Avago Technologies (Nasdaq: AVGO), a leading supplier of analog interface components for communications, industrial and consumer applications, today announced a new series of 5mm green and blue high brightness, high performance Through-hole LEDs for use in Electronic Sign and Signal applications. Avago’s competitively priced HLMP-Cxxx Through-hole round LED lamp series provide high reliability performance and high luminous intensity in electronic signs to help improve the contrast ratio and readability in sunlight. These new LEDs are also ideal for use in Traffic Signs, Variable Message Signs, and Monocolor Signs.
Each of the HLMP-Cxxx series LEDs are made with an advanced optical grade epoxy offering superior high temperature and high moisture resistance. Moreover, the package epoxy has high Ultra-violet resistivity which can reduce the effects of long term exposure to direct sunlight.
Features
• High luminous intensity
• Well defined spatial radiation pattern
• Available in green and blue colors
• Pb-Free and RoHS compliant
U.S. Pricing and Availability
Avago’s HLMP-Cxxx LEDs are priced at $0.40 each in 10,000 piece quantities. Samples and production quantities are available now through Avago’s direct sales channel and worldwide distribution partners. More information about Avago’s LED products can be found at www.avagotechlighting.com or www.avagotech.com.
About Avago Technologies
Avago Technologies is a leading supplier of analog interface components for communications, industrial and consumer applications. By leveraging its core competencies in III-V compound and silicon semiconductor design and processing, the company provides an extensive range of analog, mixed signal and optoelectronics components and subsystems to approximately 40,000 end customers. Backed by strong customer service support, the company's products serve four diverse end markets: wireless communications, wired infrastructure, industrial and automotive electronics, and consumer and computing peripherals. Avago has a global employee presence and heritage of technical innovation dating back 40 years to its Hewlett-Packard roots. |
