国外的网站对这种fiber的描述是这样的:
Imaging fiber optics
Multi-fiber rods are used for image transmission. Our standard multi-fiber rods contain apromamently 10,000 individual fibers bound together in a coherent array. A coherent array is made when fibers next to each other at one end are next to each other at the other end. An image presented to one end of the rod will be transmitted to the other end of the rod. Lenses are often used to enlarge the image because of the small size of the rod. The fiber rod can flex without breaking, or can be bent permanently by heating and then cooling into the desired shape. Heating the rod will reduce flexibility.
我们的要求是:2mm x 2mm x长度(50cm),Acceptance Angle:68.2, Numberical Aperture:.5606
请大家帮忙。 |
