2楼
楼主 |
发表于 2007-3-21 20:01:00
只看该作者
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-SIZE: 16pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">灵活地使用功能</span></b><b style="mso-bidi-font-weight: normal;"><span lang="EN-US" style="FONT-SIZE: 16pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">有用的工具</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><a name="ade"></a><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">非常强大,但有时不会注意到有用的功能。这儿有一张最有用的工具和功能的列表:</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><shapetype id="_x0000_t202" path="m,l,21600r21600,l21600,xe" ospt="202" coordsize="21600,21600"><stroke joinstyle="miter"></stroke><path oconnecttype="rect" gradientshapeok="t"></path></shapetype><shape id="_x0000_s1029" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 0px; Z-INDEX: 4; LEFT: 0px; MARGIN-LEFT: 207pt; WIDTH: 245.4pt; POSITION: absolute; HEIGHT: 63.45pt; TEXT-ALIGN: left; mso-wrap-style: none;"><textbox style="mso-fit-shape-to-text: t;"><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span lang="EN-US"><shapetype id="_x0000_t75" path="m@4@5l@4@11@9@11@9@5xe" ospt="75" coordsize="21600,21600" stroked="f" filled="f" opreferrelative="t"><stroke joinstyle="miter"></stroke><formulas><f eqn="if lineDrawn pixelLineWidth 0"></f><f eqn="sum @0 1 0"></f><f eqn="sum 0 0 @1"></f><f eqn="prod @2 1 2"></f><f eqn="prod @3 21600 pixelWidth"></f><f eqn="prod @3 21600 pixelHeight"></f><f eqn="sum @0 0 1"></f><f eqn="prod @6 1 2"></f><f eqn="prod @7 21600 pixelWidth"></f><f eqn="sum @8 21600 0"></f><f eqn="prod @7 21600 pixelHeight"></f><f eqn="sum @10 21600 0"></f></formulas><path oconnecttype="rect" gradientshapeok="t" oextrusionok="f"></path><lock aspectratio="t" vext="edit"></lock></shapetype><shape id="_x0000_i1025" type="#_x0000_t75" style="WIDTH: 209.25pt; HEIGHT: 55.5pt;"><imagedata otitle="" src="file:///C:\DOCUME~1\Steven\LOCALS~1\Temp\msohtml1\01\clip_image001.emz"></imagedata></shape></span></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">滑杆</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">滑杆可以简便地调整任何一个镜头数据编辑器,非序列元件编辑器,多重结构编辑器或系统参数(如视场或波长)并且可以修改或打开任何分析窗口。滑杆有许多有用的性能:</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">。当你输入数据到编辑器时,打开分析窗口时,它将保持打开在</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的界面上。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">。你可以按你的需要一次打开多个滑杆,每个控制一个不同的参数。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">。只要点击你想调整的参数,然后点击</span><span lang="EN-US"><font face="Times New Roman">Tools..Miscellaneous…Slider</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">并且</span><span lang="EN-US"><font face="Times New Roman">Slider</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">将预先打开以控制参数。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><shape id="_x0000_s1028" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 23.4pt; Z-INDEX: 3; LEFT: 0px; MARGIN-LEFT: 234pt; WIDTH: 218.4pt; POSITION: absolute; HEIGHT: 84.45pt; TEXT-ALIGN: left; mso-wrap-style: none;"><textbox style="mso-next-textbox: #_x0000_s1028; mso-fit-shape-to-text: t;"><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><shape id="_x0000_i1026" type="#_x0000_t75" style="WIDTH: 203.25pt; HEIGHT: 76.5pt;"><imagedata otitle="" src="file:///C:\DOCUME~1\Steven\LOCALS~1\Temp\msohtml1\01\clip_image003.emz"></imagedata></shape><p></p></span></b></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">。你可以把它加到按钮栏中以一次点击就可以进入。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">添加折叠镜</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><font face="Times New Roman"><span style="mso-spacerun: yes;"> </span><span style="mso-spacerun: yes;"></span></font></span></b><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">将一个哑元面放置在需要添加折叠镜的地方,然后按下</span><span lang="EN-US"><font face="Times New Roman">Tools…Fold Mirror…Add Fold Mirror</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">。然后指定倾斜轴和需要的倾斜次数。</span><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">快速调整</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><shape id="_x0000_s1027" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 7.95pt; Z-INDEX: 2; LEFT: 0px; MARGIN-LEFT: 234pt; WIDTH: 221.4pt; TEXT-INDENT: 0px; POSITION: absolute; HEIGHT: 93.45pt; TEXT-ALIGN: left; mso-wrap-style: none;"><textbox style="mso-fit-shape-to-text: t;"><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><shape id="_x0000_i1027" type="#_x0000_t75" style="WIDTH: 206.25pt; HEIGHT: 85.5pt;"><imagedata otitle="" src="file:///C:\DOCUME~1\Steven\LOCALS~1\Temp\msohtml1\01\clip_image005.emz"></imagedata></shape><p></p></span></b></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">快速调整工具让你能改变任何序列面的曲率半径或厚度以优化点列尺寸或任何后续面的瞄准。你可以同按需要同时打开多个调整工具,而且你可以快速调整工具打开时进行编辑或分析。