Win2000命令全集 -1
1.7k 2
发表于 2004-6-17 09:11:00|山东 | 查看全部 阅读模式
Win2000命令全集 -1
accwiz.exe  Accessibility Wizard for walking you through setting up your machine for your?mobility needs. 辅助工具向导
acsetups.exe  ACS setup DCOM server executable
actmovie.exe  Direct Show setup tool 直接显示安装工具
append.exe  Allows programs to open data in specified directories as if they were in the current directory. 允许程序打开制定目录中的数据
arp.exe  NETWORK Display and modify IP - Hardware addresses 显示和更改计算机的IP与硬件物理地址的对应列表
at.exe  AT is a scheduling utility also included with UNIX 计划运行任务
atmadm.exe  Displays statistics for ATM call manager. ATM调用管理器统计
attrib.exe  Display and modify attributes for files and folders 显示和更改文件和文件夹属性
autochk.exe  Used to check and repair Windows File Systems 检测修复文件系统
autoconv.exe  Automates the file system conversion during reboots 在启动过程中自动转化系统
autofmt.exe  Automates the file format process during reboots 在启动过程中格式化进程
autolfn.exe  Used for formatting long file names 使用长文件名格式
bootok.exe  Boot acceptance application for registry
bootvrfy.exe  Bootvrfy.exe, a program included in Windows 2000 that notifies the system that startup was successful. Bootvrfy.exe can be run on a local or remote computer. 通报启动成功
cacls.exe  Displays or modifies access control lists (ACLs) of files. 显示和编辑ACL
calc.exe  Windows Calculators 计算器
cdplayer.exe  Windows CD Player CD播放器
change.exe  Change { User | Port | Logon } 与终端服务器相关的查询
charmap.exe  Character Map 字符映射表
chglogon.exe  Same as using "Change Logon" 启动或停用会话记录
chgport.exe  Same as using "Change Port" 改变端口(终端服务)
chgusr.exe  Same as using "Change User" 改变用户(终端服务)
chkdsk.exe  Check the hard disk for errors similar to Scandisk 3 Stages must specify a Drive Letter 磁盘检测程序
chkntfs.exe  Same as using chkdsk but for NTFS NTFS磁盘检测程序
cidaemon.exe  Component of Ci Filer Service 组成Ci文档服务
cipher.exe  Displays or alters the encryption of directories [files] on NTFS partitions. 在NTFS上显示或改变加密的文件或目录
cisvc.exe  Content Index -- It's the content indexing service for I 索引内容
ckcnv.exe  Cookie Convertor 变换Cookie
cleanmgr.exe  Disk Cleanup, popular with Windows 98 磁盘清理
cliconfg.exe  SQL Server Client Network Utility SQL客户网络工具
clipbrd.exe  Clipboard viewer for Local will allow you to connect to other clipboards 剪贴簿查看器
clipsrv.exe  Start the clipboard Server 运行Clipboard服务
clspack.exe  CLSPACK used to create a file listing of system packages 建立系统文件列表清单
cluster.exe  Display a cluster in a domain 显示域的集群
_cmd_.exe  Famous command prompt 没什么好说的!
cmdl32.exe  Connection Manager Auto-Download 自动下载连接管理
cmmgr32.exe  Connection Manager 连接管理器
cmmon32.exe  Connection Manager Monitor 连接管理器监视
cmstp.exe  Connection Manager Profile Manager 连接管理器配置文件安装程序
comclust.exe  about cluster server 集群
comp.exe  ComClust Add, Remove, or Join a cluster. 比较两个文件和文件集的内容*
compact.exe  Displays or alters the compression of files on NTFS partitions. 显示或改变NTFS分区上文件的压缩状态
conime.exe  Console IME IME控制台
control.exe  Starts the control panel 控制面板
convert.exe  Convert File System to NTFS 转换文件系统到NTFS
convlog.exe  Converts MS IIS log files 转换IIS日志文件格式到NCSA格式
cprofile.exe  Copy profiles 转换显示模式
cscript.exe  MS Windows Scripts Host Version 5.1 较本宿主版本
csrss.exe  Client Server Runtime Process 客户服务器Runtime进程
csvde.exe  Comma Separated Variable Import/Export Utility 日至格式转换程序
dbgtrace.exe  和Terminal Server相关
dcomcnfg.exe  Display the current DCOM configuration. DCOM配置属性
dcphelp.exe  ?
