5楼
楼主 |
发表于 2009-9-29 13:29:37
只看该作者
Single/Dual Fiber Collimator
Two kinds of package: metal tube and glass tube
MINI collimator, WD is 5mm-100mm,
MINI collimator used to make MINI components and
Compact CWDM.
Performance Specifications
Parameters Single Fiber Collimator Dual Fiber Collimator Unit
Grade P A P A
Center Wavelength 1310,1550 mm
Insertion Loss Min 0.07 0.15 0.10 0.20 dB
Max 0.15 0.20 0.20 0.25
Return Loss (Min) 65 60 60 55
Beam Diameter (Max) 0.45 mm
Max Power Handling >800 mW
Tensile Load >5 N
Operation Temperature -20 to +80 ℃
Storage Temperature -40 to +85 ℃
Fiber Type Corning SMF-28e
Fiber Length >1.5 m |
