Graphical user interface of LASCAD
| Temperature distribution in an end pumped rod
Deformation of an end pumped rod
| zz component of stress in an end pumped rod
Parabolic fit of refractive index
| Coupling into a graded index fiber
Convergence of beam radius with laser cavity iteration
| Intensity profile at outcoupling mirror
Phase profile at outcoupling mirror
| Spectrum of transverse eigenfrequencies
Stability diagram
| Overlap of laser modes and pump beam
Laser power output
| TEM22 Eigenmode
Heat load in a end pumped rod
| Heat load in a end pumped bloc with undoped end-capes
Heat load in a rod pumped from 3 sides
| Heat load in a rod pumped from 2 sides
Dual end pumped rod with undoped endcapes
| Absorbed pump power and temperature distribution in a sandwiched slab pumped from two sides
Flashlamp pumping ZEMAX