dcpromo.exe  Promote a domain controller to ADSI AD安装向导
ddeshare.exe  Display DDE shares on local or remote computer DDE共享
ddmprxy.exe
debug.exe  Runs Debug, a program testing and editing tool. 就是DEBUG啦!
dfrgfat.exe  Defrag FAT file system FAT分区磁盘碎片整理程序
dfrgntfs.exe  Defrag NTFS file system NTFS分区磁盘碎片整理程序
dfs_cmd_.exe  configures a Dfs tree 配置一个DFS树
dfsinit.exe  Distributed File System Initialization 分布式文件系统初始化
dfssvc.exe  Distributed File System Server 分布式文件系统服务器
diantz.exe  MS Cabinet Maker 制作CAB文件
diskperf.exe  Starts physical Disk Performance counters 磁盘性能计数器
dllhost.exe  dllhost is used on all versions of Windows 2000. dllhost is the hedost process for all COM+ applications. 所有COM+应用软件的主进程
dllhst3g.exe
dmadmin.exe  Disk Manager Service 磁盘管理服务
dmremote.exe  Part of disk management 磁盘管理服务的一部分
dns.exe  DNS Applications DNS
doskey.exe  recalls Windows command lines and creates macros 命令行创建宏
dosx.exe  DOS Extender DOS扩展
dplaysvr.exe  Direct Play Helper 直接运行帮助
drwatson.exe  Dr Watson for 2000 Fault Detector 华生医生错误检测
drwtsn32.exe  Dr Watson for 2000 viewer and configuration manager 华生医生显示和配置管理
dtcsetup.exe  Installs MDTC
dvdplay.exe  Windows 2000 DVD player DVD播放
dxdiag.exe  Direct-X Diagnostics Direct-X诊断工具
edlin.exe  line-oriented text editor. 命令行的文本编辑器(历史悠久啊!)
esentutl.exe  MS Database Utility MS数据库工具
eudcedit.exe  Private character editor Ture Type造字程序
eventvwr.exe  Windows 2000 Event Viewer 事件查看器
evnt_cmd_.exe  Event to trap translator; Configuration tool
evntwin.exe  Event to trap translator setup
exe2bin.exe  Converts EXE to binary format 转换EXE文件到二进制
expand.exe  Expand Files that have been compressed 解压缩
extrac32.exe  CAB File extraction utility 解CAB工具
fastopen.exe  Fastopen tracks the location of files on a hard disk and stores the information in memory for fast access. 快速访问在内存中的硬盘文件
faxcover.exe  Fax Cover page editor 传真封面编辑
faxqueue.exe  Display Fax Queue 显示传真队列
faxsend.exe  Fax Wizard for sending faxes 发送传真向导
faxsvc.exe  Starts fax server 启动传真服务
fc.exe  Compares two files or sets of files and their differences 比较两个文件的不同
find.exe  Searches for a text string in file or files 查找文件中的文本行
findstr.exe  Searches for strings in files 查找文件中的行
finger.exe  Fingers a user and displays statistics on that user Finger一个用户并显示出统计结果
fixmapi.exe  Fix mapi files 修复MAPI文件
flattemp.exe  Enable or disable temporally directories 允许或者禁用临时文件目录
fontview.exe  Display fonts in a font file 显示字体文件中的字体
forcedos.exe  Forces a file to start in dos mode. 强制文件在DOS模式下运行
freecell.exe  Popular Windows Game 空当接龙
ftp.exe  File Transfer Protocol used to transfer files over a network connection 就是FTP了
gdi.exe  Graphic Device Interface 图形界面驱动
grovel.exe
grpconv.exe  Program Manager Group Convertor 转换程序管理员组
help.exe  displays help for Windows 2000 commands 显示帮助
hostname.exe  Display hostname for machine. 显示机器的Hostname
ie4uinit.exe  IE5 User Install tool IE5用户安装工具
ieshwiz.exe  Customize folder wizard 自定义文件夹向导
iexpress.exe  Create and setup packages for install 穿件安装包
iisreset.exe  Restart IIS Admin Service 重启IIS服务