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">倾斜</span><span lang="EN-US"><font face="Times New Roman">/</font></span></b><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">偏心元件</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" align="left" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; TEXT-ALIGN: left; mso-char-indent-count: 2.0;"><shape id="_x0000_s1026" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 15.6pt; Z-INDEX: 1; LEFT: 0px; MARGIN-LEFT: 234pt; WIDTH: 221.4pt; TEXT-INDENT: 0px; POSITION: absolute; HEIGHT: 143.7pt; TEXT-ALIGN: left; mso-wrap-style: none;"><textbox style="mso-fit-shape-to-text: t;"><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><shape id="_x0000_i1028" type="#_x0000_t75" style="WIDTH: 206.25pt; HEIGHT: 135.75pt;"><imagedata otitle="" src="file:///C:\DOCUME~1\Steven\LOCALS~1\Temp\msohtml1\01\clip_image007.emz"></imagedata></shape><p></p></span></b></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">只要点击并你想倾斜或偏心范围内的面,然后点击</span><span lang="EN-US"><font face="Times New Roman">Tools…Miscellaneous…Tilt/Decenter </font></span></p><p class="MsoNormal" align="left" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 5.25pt; TEXT-ALIGN: left; mso-char-indent-count: .5;"><span lang="EN-US"><font face="Times New Roman">Elements</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">。这个工具将增加所有需要的坐标转折面以实现你需要的改变。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">参考物体</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">设想你正在构建一个非序列的系统,并且你已将一个物体置于全局坐标空间中。你现在想将它关于其它点倾斜,典型的是物体所在支架的轴点。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><shape id="_x0000_s1030" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 15.6pt; Z-INDEX: 5; LEFT: 0px; MARGIN-LEFT: 234pt; WIDTH: 218.4pt; TEXT-INDENT: 0px; POSITION: absolute; HEIGHT: 73.2pt; TEXT-ALIGN: left; mso-wrap-style: none;"><textbox style="mso-fit-shape-to-text: t;"><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><shape id="_x0000_i1029" type="#_x0000_t75" style="WIDTH: 203.25pt; HEIGHT: 65.25pt;"><imagedata otitle="" src="file:///C:\DOCUME~1\Steven\LOCALS~1\Temp\msohtml1\01\clip_image009.emz"></imagedata></shape></span></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">只要在轴点上定义一个空物体,然后用</span><span lang="EN-US"><font face="Times New Roman">Modify Reference Object</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">工具重新定义你的目标物体按相对于轴点来放置。当你倾斜或偏心轴点时,目标物体现在绕它的轴点移动。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-SIZE: 16pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">培训和支持</span></b><b style="mso-bidi-font-weight: normal;"><span lang="EN-US" style="FONT-SIZE: 16pt;"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><shapetype id="_x0000_t202" path="m,l,21600r21600,l21600,xe" ospt="202" coordsize="21600,21600"><stroke joinstyle="miter"></stroke><path oconnecttype="rect" gradientshapeok="t"></path></shapetype><shape id="_x0000_s1026" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 0px; Z-INDEX: 1; LEFT: 0px; MARGIN-LEFT: 207pt; WIDTH: 198pt; POSITION: absolute; HEIGHT: 187.2pt; TEXT-ALIGN: left;"><textbox><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span lang="EN-US"><shapetype id="_x0000_t75" path="m@4@5l@4@11@9@11@9@5xe" ospt="75" coordsize="21600,21600" stroked="f" filled="f" opreferrelative="t"><stroke joinstyle="miter"></stroke><formulas><f eqn="if lineDrawn pixelLineWidth 0"></f><f eqn="sum @0 1 0"></f><f eqn="sum 0 0 @1"></f><f eqn="prod @2 1 2"></f><f eqn="prod @3 21600 pixelWidth"></f><f eqn="prod @3 21600 pixelHeight"></f><f eqn="sum @0 0 1"></f><f eqn="prod @6 1 2"></f><f eqn="prod @7 21600 pixelWidth"></f><f eqn="sum @8 21600 0"></f><f eqn="prod @7 21600 pixelHeight"></f><f eqn="sum @10 21600 0"></f></formulas><path oconnecttype="rect" gradientshapeok="t" oextrusionok="f"></path><lock aspectratio="t" vext="edit"></lock></shapetype><shape id="_x0000_i1025" type="#_x0000_t75" style="WIDTH: 187.5pt; HEIGHT: 174pt;"><imagedata otitle="" src="file:///C:\DOCUME~1\Steven\LOCALS~1\Temp\msohtml1\01\clip_image001.emz"></imagedata></shape></span></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">全世界的培训</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" align="left" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; TEXT-ALIGN: left; mso-char-indent-count: 2.0;"><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">短期课程是获得</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">光学设计软件投资最佳收益的最好的方法。在美国,</span><span lang="EN-US"><font face="Times New Roman">5</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">天课程在多个城市举办,由</span><span lang="EN-US"><font face="Times New Roman">ZDC</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">工程师执教。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;">2007年4月9日-13日 将在南京理工大学 举办培训班 详情请咨询 025-57929358 薄小姐</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">支持和更新</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">现在可以解决任何种类的光学问题。持续的产品开发意味着你可能需要持续地更新工具以应对当今的光学设计挑战。