Custom possibilities |
Available spectral window | 400 - 2300 nm |
Available bandwidths (FWHM) | From 0.3 nm to 3 nm depending on wavelength |
Tuning range | From 260 nm to 1300 nm |
Pointing stability | < 1 mm lateral displacement (for 1.3 μm spectral range) |
Peak transmission | Up to 60% |
Wavelength relative resolution | 0.05 nm (for FWHM = 0.3 nm) |
Damage threshold | > 100 kW/cm2 average power > 5 GW/cm2 peak power @ 1064 nm, 8 ns |
Aperture diameter | ≤ 5 mm |
Dimensions (L x W x H) | 10’’ x 7.5’’ x 9.25’’ (25.4 cm x 19.05 cm x 23.5 cm) |
Operating temperature | 10 to 40°C |
Storage temperature | 5 to 50°C |
Software | PHySpec included or basic functions available with ActiveX drivers |
Computer connection | USB 2.0 (compatible 1.1) |
Power supply | 100 - 240 V , 50 - 60 Hz |
