SPECIFICATIONS
Wavelength (nm) 532
Output power (mW) >1, 5, 10, 20, … , 300
Transverse mode TEM00
Longitudinal mode Single
Operating mode CW
Power stability (rms, over 4 hours) <1%, <3%, <5%
Warm-up time (minutes) <15
M2 factor <1. 2
Beam divergence, full angle (mrad) <1. 5
Beam diameter at the aperture (mm) ~2. 0
Beam height from base plate (mm) 24. 8
Spectral linewidth (nm) <0.0001
Polarization ratio >50:1 (45 degree)
Pointing stability after warm-up (mrad) <0.05
Noise of amplitude (rms, 1~20MHz) <0. 5%
Coherent length (m) >50
Operating temperature (℃) 15~35
Power supply (90-264VAC) PSU-III-FDA PSU-III-OEM
Modulation Modulation isn’t available.
Expected lifetime (hours) 10000
Warranty 1 year |