另外,我们的客户支持工程师队伍会在你有问题时帮助你。</span></p><shapetype id="_x0000_t202" path="m,l,21600r21600,l21600,xe" ospt="202" coordsize="21600,21600"><stroke joinstyle="miter"></stroke><path oconnecttype="rect" gradientshapeok="t"></path></shapetype><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><shape id="_x0000_s1026" strokecolor="white" type="#_x0000_t202" style="MARGIN-TOP: 23.55pt; Z-INDEX: 1; LEFT: 0px; MARGIN-LEFT: 207pt; WIDTH: 215.4pt; TEXT-INDENT: 0px; POSITION: absolute; HEIGHT: 304.2pt; TEXT-ALIGN: left; mso-wrap-style: none;"><textbox style="mso-fit-shape-to-text: t;"><table cellspacing="0" cellpadding="0" width="100%"><tbody><tr><td style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent;"><div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="EN-US"><shapetype id="_x0000_t75" path="m@4@5l@4@11@9@11@9@5xe" ospt="75" coordsize="21600,21600" stroked="f" filled="f" opreferrelative="t"><stroke joinstyle="miter"></stroke><formulas><f eqn="if lineDrawn pixelLineWidth 0"></f><f eqn="sum @0 1 0"></f><f eqn="sum 0 0 @1"></f><f eqn="prod @2 1 2"></f><f eqn="prod @3 21600 pixelWidth"></f><f eqn="prod @3 21600 pixelHeight"></f><f eqn="sum @0 0 1"></f><f eqn="prod @6 1 2"></f><f eqn="prod @7 21600 pixelWidth"></f><f eqn="sum @8 21600 0"></f><f eqn="prod @7 21600 pixelHeight"></f><f eqn="sum @10 21600 0"></f></formulas><path oconnecttype="rect" gradientshapeok="t" oextrusionok="f"></path><lock aspectratio="t" vext="edit"></lock></shapetype></span></p></div></td></tr></tbody></table></textbox><wrap type="square"></wrap></shape><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">我们明白我们的客户为了保持竞争力工作有多么的努力,所以我们也努力工作保持竞争力。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';"></span></p><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';"><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-SIZE: 18pt; FONT-FAMILY: 华文新魏;">光学系统设计软件<span lang="EN-US"><p></p></span></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US" style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体;">ZEMAX</span></b><b style="mso-bidi-font-weight: normal;"><span style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体;">是一款十分强大、精确而又易于使用的软件,可用于所有光学系统的设计<span lang="EN-US"><p></p></span></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">被全世界的光学工程师和设计师用于透镜设计、照明、激光束传播、杂散光、光纤和其它光学技术运用领域。</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">在技术功能、便于使用方面处于领先地位并被证明是精确的。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">在</span><span lang="EN-US"><font face="Times New Roman">15</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">年多的时间里,我们的工程师和科研人员一直在发展</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">光学设计软件。如今,</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">已经成长为功能最强大且在世界范围内被广泛运用的光学系统设计软件,能进行光线追迹、优化、公差分析、衍射分析、激光束传播、</span><span lang="EN-US"><font face="Times New Roman">CAD</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">输入输出,可与</span><span lang="EN-US"><font face="Times New Roman">MatLab</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">及其它软件的通信并拥有内建的脚本语言及其它功能。有了这些技术,</span><span lang="EN-US"><font face="Times New Roman">ZEMAX</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">能使你解决几乎所有的光学系统设计问题。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span lang="EN-US"><font face="Times New Roman">ZEMAX Development Corporation</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">也在努力将工业中的此项技术降低到最低价格。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">我们知道客户为保持竞争力工作有多么的努力,所以我们也努力工作以保有竞争力。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;">我们专注于为客户提供强大、易用而又廉价的软件和技术支持以及成功设计所需的培<span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;">训。</span></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"></span></span></p><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">光研科学有限公司</span><span lang="EN-US"><p></p></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">电话:</span><span lang="EN-US"><font face="Times New Roman">+86 25 57929358<p></p></font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">传真:</span><span lang="EN-US"><font face="Times New Roman">+86 25 57929359</font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><font face="Times New Roman"></font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><font face="Times New Roman"></font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><font face="Times New Roman"></font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><font face="Times New Roman"></font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><b style="mso-bidi-font-weight: normal;"><span lang="EN-US"><font face="Times New Roman"><p></p></font></span></b></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"></p></span></span><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"><span style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"></span></span></p></span>