internat.exe  Keyboard Language Indicator Applet 键盘语言指示器
ipconfig.exe  Windows 2000 IP configuration. 察看IP配置
ipsecmon.exe  IP Security Monitor IP安全监视器
ipxroute.exe  IPX Routing and Source Routing Control Program IPX路由和源路由控制程序
irftp.exe  Setup FTP for wireless communication 无线连接
ismserv.exe  Intersite messaging Service 安装或者删除Service Control Manager中的服务
jdbgmgr.exe  Microsoft debugger for java 4 Java4的调试器
jetconv.exe  Convert a Jet Engine Database 转换Jet Engine数据库
jetpack.exe  Compact Jet Database. 压缩Jet数据库
jview.exe  Command-line loader for Java Java的命令行装载者
krnl386.exe  Core Component for Windows 2000 2000的核心组件
label.exe  Change label for drives 改变驱动器的卷标
lcwiz.exe  License Compliance Wizard for local or remote systems. 许可证符合向导
ldifde.exe  LDIF cmd line manager LDIF目录交换命令行管理
licmgr.exe  Terminal Server License Manager 终端服务许可协议管理
lights.exe  display connection status lights 显示连接状况
llsmgr.exe  Windows 2000 License Manager 2000许可协议管理
llssrv.exe  Start the license Server 启动许可协议服务器
lnkstub.exe
locator.exe  RPC Locator 远程定位
lodctr.exe  Load perfmon counters 调用性能计数
logoff.exe  Log current user off. 注销用户
lpq.exe  Displays status of a remote LPD queue 显示远端的LPD打印队列的状态,显示被送到基于Unix的服务器的打印任务
lpr.exe  Send a print job to a network printer. 重定向打印任务到网络中的打印机。通常用于Unix客户打印机将打印任务发送给连接了打印设备的NT的打印机服务器。
lsass.exe  LSA Executable and Server DLL 运行LSA和Server的DLL
lserver.exe  Specifies the new DNS domain for the default server 指定默认Server新的DNS域
macfile.exe  Used for managing MACFILES 管理MACFILES
magnify.exe  Used to magnify the current screen 放大镜
makecab.exe  MS Cabinet Maker 制作CAB文件
mdm.exe  Machine Debug Manager 机器调试管理
mem.exe  Display current Memory stats 显示内存状态
migpwd.exe  Migrate passwords. 迁移密码
回复|共 2 个
suncon 楼主Lv.12 发表于 2004-6-17 09:11:00|山东 | 查看全部
Win2000命令全集 -2
mmc.exe  Microsoft Management Console 控制台
mnmsrvc.exe  Netmeeting Remote Desktop Sharing NetMeeting远程桌面共享
mobsync.exe  Manage Synchronization. 同步目录管理器
mountvol.exe  Creates, deletes, or lists a volume mount point. 创建、删除或列出卷的装入点。
mplay32.exe  MS Media Player 媒体播放器
mpnotify.exe  Multiple Provider Notification application 多提供者通知应用程序
mq1sync.exe
mqbkup.exe  MS Message Queue Backup and Restore Utility 信息队列备份和恢复工具
mqexchng.exe  MSMQ Exchange Connector Setup 信息队列交换连接设置
mqmig.exe  MSMQ Migration Utility 信息队列迁移工具
mqsvc.exe  ?
mrinfo.exe  Multicast routing using SNMP 使用SNMP多点传送路由
mscdexnt.exe  Installs MSCD (MS CD Extensions) 安装MSCD
msdtc.exe  Dynamic Transaction Controller Console 动态事务处理控制台
msg.exe  Send a message to a user local or remote. 发送消息到本地或远程客户
mshta.exe  HTML Application HOST HTML应用程序主机
msiexec.exe  Starts Windows Installer Program 开始Windows安装程序
mspaint.exe  Microsoft Paint 画板
msswchx.exe
mstask.exe  Task Schedule Program 任务计划表程序
mstinit.exe  Task scheduler setup 任务计划表安装
narrator.exe  Program will allow you to have a narrator for reading. Microsoft讲述人
nbtstat.exe  Displays protocol stats and current TCP/IP connections using NBT 使用 NBT(TCP/IP 上的 NetBIOS)显示协议统计和当前 TCP/IP 连接。
nddeapir.exe  NDDE API Server side NDDE API服务器端
net.exe  Net Utility 详细用法看/?
