查看: 3207|回复: 2
德国halbeckK运动控制卡
发表于 2003-12-30 19:40:00 | 显示全部楼层 |阅读模式
德国halbeck 运动控制卡简介
http://www.servo-halbeck.com
  1.产品类型齐全 可选购 1 到 8 轴控制
  2.技术领先,32 bit 微处理器,内建记忆
  3.操作便利,Auto Tuning, C, C++ Builder, VC,VB, ASCII Command,ACTIVEX 软件
  4.价格适中, 品质性能一流
  5.接收5MHZ伺服编码器回馈信号,
  6.步进马达命令5MHZ
  7.伺服更新速率 50 微秒 /轴 (备有较高速率韧体)
  8.实时 PID 控制 : 速度, 加速度 之前馈及补偿&#59; 积分参数极限
  9.可控制步进和伺服马达,可选购VME, PC/104, PCI,ISA, RS232, USB, CAN, 和 ETHERNET 等各种接口
The P800 Motion Controller are fully compliant PC/104-Bus cards that fit directly into a PC/104 connector. The P800 are used in embedded control systems for industrial control, automation and robotic applications. They are available in one (P8x1), two (P8x2), and four (P8x4) axis configurations.
The motion processor is driven by a host microprocessor via a 16-bit bus interface or through an asynchronous bi-directional serial port, giving users the ability to offload resource intensive motion control functions from the application’s host.
●Motion profiles include S-curve, trapezoidal, velocity contouring, and electronic gearing, linear  circular interpolation for 4 axes.
●Trace capabilities for system performance checks, servo-tuning, maintenance and diagnostics.
●Encoder rate of 5.0 Mcounts/sec allows use of fine resolution feedback devices.
●10-bit 20 kHz PWM or 16-bit DAC motor control output to amplifier.
●8 general-purpose analog inputs.....
The P400 series is an enhanced standalone motion controller for 2 to 8 axes. It is either available for servo (brushtype and brushless) or stepper motors or in a combination of both (option and on request). The P400 is used in embedded control systems for industrial control, automation and robotic applications. The P400 is developed for either brushtype, brushless servo motors or a combination of both, microstepping or stepper motors. The motion processor is driven by a host microprocessor via a 16-bit bus interface or through an asynchronous bi-directional serial port, giving users the ability to offload resource intensive motion control functions from the application’s host.
发表于 2004-2-10 17:33:00 | 显示全部楼层
德国halbeckK运动控制卡
haha
发表于 2004-2-16 19:10:00 | 显示全部楼层
德国halbeckK运动控制卡
看不懂
