哪里可以买到测消光比的仪器
回复|共 18 个
landau Lv.9 发表于 2005-6-2 16:46:00|上海 | 查看全部
应该可以测试到40dB
有兴趣讨论讨论。lzc@oelandau.com
opneticom Lv.8 发表于 2005-6-7 01:45:00|广东 | 查看全部
UGA VPMM-100消光比测试仪(偏振分析仪) Polarization Multimeter: VPMM-100 Series 760nm-1550nm 80uW-1.5W Ratio 0-30dB Amplitude -30-+30dB res0.1dB Angle -90-+90deg Phase0-180deg res0.5deg Display8.4Hz ,Input FC fiber Head 52*115*90 1Kg Main 210*100*240 3Kg AC100V manual 1  Conventionally a special optical system and calculating process are required to measure extinction ratio and phase difference. However, with this instrument, extinction ratio and phase difference can be simply evaluated in real time. 1、Extinction ratio, Azimuth, Phase difference and Amplitude ratio can be evaluated.
2、VPMM-100 can be used with inputs of either FC connector fiber or space-collimating light.
3、SC connector is optional.
4、Evaluation can be performed with low level of light-input between 80uW to 1.5mW.
5、For evaluation of Azimuth, VPMM-100 has an angle compensation function and evaluation is realized at any desired angle.
6、Featuring a 7-step LED level for input light power
7、Featuring Averaging function "AVE" (average over 8-times data acquired), stable evaluation with high repeatability is realized.
8、Compact and convenient at narrow space.
9、RS232C interface enables communication with external equipment
zsj1190 Lv.2 发表于 2005-6-8 00:35:00|广东 | 查看全部
找上海瀚宇就可以了,服务好技术到家
angzh030721 Lv.9 发表于 2005-6-8 17:31:00|山东 | 查看全部
消光比需要仪器吗?我们公司买入的片子测消光比都是自己动手的,用个偏振就行了。
yanmountain Lv.5 发表于 2006-1-12 04:56:00|南开大学 | 查看全部
http://bbs.oecr.com/dispbbs.asp?boardID=23ID=35660page=11
站内帖子光通讯测试设备就有提供
Jz_zzzz Lv.3 发表于 2006-1-20 01:48:00|广东 | 查看全部
现在的光学示波器就可以。
navyjack Lv.2 发表于 2006-2-6 18:31:00|广东 | 查看全部
当然是安捷伦和泰克的了。