net1.exe  Net Utility updated version from MS Net的升级版
netdde.exe  Network DDE will install itself into the background 安装自己到后台
netsh.exe  Creates a shell for network information 用于配置和监控 Windows 2000 命令行脚本接口。
netstat.exe  Displays current connections. 显示协议统计和当前的 TCP/IP 网络连接。
nlsfunc.exe  Loads country-specific information 加载特定国家(地区)的信息。Windows 2000 和 MS-DOS 子系统不使用该命令。接受该命令只是为了与 MS-DOS 文件兼容。
notepad.exe  Opens Windows 2000 Notepad 记事本
nslookup.exe  Displays information for DNS 该诊断工具显示来自域名系统 (DNS) 名称服务器的信息。
ntbackup.exe  Opens the NT Backup Utility 备份和故障修复工具
ntbooks.exe  Starts Windows Help Utility 帮助
ntdsutil.exe  Performs DB maintenance of the ADSI 完成ADSI的DB的维护
ntfrs.exe  NT File Replication Service NT文件复制服务
ntfrsupg.exe
ntkrnlpa.exe  Kernel patch 核心补丁
ntoskrnl.exe  Core NT Kernel KT的核心
ntsd.exe
ntvdm.exe  Simulates a 16-bit Windows environment 模拟16位Windows环境
nw16.exe  Netware Redirector NetWare转向器
nwscript.exe  runs netware scripts 运行Netware脚本
odbcad32.exe  ODBC 32-bit Administrator 32位ODBC管理
odbcconf.exe  Configure ODBC driver's and data source's from command line 命令行配置ODBC驱动和数据源
os2.exe  An OS/2 Warp Server (os2 /o) OS/2
os2srv.exe  An OS/2 Warp Server OS/2
os2ss.exe  An OS/2 Warp Server OS/2
osk.exe  On Screen Keyboard 屏幕键盘
packager.exe  Windows 2000 Packager Manager 对象包装程序
pathping.exe  Combination of Ping and Tracert 包含Ping和Tracert的程序
pax.exe  is a POSIX program and path names used as arguments must be specified in POSIX format. Use "file://C/Users/Default" instead of "C:\USERS\DEFAULT." 启动便携式存档互换 (Pax) 实用程序
pentnt.exe  Used to check the Pentium for the floating point division error. 检查Pentium的浮点错误
perfmon.exe  Starts Windows Performance Monitor 性能监视器
ping.exe  Packet Internet Groper 验证与远程计算机的连接
posix.exe  Used for backward compatibility with Unix 用于兼容Unix
print.exe  Cmd line used to print files 打印文本文件或显示打印队列的内容。
progman.exe  Program manager 程序管理器
proquota.exe  Profile quota program
psxss.exe  POSIX Subsystem Application Posix子系统应用程序
qappsrv.exe  Displays the available application terminal servers on the network
在网络上显示终端服务器可用的程序
qprocess.exe  Display information about processes local or remote 在本地或远程显示进程的信息(需终端服务)
query.exe  Query TERMSERVER user process and sessions 查询进程和对话
quser.exe  Display information about a user logged on 显示用户登陆的信息(需终端服务)
qwinsta.exe  Display information about Terminal Sessions. 显示终端服务的信息
rasadmin.exe  Start the remote access admin service 启动远程访问服务
rasautou.exe  Creates a RAS connection 建立一个RAS连接
rasdial.exe  Dial a connection 拨号连接
rasphone.exe  Starts a RAS connection 运行RAS连接
rcp.exe  Copies a file from and to a RCP service. 在 Windows 2000 计算机和运行远程外壳端口监控程序 rshd 的系统之间复制文件
rdpclip.exe  RdpClip allows you to copy and paste files between a terminal session and client console session. 再终端和本地复制和粘贴文件
recover.exe  Recovers readable information from a bad or defective disk 从坏的或有缺陷的磁盘中恢复可读取的信息。
redir.exe  Starts the redirector service 运行重定向服务
regedt32.exe  32-bit register service 32位注册服务
regini.exe  modify registry permissions from within a script 用脚本修改注册许可
register.exe  Register a program so it can have special execution characteristics. 注册包含特殊运行字符的程序
regsvc.exe
regsvr32.exe  Registers and unregister's dll's. As to how and where it register's them I dont know. 注册和反注册DLL
regtrace.exe  Options to tune debug options for applications failing to dump trace statements
Trace 设置
regwiz.exe  Registration Wizard 注册向导
remrras.exe
replace.exe  Replace files 用源目录中的同名文件替换目标目录中的文件。
reset.exe  Reset an active section 重置活动部分
rexec.exe  Runs commands on remote hosts running the REXEC service. 在运行 REXEC 服务的远程计算机上运行命令。rexec 命令在执行指定命令前,验证远程计算机上的用户名,只有安装了 TCP/IP 协议后才可以使用该命令。
risetup.exe  Starts the Remote Installation Service Wizard. 运行远程安装向导服务
route.exe  display or edit the current routing tables. 控制网络路由表
routemon.exe  no longer supported 不再支持了!
