zemax 英文版说明书
1.9k 1
发表于 2004-6-1 16:05:00|浙江 | 查看全部 阅读模式
Download Files
Each new version of ZEMAX includes license codes for all users who have support. Updated license codes will be posted periodically for new keys. If your support has expired, you will not be able to run the latest version of ZEMAX until you renew your support, and the next license code file or update is released.
We recommend that you archive your update files for future use, or re-installation.
File
ZEMAX Update, April 27, 2004
Download ZEMAX_2004-04-27.exe (9.8 MB)
Comments Installs the current version of ZEMAX. Click here for what's new in this version. This release of ZEMAX requires Rainbow Hardware Key Driver version 5.41.1 or later. Download other files as needed below.
File
ZEMAX Manual, May 3, 2004
Download ZEMAX_Manual_2004-05-03.exe (4.7 MB)
Comments Installs the current ZEMAX manual. If you need Acrobat Reader to read PDF files, download from Adobe here.
File
Download SSD5411-32bit.exe (4.88 MB)
Comments System driver for communication with the hardware key. The driver is usually only needed for first-time installations. To install the driver on new Windows 2000, XP, or NT computers, you must be logged in as administrator. If you have a USB key, do not plug the key into the computer before installing the driver.
See also Rainbow's SuperproMedic.exe troubleshooting utility.
File
License code file, updated daily.
Download lc.dat (0.30 MB)
Comments License codes for the current version. Click to download file, then copy to your ZEMAX directory after installing the current version update.
File
ZEMAX Tutorial Help File, April 29, 2003
Download ZEMAX_Tutorial.exe (3.3 MB)
Comments Installs the ZEMAX tutorial help file.
File
ZEMAX Demo Version
Download ZEMAXDemo.exe (12.6 MB)
Comments Installs the ZEMAX Demonstration version and manual.
geezer Lv.8 发表于 2004-7-10 19:41:00|广东 | 查看全部
早就知道了
