深圳众望达光电有限公司
(泵源都是符合外太空标准,在0度到55度都是不需要制冷)数据如下:
Telcordia Qualification CapabilityGR-1209-CORE / GR-1221-CORE / GR-468-CORE Requirements:
TEST METHOD TEST REQUIREMENT CAPABILITY
Damp Heat 85°C/85% 500 hours Internal
Temperature Cycling -40°C to +85°C Internal
Thermal Shock 0°C to 100°C 15 cycles (hermetic) Internal
High Temperature Storage DRY 85°C 2000 hours lnternal
High Temperature Storage DAMP (hermetic) 85°C/85%RH 500 hours Internal
Low Temperature Storage -40°C 2000 hours Internal
Cyclic Moisture Resistance 85-95%RH @ 70°C to -40°C Internal
Temp/Humidity Cycling -40°C to +85°C 20 to 85%RH Operational Internal
Water Immersion +45°C 168 hours Operational Internal
DWDM Temperature Effect -40°C to +85°C, 1 Cycle Operational Internal
Fiber Flex/twist/side pull Up to 1 kg with cycling and insertion loss measurement Internal
Accelerated Aging 70°C or 85°C Operational 5000 hours Internal
Mechanical Variable Frequency Vibration – 20G (2G operational) External
Mechanical 500G 3 Axis Shock External
RGA Analysis After specific time points in long term aging External
915nm 7W激光器 纤芯:105/125um NA:0.15或0.22
975nm 6.5W激光器 纤芯:105/125um NA:0.15或0.22
976nm 25W激光器,体积很小(比915nm 7W激光器大二倍) 纤芯是105/125um.
976nm 15W激光器 ,纤芯:100um NA:0.22 体积很小(比915nm 7W激光器大二倍)
980nm 50W激光器,纤芯:200um
[ 本帖最后由 cherryyang 于 2008-7-29 12:18 编辑 ] |