router.exe  Router software that runs either on a dedicated DOS or on an OS/2 system. Route软件在 DOS或者是OS/2系统
rsh.exe  Runs commands on remote hosts running the RSH service 在运行 RSH 服务的远程计算机上运行命令
rsm.exe  Mounts and configures remote system media 配置远程系统媒体
rsnotify.exe  Remote storage notification recall 远程存储通知回显
rsvp.exe  Resource reservation protocol 源预约协议
runas.exe  RUN a program as another user 允许用户用其他权限运行指定的工具和程序
rundll32.exe  Launches a 32-bit dll program 启动32位DLL程序
runonce.exe  Causes a program to run during startup 运行程序再开始菜单中
rwinsta.exe  Reset the session subsystem hardware and software to known initial values 重置会话子系统硬件和软件到最初的值
savedump.exe  Does not write to e:\winnt\user.dmp 不写入User.dmp中
scardsvr.exe  Smart Card resource management server 子能卡资源管理服务器
schupgr.exe  It will read the schema update files (.ldf files) and upgrade the schema. (part of ADSI) 读取计划更新文件和更新计划
secedit.exe  Starts Security Editor help 自动安全性配置管理
services.exe  Controls all the services 控制所有服务
sethc.exe  Set High Contrast - changes colours and display mode Logoff to set it back to normal 设置高对比
setreg.exe  Shows the Software Publishing State Key Values 显示软件发布的国家语言
setup.exe  GUI box prompts you to goto control panel to configure system components 安装程序(转到控制面板)
setver.exe  Set Version for Files 设置 MS-DOS 子系统向程序报告的 MS-DOS 版本号
sfc.exe  System File Checker test and check system files for integrity 系统文件检查
sfmprint.exe  Print Services for Macintosh 打印Macintosh服务
sfmpsexe.exe
sfmsvc.exe
shadow.exe  Monitor another Terminal Services session. 监控另外一台中端服务器会话
share.exe  Windows 2000 和 MS-DOS 子系统不使用该命令。接受该命令只是为了与 MS-DOS 文件兼容
shmgrate.exe
shrpubw.exe  Create and Share folders 建立和共享文件夹
sigverif.exe  File Signature Verification 文件签名验证
skeys.exe  Serial Keys utility 序列号制作工具
smlogsvc.exe  Performance Logs and Alerts 性能日志和警报
smss.exe
sndrec32.exe  starts the Windows Sound Recorder 录音机
sndvol32.exe  Display the current volume information 显示声音控制信息
snmp.exe  Simple Network Management Protocol used for Network Mangement 简单网络管理协议
snmptrap.exe  Utility used with SNMP SNMP工具
sol.exe  Windows Solitaire Game 纸牌
sort.exe  Compares files and Folders 读取输入、排序数据并将结果写到屏幕、文件和其他设备上
SPOOLSV.EXE  Part of the spooler service for printing 打印池服务的一部分
sprestrt.exe
srvmgr.exe  Starts the Windows Server Manager 服务器管理器
stimon.exe  WDM StillImage-  Monitor
stisvc.exe  WDM StillImage-  Service
subst.exe  Associates a path with a drive letter 将路径与驱动器盘符关联
svchost.exe  Svchost.exe is a generic host process name for services that are run from dynamic-link libraries (DLLs). DLL得主进程
syncapp.exe  Creates Windows Briefcase. 创建Windows文件包
sysedit.exe  Opens Editor for 4 system files 系统配置编辑器
syskey.exe  Encrypt and secure system database NT账号数据库按群工具
