查看: 2491|回复: 0
[技术] 摄远物镜实现太阳模拟器的小型化
发表于 2015-7-10 16:37:42 | 显示全部楼层 |阅读模式
摄远物镜实现太阳模拟器的小型化
Miniaturization of Solar Simulator by Using Telephoto Lens
下载全文
摄远物镜实现太阳模拟器的小型化.pdf (589.05 KB, 下载次数: 0)
作  者:吕涛 付东辉 陈小云 郭帮辉
Lv Tao,Fu Donghui,Chen Xiaoyun,Guo Banghui(Changchun Institute of Optics, Fine Mechanics and Physics, Chinese Academy of Sciences, Changchun, Jilin 130033, China)
机构地区:中国科学院长春光学精密机械物理研究所,吉林长春130033
出  处:《激光与光电子学进展》 CSCD 2015年第52卷第1期 173-178页,共6页
Laser & Optoelectronics Progress
基  金:国家863计划(2013AA7031010B)
摘  要:太阳模拟器是非成像光学领域的重要应用。由于光学系统的特殊性,导致其光路很长,当采用双分离准直物镜时,准直系统的长度占了很大一部分。因此为实现太阳模拟器的小型化,提出将具有短后截距的摄远物镜替代通常采用的双分离准直物镜,从而缩短准直系统的长度,使光学系统的结构更加紧凑。同时设计了一种三片式的摄远物镜,并通过Light Tools软件仿真分析的方法研究了这种三片式的摄远准直物镜对太阳模拟器技术指标的影响。仿真结果表明:应用这种摄远物镜可以在太阳模拟器技术指标变化不大的情况下,实现太阳模拟光学系统缩短,有利于太阳模拟器的小型化。
Solar simulator is an important application in non-imaging optics, its optical path is long because of the special optical system, and the collimating system accounts for nearly half of the whole optical path when the dual separation collimating lens are used. In order to achieve the miniaturization of solar simulator, the telephoto lens is used, and the telephoto lens has a short back focal length. When the dual separation collimating lens is replaced by the telephoto lens, the optical path of the collimating system can be shorter and the whole solar simulator optical path can be more compact. The collimating system with three-piece telephoto lens is designed, and the impact on the solar simulator technical specifications is studied through LightTools software simulation analysis. The simulation results show that although the solar simulator technical specifications change little. The simulator optical path becomes shorter, therefore the solar simulator can be miniaturized by using the telephoto lens as collimating optical system.
关键词:光学设计 非成像光学 太阳模拟器 小型化 摄远物镜 准直
optical design ; non-imaging optics ; solar simulator ; miniaturization ; telephoto lens ; collimation ;
本帖被以下淘专辑推荐:
