请问CCD灰度分辨率?谢谢
如果灰度变化范围很少,如从240-244,那么在CCD能够分辨出来吗?即人眼通过CCD是否能够分辨出来吗?能分辨的最小范围一般由什么决定。人眼能分辨的灰度级在50-60,也即差不多需要64灰度时人眼能够分辨。请问CCD(黑白的)灰度分辨率是由什么决定的?比方如下参数的CCD能够分辨的最小灰度范围。对CCD不懂,不知道是否表达清楚
Sensor: 1/3" IT CCD, 768(H) x 494(V)
Resolution: Horizontal: 570 TVL
Vertical: 350 TVL
Signal to Noise: 57 db
Gain Range: >18db
Enhancement: 0db to +8db @ 5MHz.
Electronic Exposure Range: 1/60 to 1/50,000 sec.
Minimum Illumination: 0.007 lux for 20% video out
(w/ f/1.2 lens) (No IR Filter)
Back Focus Adjustment: ± 1.9mm
Lens Mount: "CS" or "C" (with adapter)
Input Power: +12VDC @ 200mA
Dimensions: 2¼"(W) x 2½"(H) x 5"(L)
Weight: 1 lb.
Operating Temperature: 0ºC to +40ºC |