sysocmgr.exe  Windows 2000 Setup 2000安装程序
systray.exe  Starts the systray in the lower right corner. 在低权限运行systray
taskman.exe  Task Manager 任务管理器
taskmgr.exe  Starts the Windows 2000 Task Manager 任务管理器
tcmsetup.exe  telephony client wizard 电话服务客户安装
tcpsvcs.exe  TCP Services TCP服务
.exe  Telnet Utility used to connect to Telnet Server
suncon 楼主Lv.12 发表于 2004-6-17 09:12:00|山东 | 查看全部
Win2000命令全集 -3
termsrv.exe  Terminal Server 终端服务
tftp.exe  Trivial FTP 将文件传输到正在运行 TFTP 服务的远程计算机或从正在运行 TFTP 服务的远程计算机传输文件
tftpd.exe  Trivial FTP Daemon
themes.exe  Change Windows Themes 桌面主题
tlntadmn.exe  Telnet Server Administrator Telnet服务管理
tlntsess.exe  Display the current Telnet Sessions 显示目前的Telnet会话
tlntsvr.exe  Start the Telnet Server 开始Telnet服务
tracert.exe  Trace a route to display paths 该诊断实用程序将包含不同生存时间 (TTL) 值的 Internet 控制消息协议 (ICMP) 回显数据包发送到目标,以决定到达目标采用的路由
tsadmin.exe  Terminal Server Administrator 终端服务管理器
tscon.exe  Attaches a user session to a terminal session. 粘贴用户会话到终端对话
tsdiscon.exe  Disconnect a user from a terminal session 断开终端服务的用户
tskill.exe  Kill a Terminal server process 杀掉终端服务
tsprof.exe  Used with Terminal Server to query results. 用终端服务得出查询结果
tsshutdn.exe  Shutdown the system 关闭系统
unlodctr.exe  Part of performance monitoring 性能监视器的一部分
upg351db.exe  Upgrade a jet database 升级Jet数据库
ups.exe  UPS service UPS服务
user.exe  Core Windows Service Windows核心服务
userinit.exe  Part of the winlogon process Winlogon进程的一部分
usrmgr.exe  Start the windows user manager for domains 域用户管理器
utilman.exe  This tool enables an administrator to designate which computers automatically open accessibility tools when Windows 2000 starts. 指定2000启动时自动打开那台机器
verifier.exe  Driver Verifier Manager Driver Verifier Manager
vwipxspx.exe  Loads IPX/SPX VDM 调用IPX/SPX VDM
w32tm.exe  Windows Time Server 时间服务器
wextract.exe  Used to extract windows files 解压缩Windows文件
winchat.exe  Opens Windows Chat 打开Windows聊天
winhlp32.exe  Starts the Windows Help System 运行帮助系统
winlogon.exe  Used as part of the logon process. Logon进程的一部分
winmine.exe  windows Game 挖地雷
winmsd.exe  Windows Diagnostic utility 系统信息
wins.exe  Wins Service Wins服务
winspool.exe  Print Routing 打印路由
winver.exe  Displays the current version of Windows 显示Windows版本
wizmgr.exe  Starts Windows Administration Wizards Windows管理向导
wjview.exe  Command line loader for Java 命令行调用Java
wowdeb.exe  . For starters, the 32-bit APIs require that the WOWDEB.EXE task runs in the target debugee's VM 启动时,32位API需要
wowexec.exe  For running Windows over Windows Applications 在Windows应用程序上运行Windows
wpnpinst.exe  ?
write.exe  Starts MS Write Program 写字板
wscript.exe  Windows Scripting Utility 脚本工具
wupdmgr.exe  Starts the Windows update Wizard (Internet) 运行Windows升级向导
xcopy.exe  Used to copy directories 复制文件和目录,包括子目录
