[供应] 1×1 1×2 1×4 1×8 2×2 光开关汇总
 火
1.5k 0
发表于 2014-7-15 11:48:15|广东 | 查看全部 阅读模式
1×N Optical Switch
Features
•More Than 128Channels
•Low Loss and High Reliability
&#8226arallel Interface (TTL)
•Modularized Design
•Epoxy-free on Optical Path
Application
•Ring Network
•Remote Monitoring in Optical Network
•Testing of Fiber, Optical Component
Specifications
Parameters                FY-1×N
Insertion Loss        dB        1<N≤45        45<N≤88        88<N≤128
                Typ:0.8  Max:1.0        Typ:1.2  Max:1.5        Typ:1.7  Max:2.0
Wavelength Range        nm        850±40/1300±40
850(SM)        1260&#61566;1650
1260&#61566;1620(SM)
Test Wavelength        nm        850/1310
850        1310/1550
1310/1490/1550/1625
Return Loss        dB        SM≥50、MM≥30
Crosstalk        dB        SM≥55、MM≥35
PDL        dB        ≤0.05
WDL
dB        dB        ≤0.25
TDL        dB        ≤0.25
Repeatability        dB        ≤±0.05
Durability        cycles        ≥10 Million
Transmission Power          mW        mW        ≤500
Switch Time        ms         ≤10(Sequence switch time of adjacent channel)
Operating Temperature        &#61616;C        -20~+70
Storage Temperature        &#61616;C        -40~+85
Power Supply        V        +5 or 12
Relative Humidity                5~+95
Dimension        mm        1<N<4 (135×40×32)        4≤N≤12 (135×64×32)        12<N≤16(184×78×36)
                 16<N≤45(184×78×66)        N≤<88 (184×156×66)        88≤N≤128(184×220×66)
                N≤16(140×77.5×32)        N≤32(140×77.5×64)
Ordering Information
Channel        Mode        Wavelength        Voltage Type         Fiber type        Fiber diameter        Fiber Length        Connector
1~128        S=SM M=MM        85=850nm
13=1310nm
15=1550nm
162= 1625nm
165=1650nm
13/15=1310/1550nm        3=5V
5=12V        5=50/125
6=62.5/125
9=9/125
X= Other        25=250um
90=900um;
20=2.0mm
30=3.0mm
X= Other        05=0.5m
10=1.0m
15=1.5m
X=Other        0=None
1=FC/PC
2=FC/APC
3=SC/PC
4=SC/APC
5=ST/PC
6=ST/APC
7=LC/PC
8=LC/APC
X=Others
Pin Configurations
DB-9 male connector  (max.1×16)
Pin No.        Signal Name        I / O            Description
1        D0        Input        TTL, Channel selection bit 0
2        D1        Input        TTL, Channel selection bit 1
3        D2        Input        TTL, Channel selection bit 2
4        D3        Input        TTL, Channel selection bit 3
5        /RESET        Input        TTL, Low level reset to channel 0. High level means channel selection bits are effective.
6        /READY        Output        TTL, Ready (High=Not ready, Low=Ready)
7        ERROR        Output        TTL, Error (High=Error, Low=No error)
8        GND        Input        Ground
9        +5VDC        Input        5.0±5% VDC Power Supply (max 550mA)
吴海燕  132 6585 3433
珠海飞宇光电科科技有限公司(深圳业务中心)
地址:深圳市宝安区龙华鹊山路口太阳能硅谷大厦A座14楼
电话:0755-28113498-6037
传真:0755-29048624
Http://www.opticres.com
