EL-1KL2 | | EL-1KL3 | | EL-1KL5 | | CL-203HL | | SG-2BC | | SG-105F | | SG-105LF | | SG-105F6 | | SG-113 | | SG-206S | | SG-207 | | SG-211V | | SG-214 | | SG-215·SG-215M | | SG-226 | | SG-243 | | SG-23FF | | SG-23FI | | SG-23FL | | LG-207 | | KE-204 | | KE-2108-15 | | PIC0103 | | PIC0903 | | PS-R11D | | KSM-603LM-2 | | KSM-603LM2K | | KSM-603TM2 | | KSM-903LM | | KSM-953TH2-2 | | PC17K1 | | AUK | SI5312 | | ST3811 | | ST5811 | | 亿光 | IR204-A | | PT204-6B | | PT17-21C | | PT908-7C | | IR908-7C | | honeywell | SD1440-004L | | SD2440-004 | | SD5443-004 | | SE5470-004 | | SE1470-004L | | OSRAM | BPW34 | | BPX48 |
另还有各类激光管,欢迎前来询问购买! 上海韩申电子有限公司 董先生. 021-51696207-837. |
